查看: 3386|回复: 0
[TestStand] NI TestStand 4.1.1 and Patch 美国国家仪器测试序列管理软件TS4.1.1及补丁
    3 小时前
  • 签到天数: 3808 天
    发表于 2020-2-29 17:32:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    TestStand是一款旨在帮助测试和验证工程师快速构建和部署自动化测试系统的应用软件。
    TestStand是一款可立即运行的测试管理软件,可帮助您快速开发自动化测试和验证系统。您可以使用TestStand来开发、执行和部署测试系统软件。还可以通过在TestStand中开发测试序列来扩展系统的功能,这些测试序列可集成使用任何编程语言编写的代码模块。TestStand还为报告生成、数据库记录以及与其他企业系统的连接提供了可扩展的插件。您可以使用易用的操作界面将测试系统部署到生产环境中。
    TestStand4.1.1
    链接: 请注册视觉论坛会员登录后购买附件下载查看 提取码: 请购买附件下载查看
    TestStand4.1.1patch132949补丁
    TestStand4.1Patch231477补丁
    TestStand4.1.1
    请购买附件下载查看
    请购买附件下载查看
    请购买附件下载查看
    TS4.1.1.txt (1.23 KB, 下载次数: 1, 售价: 10 圆)
    NI TestStand™ 4.1.1 Readme
    October 2008
    This document contains information about known issues and bugs fixed in NI TestStand 4.1.1. This maintenance release resolves some existing issues and bugs in TestStand 4.1. Refer to the What's New in TestStand topic in the NI TestStand Help for information about other changes since TestStand 4.0, including new features, compatibility and known issues, and bug fixes for TestStand 4.1 and previous versions of TestStand.
    TestStand 4.1.1 does not include the LabVIEW 8.6 Run-Time Engine. To include the LabVIEW 8.6 Run-Time Engine in a TestStand deployment installer, you must install LabVIEW 8.6 on the computer from which you create the deployment, and you must select the run-time component in the Drivers and Components dialog box of the TestStand Deployment Utility.
    To execute VIs on a remote LabVIEW 8.6 system, TestStand requires Remote Execution Support for NI TestStand for LabVIEW 8.6. Refer to the Remote Execution section of Appendix A, Using LabVIEW 8.x with TestStand, in the Using LabVIEW with TestStand manual for more information about installing remote execution support.
    TestStand includes the device driver software on a DVD. If you require device driver software on CDs, refer to the National Instruments Web site at ni.com/info and enter the info code drivercd.
    TestStand no longer includes a quick start guide. Refer to the NI TestStand Version 4.1 Release Notes for information about getting started with TestStand, such as system requirements, installation instructions, and descriptions of the TestStand licenses. If you do not activate a TestStand license, TestStand operates in evaluation mode.
    Upgrading TestStand 4.1 to TestStand 4.1.1
    You can install TestStand 4.1 and TestStand 4.1.1 on the same computer and run applications in both versions, or you can upgrade an existing TestStand 4.1 installation to TestStand 4.1.1. TestStand 4.1 and TestStand 4.1.1 use separate directories for the , , and directories.
    Complete the following steps to upgrade an existing TestStand 4.1 installation to TestStand 4.1.1.
    • Navigate to Add/Remove Programs on the Windows Control Panel, select National Instruments Software, and run the TestStand 4.1 uninstaller.
    • Install TestStand 4.1.1.
    • Move any custom components you added to the TestStand 4.1 directory to the TestStand 4.1.1 directory. Custom components include code templates, engine callbacks, icons, language files, models, run-time servers, step types, tools, and type palettes.
    • Move any configuration files you want to use from the TestStand 4.1 directory to the TestStand 4.1.1 directory.
    When you install TestStand 4.1 and TestStand 4.1.1 on the same computer, TestStand 4.1.1 cannot directly access the custom components in TestStand 4.1. You must copy custom components you added to the TestStand 4.1 directory to the TestStand 4.1.1 directory. You can copy the configuration files you want to use from the TestStand 4.1 directory to the TestStand 4.1.1 directory, or you can configure TestStand 4.1.1 to use the files in the TestStand 4.1 directory or in an alternate shared directory.
    Use the TestStand Version Selector to switch to TestStand 4.1, 4.1.1, or any other version installed on the computer before you launch a TestStand application. National Instruments does not support running applications that use two different versions of TestStand at the same time.
    Refer to the TestStand Directory Structure section of Chapter 8, Customizing and Configuring TestStand, of the NI TestStand Reference Manual for the location of the , , and directories.
    Installing TestStand 4.1.1 Deployment Software
    You can install deployments for TestStand 4.1 and TestStand 4.1.1 on the same computer. Use the TestStand Version Selector to select the active version of TestStand before you launch the deployed TestStand application. National Instruments does not support running applications that use two different versions of TestStand at the same time.
    TestStand 4.1 to TestStand 4.1.1 Bug Fixes
    TestStand 4.0.1 to TestStand 4.1 Bug Fixes
    Additional Information
    Use this Toggle Expansion button to expand or collapse all the sections. You must enable the Allow Blocked Content option in Internet Explorer to collapse each section. You must expand each section you want to print or search.
    Installation
    Windows Vista
    TestStand Sequence Editor
    TestStand User Interface (UI) Controls
    LabWindows/CVI
    Microsoft Visual Studio
    Miscellaneous
    The following items are changes from TestStand 4.1 to TestStand 4.1.1, unless otherwise specified.
    TestStand Engine
    LabWindows/CVI
    .NET Adapter
    Miscellaneous
    The following items are changes from TestStand 4.0.1 to TestStand 4.1, unless otherwise specified.
    TestStand Engine
    LabWindows/CVI
    .NET Adapter and Microsoft Visual Studio
    Miscellaneous
    Refer to the support section of the National Instruments Web site, located at http://www.ni.com/support/teststandsupp, for more information about TestStand.
    © 2008 National Instruments Corporation. All rights reserved.
    National Instruments, NI, ni.com, NI TestStand, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    Members of the National Instruments Alliance Partner Program are business entities independent from National Instruments and have no agency, partnership, or joint-venture relationship with National Instruments.
    For patents covering National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    GMT+8, 2026-2-25 13:26
