查看: 3013|回复: 0
[LV工具模块] LabVIEW 2014 MathScript Real-Time Module Linux LV2014文本数学脚本实时模块MSRT2014 Linux英文版下载
    昨天 08:56
  • 签到天数: 3596 天
    连续签到: 4 天
    发表于 2020-2-25 17:37:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW MathScript模块帮助您将自定义的文本数学代码部署到LabVIEW应用程序中和NI实时硬件上。
    LabVIEW MathScript模块是LabVIEW编程环境的一个附加软件,包含750多种用于信号处理、分析和数学运算的内置文本函数。该模块还提供了一个交互式可编程界面。专为脚本编程而设计的MathScript交互式窗口提供命令行界面,方便用户下载、保存、设计和执行文本文件脚本。MathScript节点专为脚本部署而设计,作为LabVIEW的一项嵌入式功能,可将基于文本的变量与图形化LabVIEW代码的输入与输出连接起来。该模块适用于LabVIEW以及所有LabVIEW Real-Time硬件终端。
    链接:
    请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    MSRT2014Linux.txt (844 Bytes, 下载次数: 1, 售价: 10 元)
    LabVIEW 2014 MathScript RT Module Readme
    Version 14.0.0
    June 2014
    This file contains important information about the LabVIEW MathScript RT Module, including installation instructions, a partial list of bugs fixed for LabVIEW 2014 MathScript RT Module, and known issues.
    LabVIEW MathScript is a text-based environment you can use to write functions and scripts. You can process scripts using LabVIEW MathScript in the LabVIEW MathScript Window or a MathScript Node.
    Use the LabVIEW MathScript Window to edit and execute mathematical commands, create mathematical scripts, and view numerical and graphical representations of variables. Select Tools»MathScript Window to display this window.
    Use the MathScript Node to execute your LabVIEW MathScripts and other text-based scripts on the block diagram using the MathScript RT Module engine. You can save scripts that you create in the LabVIEW MathScript Window and load them in the MathScript Node and vice versa.
    In addition to the system requirements for the LabVIEW Development System, the MathScript RT Module has the following requirements:
    • LabVIEW 2014 Full or Professional Development System (32-bit)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2014.
    (Windows) MathScript RT Module runs on 32-bit Windows operating systems. You can install all of your LabVIEW products—including the MathScript RT Module—using the LabVIEW 2014 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    To request additional LabVIEW Platform media, refer to the National Instruments website.
    (OS X) MathScript RT Module runs on 32-bit OS X operating systems. Complete the following steps to install the MathScript RT Module on OS X.
    • Insert the MathScript RT Module installation media and open LabVIEW 2014 MathScript RT Module.pkg from the Mac OS X subdirectory.
    Delete the following files or directories on the computer to manually uninstall the MathScript RT Module on OS X:
    • /Applications/National Instruments/LabVIEW 2014/resource/mathscript.rsc
    • /Applications/National Instruments/LabVIEW 2014/examples/MathScript/
    • /Applications/National Instruments/LabVIEW 2014/vi.lib/imath/
    • /Applications/National Instruments/LabVIEW 2014/vi.lib/imathl/
    • /Library/Caches/National Instruments/InstCache/14.0/
    • ~/Documents/LabVIEW Data/MathScriptVIs/
    • /Library/Application Support/National Instruments/example finder/1.0/products/labview/14.0/exbins/english/lvexmscript.bin4
    (Linux) MathScript RT Module runs on 32-bit and 64-bit Linux operating systems. Complete the following steps to install the MathScript RT Module on Linux.
    • Insert the MathScript RT Module installation media. Use mount /mnt/cdrom to mount the media. On some systems, the media mounts automatically.
    • To change the current directory to the mounted media, enter the following command according to the Linux operating system on which you run the MathScript RT Module:
      cd /mnt/cdrom/Linux_32-bit or cd /mnt/cdrom/Linux_64-bit
      sh ./INSTALL
    To run a script that uninstalls the MathScript RT Module on Linux, enter the following command:
    sh ./UNINSTALL
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the MathScript RT Module.
    The following items are the IDs and titles of a subset of issues fixed in the MathScript RT Module. This is not an exhaustive list of issues fixed in the current version of the MathScript RT Module. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    442075Functions in MathScript Window return empty field names to the top level script
    Refer to the LabVIEW Help, accessible from Help»LabVIEW Help, for information about the MathScript RT Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the MathScript RT Module are located in the labview\examples\MathScript directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Finding All Programs
    NI LabVIEW MathScript RT Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW MathScript RT Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of MathScript RT Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2009–2014 National Instruments. All rights reserved.
    GMT+8, 2025-7-18 09:03
