查看: 2824|回复: 0
[LV工具模块] LabVIEW 2011 MathScript Real-Time Module MAC OS X LV2011文本数学脚本实时模块MSRT2011 MAC版下载
    昨天 08:56
  • 签到天数: 3596 天
    连续签到: 4 天
    发表于 2020-2-25 16:45:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW MathScript模块帮助您将自定义的文本数学代码部署到LabVIEW应用程序中和NI实时硬件上。
    LabVIEW MathScript模块是LabVIEW编程环境的一个附加软件,包含750多种用于信号处理、分析和数学运算的内置文本函数。该模块还提供了一个交互式可编程界面。专为脚本编程而设计的MathScript交互式窗口提供命令行界面,方便用户下载、保存、设计和执行文本文件脚本。MathScript节点专为脚本部署而设计,作为LabVIEW的一项嵌入式功能,可将基于文本的变量与图形化LabVIEW代码的输入与输出连接起来。该模块适用于LabVIEW以及所有LabVIEW Real-Time硬件终端。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址:
    请购买附件下载查看
    MSRT2011-MAC.txt (807 Bytes, 下载次数: 0, 售价: 10 元)
    LabVIEW 2011 MathScript RT Module Readme
    Version 11.0
    June 2011
    This file contains important information about the LabVIEW 2011 MathScript RT Module, including installation instructions, new features, and known issues.
       Mac OS X
       Linux
    LabVIEW MathScript is a text-based language you can use to write functions and scripts. You can process scripts using LabVIEW MathScript in the LabVIEW MathScript Window or a MathScript Node.
    Use the LabVIEW MathScript Window to edit and execute mathematical commands, create mathematical scripts, and view numerical and graphical representations of variables. Select Tools»MathScript Window to display this window.
    Use the MathScript Node to execute your LabVIEW MathScripts and other text-based scripts on the block diagram using the MathScript RT Module engine. You can save scripts that you create in the LabVIEW MathScript Window and load them in the MathScript Node and vice versa.
    In addition to the system requirements for the LabVIEW Development System, the MathScript RT Module has the following requirements:
    • LabVIEW 2011 Full or Professional Development System (32-bit)
    Refer to the LabVIEW Release Notes, which are available in your LabVIEW software kit or on the National Instruments Web site, for additional system requirements and supported operating systems for LabVIEW 2011.
    Complete the following steps to install the MathScript RT Module.
    You can install all of your LabVIEW products—including the MathScript RT Module—using the LabVIEW Platform DVDs. You can find installation instructions for the module along with activation instructions in the following locations:
    • LabVIEW Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments Web site.
    Mac OS X
    Complete the following steps to install the LabVIEW MathScript RT Module on Mac OS X.
    • Insert the LabVIEW MathScript RT Module installation CD and open LabVIEW MathScript 2011.mpkg from the Mac OS X subdirectory.
    Delete the following files or directories on the computer to manually uninstall the LabVIEW MathScript RT Module on Mac OS X:
    • /Applications/National Instruments/LabVIEW 2011/resource/mathscript.rsc
    • /Applications/National Instruments/LabVIEW 2011/examples/MathScript/
    • /Applications/National Instruments/LabVIEW 2011/vi.lib/imath/
    • /Applications/National Instruments/LabVIEW 2011/vi.lib/imathl/
    • /Documents/LabVIEW Data/InstCache/
    • /Library/Caches/National Instruments/InstCache/
    • /Documents/LabVIEW Data/MathScriptVIs/
    Linux
    Complete the following steps to install the LabVIEW MathScript RT Module on Linux.
    • Insert the LabVIEW MathScript RT Module installation CD. Use mount /mnt/cdrom to mount the CD. On some systems, the CD mounts automatically.
    • To change the current directory to the mounted CD, enter the following command:
      cd /mnt/cdrom/Linux
      sh ./INSTALL
      If you encounter the message bad interpreter: Permission denied, the CD might not have mounted with executable permissions. To correct this issue, enter the following command:
      /bin/sh ./INSTALL
    To run a script that uninstalls the MathScript RT Module on Linux, enter the following command:
    sh ./UNINSTALL
    Refer to the MathScript RT Module book on the Contents tab of the LabVIEW Help for more information about the MathScript RT Module.
    Refer to the labview\examples\MathScript directory for LabVIEW examples for the MathScript RT Module. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The LabVIEW 2011 MathScript RT Module introduces the following enhancements and changes.
    MathScript Support for Structures
    In the MathScript RT Module 2010 and earlier, you assign related data to separate variables. In the MathScript RT Module 2011, you define structures, or structs, to organize related data in the LabVIEW MathScript Window or a MathScript Node. You also can wire a cluster to a MathScript Node, where that cluster becomes a structure. Refer to the MathScript RT Module Organizing Related Data in Variables topic on the Contents tab of the LabVIEW Help for more information about structures.
    Documentation Addition for Structures
    If a MathScript Node contains a warning glyph, LabVIEW cannot determine the data types of any of the variables included in the node. To pass a variable out of the node, right-click the output terminal and select the variable's data type through the Choose Data Type option in the shortcut menu. However, you cannot select a data type for a structure if there is a warning glyph in the MathScript Node. LabVIEW does not allow structure as a possible data type choice, and the output terminal to the node breaks. To pass structures out of the MathScript Node, avoid functions or scripts that cause warning glyphs.
    New MathScript Functions
    The MathScript RT Module 2011 includes the following new MathScript functions. You can use these functions in the LabVIEW MathScript Window or a MathScript Node:
    MathScript ClassFunction
    basicdeg_to_rad, rad_to_deg
    communicationspadm, pam, qadm, qam
    filter designrcos
    filter implementationfilter_rcos
    ignoredpaintnow
    linalgebrareverse_vector
    matrixadd_noise, padarray
    plotscompass, eyediagram, is_hold, print, view_image
    statisticsdensity_kernel, kurtosis, moment_central, movavg, randint, randsample, skewness
    structis_field, is_struct, remove_field
    supportmenu
    Refer to MathScript RT Module»MathScript RT Module Functions book on the Contents tab of the LabVIEW Help for more information about built-in MathScript functions.
    MathScript Function Changes
    The MathScript RT Module 2011 includes the following changes to built-in MathScript functions:
    • The aoch and aowf functions contain a limits input that specifies the lowest and highest limits of a signal.
    • The iir_butterord, iir_cheby1ord, iir_cheby2ord, and iir_ellipticord functions contain a domain input that specifies whether the output filter is digital or analog.
    • The interpolate1d function accepts complex sample data.
    • The load function supports loading structures from files, and the save function supports saving structures to files.
    • The log2 function includes syntax for splitting input elements into binary mantissa and binary exponent.
    • The following functions include syntax that accepts a structure containing parameters for the ODE solver:
      • ode_adams
      • ode_bdf15
      • ode_bdf23
      • ode_radau5
      • ode_rk23
      • ode_rk45
      • ode_rosen
    • The odepset function includes syntax that returns a structure containing parameters for the ODE solver.
    • The following functions include enhancements to generating or manipulating 2D and 3D plots:
      • The contour, contour3d, contouris, and contours functions contain an x input and a y input that specify the surface you are plotting in relation to the x-plane or y-plane, respectively.
      • The legend function includes syntax for specifying the location of the legend.
      • The line function includes syntax for plotting lines on a 3D graph.
      • The plotyy function includes syntax for returning references to the plot area, the line with the left y-axis, and the line with the right y-axis.
      • The subplot function includes syntax for specifying the location of the subplot.
      • The text function includes syntax for plotting text on a 3D graph.
    • The powerof2 function includes syntax for specifying two inputs.
    • The reshapemx function includes syntax that allows you to specify the size of the array as an input variable.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the MathScript RT Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2011 MathScript RT Module. This is not an exhaustive list of issues fixed in the current version of the MathScript RT Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    173387After removing functions that cause warning glyphs from user-defined functions, the VI looks broken
    176681Cannot set a breakpoint on the last line of a script
    193443Deployment to RT fails when the matrix data type is wired to a MathScript Node
    210391DAQ MathScript aoch function creates wrong task type
    229239MathScript cache files shared on computers with multiple users
    234573Auto-detect output does not return strings data type
    235596Mathscript RT Module for Mac OS X will not install on LabVIEW 2009 Evaluation
    244950The Optional Plane in shortcut menu does not work in MathScript plot window
    245553MathScript cannot differentiate n and h inputs for contour when there is reduced performance
    279908Subplot window cannot be closed
    Important Information
    © 2011 National Instruments Corporation. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in the MathScript RT Module, refer to the Copyright topic of the LabVIEW Help.
    GMT+8, 2025-7-18 08:57
