查看: 3736|回复: 0
[LV工具模块] LabVIEW 2016 MathScript Real-Time Module Win32ENG LV2016文本数学脚本实时模块MSRT2016 Win32位英文版下载
  • 签到天数: 3535 天
    发表于 2020-2-25 17:57:08 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW MathScript模块帮助您将自定义的文本数学代码部署到LabVIEW应用程序中和NI实时硬件上。自2016MSRT开始,WINDOWS系统LabVIEW增加64位版本MSRT。
    LabVIEW MathScript模块是LabVIEW编程环境的一个附加软件,包含750多种用于信号处理、分析和数学运算的内置文本函数。该模块还提供了一个交互式可编程界面。专为脚本编程而设计的MathScript交互式窗口提供命令行界面,方便用户下载、保存、设计和执行文本文件脚本。MathScript节点专为脚本部署而设计,作为LabVIEW的一项嵌入式功能,可将基于文本的变量与图形化LabVIEW代码的输入与输出连接起来。该模块适用于LabVIEW以及所有LabVIEW Real-Time硬件终端。
    百度网盘下载地址(EXE版和ZIP版内容一样,EXE版是NI当年发行版,ZIP版是NI后期重新压制版):
    EXE版:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    ZIP版:
    提取码: 请购买附件下载查看
    NI下载器下载:
    提取码: 请购买附件下载查看
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    MSRT2016.txt (1.31 KB, 下载次数: 7, 售价: 10 元)
    LabVIEW 2016 MathScript RT Module Readme
    June 2016
    This file contains important information about the LabVIEW 2016 MathScript RT Module, including system requirements, installation instructions, new features, known issues, and a partial list of bugs fixed.
    Limitations on Windows (64-bit), OS X, and Linux
    LabVIEW MathScript is a text-based environment you can use to write functions and scripts. You can process scripts using LabVIEW MathScript in the LabVIEW MathScript Window or a MathScript Node.
    Use the LabVIEW MathScript Window to edit and execute mathematical commands, create mathematical scripts, and view numerical and graphical representations of variables. Select Tools»MathScript Window to display this window.
    Use the MathScript Node to execute your LabVIEW MathScripts and other text-based scripts on the block diagram using the MathScript RT Module engine. You can save scripts that you create in the LabVIEW MathScript Window and load them in the MathScript Node and vice versa.
    In addition to the system requirements for the LabVIEW Development System, the MathScript RT Module has the following requirements:
    • LabVIEW 2016 Full or Professional Development System
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2016.
    The MathScript RT Module supports the following operating systems:
    WindowsWindows 10/8.11/7 SP12
    Windows Server 2012 R21
    Windows Server 2008 R2 SP12
    OS XOS X 10.10 or 10.11
    LinuxRed Hat Enterprise Linux Desktop + Workstation 6.5 or later
    openSUSE 13.2 or openSUSE LEAP 42.1
    Scientific Linux 6.5 or later
    CentOS 7
    The MathScript RT Module on Windows (64-bit), OS X, and Linux does not support the libraries class of MathScript RT Module functions.
    (Windows)
    You can install all of your LabVIEW products—including the MathScript RT Module—using the LabVIEW 2016 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    The LabVIEW Platform media does not include the MathScript RT Module (64-bit). To install the MathScript RT Module (64-bit), visit ni.com/info and enter the Info Code lvmsdownload to download the software. You also can request the LabVIEW 2016 (64-bit) media, which includes limited support for 64-bit modules and toolkits, from the NI website.
    (OS X)
    Complete the following steps to install the MathScript RT Module on OS X:
    • Insert the MathScript RT Module installation media and open NI LabVIEW 2016 MathScript RT Module 64-bit.pkg from the Mac OS X subdirectory.
    To uninstall the MathScript RT Module on OS X, manually delete the following files and directories:
    • /Applications/National Instruments/LabVIEW 2016/resource/mathscript.rsc
    • /Applications/National Instruments/LabVIEW 2016/examples/MathScript/
    • /Applications/National Instruments/LabVIEW 2016/vi.lib/imath/
    • /Applications/National Instruments/LabVIEW 2016/vi.lib/imathl/
    • /Library/Caches/National Instruments/InstCache/16.0/
    • ~/Documents/LabVIEW Data/MathScriptVIs/
    • /Library/Application Support/National Instruments/example finder/1.0/products/labview/16.0/exbins/english/lvexmscript.bin4
    (Linux)
    Complete the following steps to install the MathScript RT Module on Linux:
    • Insert the MathScript RT Module installation media. Use mount /mnt/cdrom to mount the media. On some systems, the media mounts automatically.
    • To change the current directory to the mounted media, enter the following command according to the Linux operating system on which you run the MathScript RT Module:
      cd /mnt/cdrom/Linux_32-bit or cd /mnt/cdrom/Linux_64-bit
      sh ./INSTALL
    To uninstall the MathScript RT Module on Linux, enter the following command:
    sh ./UNINSTALL
    LabVIEW 2016 MathScript RT Module Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, the MathScript RT Module drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. LabVIEW 2016 MathScript RT Module and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2016 MathScript RT Module to an unsupported OS. Additionally, after installing the LabVIEW 2016 MathScript RT Module, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The LabVIEW 2016 MathScript RT Module (64-bit) is available on Windows and OS X. NI no longer provides the 32-bit version of MathScript RT Module for OS X.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2016 MathScript RT Module.
    The following item is the ID and title of a subset of issues fixed in LabVIEW 2016 MathScript RT Module. This is not an exhaustive list of issues fixed in the current version of MathScript RT Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    566463The downsample() function truncates the imaginary portion of complex numbers
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help from LabVIEW, for information about the MathScript RT Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the MathScript RT Module are located in the labview\examples\MathScript directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    © 2009–2016 National Instruments. All rights reserved.
    375325B-01
    GMT+8, 2025-5-10 11:21
