查看: 3598|回复: 0
[TestStand] NI TestStand 2016SP1 Win64ENG 美国国家仪器测试序列管理软件TS2016SP1 Win64英文版下载
  • 签到天数: 3594 天
    连续签到: 2 天
    发表于 2020-2-29 23:40:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    TestStand是一款旨在帮助测试和验证工程师快速构建和部署自动化测试系统的应用软件。自TestStand2010版开始,TS版本号由数字改为年代版本。自TestStand2014版开始,增加TS64位版本。
    TestStand是一款可立即运行的测试管理软件,可帮助您快速开发自动化测试和验证系统。您可以使用TestStand来开发、执行和部署测试系统软件。还可以通过在TestStand中开发测试序列来扩展系统的功能,这些测试序列可集成使用任何编程语言编写的代码模块。TestStand还为报告生成、数据库记录以及与其他企业系统的连接提供了可扩展的插件。您可以使用易用的操作界面将测试系统部署到生产环境中。
    百度网盘下载(EXE版与ZIP版内容一样,EXE版为NI早期发行时的版本,ZIP版为NI后期重新压缩的版本):
    TestStand2016SP1EXE版X64
    链接:
    请注册视觉论坛会员登录后购买附件下载查看 提取码: 请购买附件下载查看
    TestStand2016SP1ZIP版X64
    链接:
    TestStand2016SP1下载器X64
    链接:
    请购买附件下载查看
    TS2016SP1X64.txt (1.13 KB, 下载次数: 12, 售价: 10 元)
    TestStand 2016 SP1 Readme
    May 2017
    This document contains information about TestStand 2016 SP1. Refer to the TestStand 2016 Release Notes for information about getting started with TestStand, such as system requirements, licensing information, and installation instructions. If you do not activate a TestStand license, TestStand operates in Evaluation Mode.
    Refer to the What's New in TestStand topics for TestStand 2016 SP1 in the NI TestStand Help for detailed information about new features and other changes since TestStand 2016. Refer to the What's New in TestStand topics for previous versions of TestStand in the NI TestStand Help for information about new features, compatibility and known issues, and bug fixes for those versions.
    Upgrading TestStand 2016 to TestStand 2016 SP1
    Additional TestStand Resources
    TestStand 2016 SP1 supports the following operating systems:
    • Windows 10/8.11/7 SP12
    Note  In 2016 TestStand dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. TestStand 2016 SP1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use TestStand 2016 SP1 to an unsupported OS. Additionally, after installing TestStand 2016 SP1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    TestStand 2016 SP1 provides full support for the following application software versions, including service packs. Refer to the TestStand 2016 Release Notes to see application software that TestStand allows, but does not fully support. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Application SoftwareVersions Supported by TestStand 2016 SP1
    LabVIEW2013 SP1, 2014 SP1, 2015 SP1, 2016 SP1, 2017
    LabWindows™/CVI™2012 SP1, 2013 SP2, 2015 SP1, 2017
    NI Measurement Studio - Visual Studio MFC Legacy SupportR3 for Visual Studio 2010; R1 for Visual Studio 2012
    NI Switch Executive3.5, 3.6 (32-bit only); 15.1
    TestStand 2016 SP1 supports the following Microsoft Visual Studio versions and associated programming languages.
    Programming LanguagesVisual Studio Versions Supported by TestStand 2016 SP1
    .NET Framework 4.6.2 Languages
    (Visual C#, Visual Basic .NET)
    2012, 2013, or 2015
    You can install TestStand or deployments of TestStand for TestStand 2016 SP1 and TestStand 2014 SP1 or earlier on the same computer. Use the TestStand Version Selector to select the active version of TestStand before you launch TestStand or a deployed TestStand application. National Instruments does not support running applications that use two different versions of TestStand at the same time.
    You cannot install TestStand 2016 SP1 over a previous version, such as TestStand 2014 SP1, and you cannot install TestStand 2016 SP1 in the default installation directory for a previous version. If you installed a previous version of TestStand in a non-default directory, you can uninstall the previous version of TestStand and install TestStand 2016 SP1 to that directory.
    Uprading TestStand 2016 to TestStand 2016 SP1
    Installing TestStand 2016 SP1 or a deployment of TestStand 2016 SP1 upgrades TestStand 2016. You cannot install a service pack side-by-side with its main release. TestStand 2016 SP1 and TestStand 2016 use the same directories for the , , and directories.
    TestStand 2016 SP1 upgrades TestStand 2016 files according to the following guidelines:
    • Upgrades files in the \Shared and directories.
    • Upgrades files in the Global Assembly Cache (GAC).
    • Does not remove or upgrade configuration files in the or directories.
    • Does not remove new files you added to the directory.
    • Always upgrades files in the \AdapterSupport\LabVIEW, \Examples, and \Tutorial directories.
    • Upgrades files in the \AdapterSupport\CVI, \Components\Callbacks, \Components\Language\English, and \Components\Models directories only if you did not previously modify the files.
    • Never upgrades files in the \UserInterfaces directory. Refer to the \UserInterfaces directory for updated user interface files.
    Refer to the NI TestStand Help for more information about the locations of TestStand directories.
    Note  You can install TestStand 2016 SP1 on a computer on which you have not previously installed TestStand 2016. If you want to install TestStand 2016 SP1 immediately after installing TestStand 2016, you must first restart the computer when prompted after you finish installing TestStand 2016.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in TestStand 2016 SP1.
    Refer to the List of Bug Fixes in TestStand 2016 SP1 on the National Instruments website for a list of a subset of issues fixed in TestStand 2016 SP1. This is not an exhaustive list of issues fixed in TestStand 2016 SP1. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    Refer to the NI TestStand Help for information about TestStand 2016 SP1. You can access the NI TestStand Help in the following ways:
    • Select Help»NI TestStand Help in the sequence editor.
    • (Windows 8.1) Click the NI Launcher tile on the Start screen and select TestStand»TestStand Documentation»TestStand Help.
    • (Windows 7 or earlier) Select Start»All Programs»National Instruments»TestStand» TestStand Documentation»TestStand Help.
    TestStand includes a variety of example programs that you can use to help you learn key concepts or to serve as a starting point for applications you create. You can browse the examples in the following ways:
    • Open the Examples.tsw workspace file located in the \Examples directory.
    • Open an example sequence file from the subdirectories of the \Examples directory.
    Select Help»Find Examples to launch the NI TestStand Example Programs Help from the TestStand Sequence Editor.
    Refer to the Technical Support page at ni.com/support and search for TestStand to access the TestStand Support website, which contains online documentation, KnowledgeBase articles, tutorials, example code, discussion forums, and other resources.
    © 2000–2017 National Instruments. All rights reserved.
    For patents covering the NI products/technology, refer to the appropriate location: Help>;Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents.
    376434B-01
    GMT+8, 2025-7-15 21:23
