查看: 2901|回复: 0
[LV工具模块] LabVIEW 2010 MathScript Real-Time Module Win32ENG LV2010文本数学脚本实时模块MSRT2010 Win32位英文版下载
    4 小时前
  • 签到天数: 3544 天
    连续签到: 14 天
    发表于 2020-2-25 14:58:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW MathScript模块帮助您将自定义的文本数学代码部署到LabVIEW应用程序中和NI实时硬件上。
    LabVIEW MathScript模块是LabVIEW编程环境的一个附加软件,包含750多种用于信号处理、分析和数学运算的内置文本函数。该模块还提供了一个交互式可编程界面。专为脚本编程而设计的MathScript交互式窗口提供命令行界面,方便用户下载、保存、设计和执行文本文件脚本。MathScript节点专为脚本部署而设计,作为LabVIEW的一项嵌入式功能,可将基于文本的变量与图形化LabVIEW代码的输入与输出连接起来。该模块适用于LabVIEW以及所有LabVIEW Real-Time硬件终端。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址:
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    MSRT2010.txt (1.09 KB, 下载次数: 0, 售价: 10 元)
    LabVIEW 2010 MathScript RT Module Readme
    Version 10.0
    June 2010
    This file contains important last-minute information about the LabVIEW 2010 MathScript RT Module, including installation instructions, new features, and known issues.
       Mac OS X
       Linux
    Upgrading from the LabVIEW 2009 MathScript RT Module
    LabVIEW MathScript is a text-based language you can use to write functions and scripts. You can process scripts using LabVIEW MathScript in the LabVIEW MathScript Window or a MathScript Node.
    Use the LabVIEW MathScript Window to edit and execute mathematical commands, create mathematical scripts, and view numerical and graphical representations of variables. Select Tools»MathScript Window to display this window.
    Use the MathScript Node to execute your LabVIEW MathScripts and other text-based scripts on the block diagram using the MathScript RT Module engine. You can save scripts that you create in the LabVIEW MathScript Window and load them in the MathScript Node and vice versa.
    In addition to the system requirements for the LabVIEW Development System, the MathScript RT Module has the following requirements:
    • LabVIEW 2010 Full or Professional Development System
    Refer to the LabVIEW Release Notes, which are available in your LabVIEW software kit or on the National Instruments Web site, for additional system requirements and supported operating systems for LabVIEW 2010.
    (LabVIEW 64-bit) The MathScript RT Module is not supported in LabVIEW (64-bit).
    Complete the following steps to install the MathScript RT Module.
    You can install all of your LabVIEW products—including the MathScript RT Module—using the LabVIEW Platform DVDs. You can find installation instructions for the module along with activation instructions in the following locations:
    • LabVIEW Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments Web site.
    Mac OS X
    Complete the following steps to install the LabVIEW MathScript RT Module on Mac OS X.
    • Insert the LabVIEW MathScript RT Module installation CD and open LabVIEW MathScript 2010.mpkg from the Mac OS X subdirectory.
    Delete the following files or directories on the computer to manually uninstall the LabVIEW MathScript RT Module on Mac OS X:
    • /Applications/National Instruments/LabVIEW 2010/resource/mathscript.rsc
    • /Applications/National Instruments/LabVIEW 2010/examples/MathScript/
    • /Applications/National Instruments/LabVIEW 2010/vi.lib/imath/
    • /Documents/LabVIEW Data/InstCache/
    • /Documents/LabVIEW Data/MathScriptVIs/
    Linux
    Complete the following steps to install the LabVIEW MathScript RT Module on Linux.
    • Insert the LabVIEW MathScript RT Module installation CD. Use mount /mnt/cdrom to mount the CD. On some systems, the CD mounts automatically.
    • To change the current directory to the mounted CD, enter the following command:
      cd /mnt/cdrom/Linux
      sh ./INSTALL
      If you encounter the message bad interpreter: Permission denied, the CD might not have mounted with executable permissions. To correct this issue, enter the following command:
      /bin/sh ./INSTALL
    To run a script that uninstalls the MathScript RT Module on Linux, enter the following command:
    sh ./UNINSTALL
    The following sections describe issues to be aware of when you upgrade to the MathScript RT Module 2010.
    Opening Applications Saved in LabVIEW 2009
    Due to enhancements to the LabVIEW compiler, LabVIEW 2010 requires more memory than previous LabVIEW versions when compiling VIs, particularly large VI applications. In LabVIEW 2010, when you open the top-level VI of a large application saved in LabVIEW 2009 or earlier that calls many .m files, LabVIEW might run out of memory and exit. (Windows 64-bit) If you encounter this situation, National Instruments recommends you open the VI on a computer with at least 4 GB of memory. (Windows 32-bit) Refer to the Fundamentals»Managing Performance and Memory»How-To»Extending Virtual Memory Usage for 32-bit Windows topic on the Contents tab of the LabVIEW Help for information about enabling LabVIEW to access more virtual memory.
    Disallowing Sharing of MathScript Cache Files on Computers with Multiple Users
    The MathScript RT Module 2010 installs VIs that improve the performance of the module. These VIs install to a public directory that is writable for all users of the computer so that LabVIEW can compile the VIs. However, if you want to prevent multiple users from sharing this directory, you can complete the following steps to make LabVIEW use a local directory for each user rather than the public directory.
    • Delete the InstCache directory from the <;Public Cache>\ directory. (Windows, Mac OS X) The directory is located at <;Public Cache>\National Instruments. (Linux) The directory is located at <;Public Cache>\natinst.
      Note: Use the Get System Directory VI, available on the File Constants palette in LabVIEW, to return the location of the <;Public Cache> directory.
    • Create an empty file named UseLocalInstCacheForAllUsers.ini in the directory.
    • Make the directory read-only. Ensure that non-administrator users have only read access to the directory.
    This procedure causes LabVIEW to generate VIs in the \LabVIEW Data\InstCache directory instead of the public directory. You can use the Get System Directory VI to return the location of the directory.
    Refer to the MathScript RT Module book on the Contents tab of the LabVIEW Help for more information about the MathScript RT Module.
    Refer to the labview\examples\MathScript directory for LabVIEW examples for the MathScript RT Module. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The LabVIEW 2010 MathScript RT Module introduces the following enhancements and changes.
    LabVIEW MathScript Window Enhancements
    The LabVIEW MathScript Window includes the following enhancements:
    • (Windows) The Script Editor in the LabVIEW MathScript Window includes improved script-editing features, such as syntax highlighting, line numbers, a dialog box for finding and replacing text, and bookmarks with which you can mark lines of your script.
    • The menu items in the Script Editor are reorganized to include new options. (Windows) The Edit menu in the Script Editor also includes items for finding and replacing text, navigating between bookmarks, and so on.
    • On the Variables page, the Dimension column is renamed to Data. The Data column in the LabVIEW MathScript Window displays the value of the corresponding variable, or, if the value is too long to display, LabVIEW displays the dimension of the variable. This feature also exists in the LabVIEW MathScript Probe window.
    Adding Output Terminals to MathScript Nodes
    In the MathScript RT Module 2009 and earlier, after you add an output terminal to a MathScript Node you must manually type the variable name with which you want to configure the output. In the MathScript RT Module 2010, after you enter your script in a MathScript Node, you can right-click the right side of the MathScript Node frame, move the cursor over the Add Output item in the shortcut menu, and select the variable for which you want to create an output from a list of variables detected in your script.
    New MathScript Functions
    The MathScript RT Module 2010 includes the following new MathScript functions. You can use these functions in the LabVIEW MathScript Window or the MathScript Node:
    • The support class contains the rgb_to_grayscale function.
    • The transforms class contains the realifft and realifft2d functions.
    Refer to MathScript RT Module»MathScript RT Module Functions book on the Contents tab of the LabVIEW Help for more information about built-in MathScript functions.
    Performance Improvements
    The LabVIEW MathScript Window executes code with performance similar to the MathScript Node due to performance improvements.
    The LabVIEW 2010 MathScript RT Module introduces the following behavior changes to LabVIEW MathScript:
    • In the MathScript RT Module 2009, the default data type of MathScript Node input terminals you create is void. In the MathScript RT Module 2010, the default data type of input terminals you create is double-precision, floating-point numeric.
    • In previous versions, the LabVIEW MathScript Probe window does not display variables you define but do not reuse in your script. In the MathScript RT Module 2010, the LabVIEW MathScript Probe window displays all variables you define in your script.
    • When you specify indexes of matrix elements in previous versions, LabVIEW ignores indexes for any dimensions higher than 2. For example, when indexing an element of matrix a, LabVIEW treats a(1, 2, 3, 4); the same as a(1, 2); and does not return an error or warning. In the MathScript RT Module 2010, LabVIEW returns an error when you specify a value for a dimension greater than 2.
    MathScript Function Changes
    The MathScript RT Module 2010 includes the following changes to built-in MathScript functions:
    • The bin_to_dec function does not accept letters or digits other than 0, 1, or white space.
    • In the MathScript RT Module 2009 SP1, National Instruments recommends you use the fft and sort functions in a time-critical VI or timed structure only if you specify a vector for the a input. In the MathScript RT Module 2010, you also can use these functions in time-critical code with matrices as inputs.
    • In the MathScript RT Module 2010, the format function modifies the display format of numbers differently than in previous versions, as described in the following table.
      SyntaxMathScript RT Module 2009 FormatMathScript RT Module 2010
      FormatExample: 100 * pi =
      format shortScaled fixed-point format with 5 digitsScaled fixed-point format with 4 digits after the decimal point314.1593
      format short eFloating-point format with 5 digitsFloating-point format with 4 digits after the decimal point3.1416e+002
      format longScaled fixed-point format with 15 digitsScaled fixed-point format with 15 digits after the decimal point314.159265358979326
      format long eFloating-point format with 15 digitsFloating-point format with 15 digits after the decimal point3.141592653589793e+002
    • The fread and fwrite functions include a byte input you can use to specify the byte order, or endian form, to use when reading and writing data, respectively.
    • In the MathScript RT Module 2009, you can specify attributes for only 2D plots. In the MathScript RT Module 2010, you can specify attributes for 3D plots you generate with the line and plot3d functions.
    • The b input of the linearsolve function accepts matrices.
    • The a input of the lu function accepts non-square matrices.
    • The median and meshgrid2d functions are suitable for use in deterministic applications when used according to certain guidelines.
      Refer to the MathScript RT Module»Guidelines for Using LabVIEW MathScript in Real-Time Applications book on the Contents tab of the LabVIEW Help for more information about using MathScript with RT targets.
    • The sort function includes an optional order input you can use to sort the input elements in ascending or descending order.
    • The std and var functions include a d input you can use to specify the dimension of x across which to calculate the standard deviation or variance, respectively, if x is a matrix.
    • The str_to_double and str_to_num functions are no longer supported on RT targets.
    • In the MathScript RT Module 2009, when you use the following functions to generate multiple plots, you must specify attributes for all plots or no plots. In the MathScript RT Module 2010, you can specify attributes for only the last plot, and LabVIEW uses the default attributes for previous plots.
      • loglog
      • plot
      • semilog_x
      • semilog_y
    • Inputs that accept signals for the following functions now accept complex values. For example, the x and y inputs of the crosspsd function accept complex values in addition to real values.
      • buffermx
      • coherence_ms
      • corrmx
      • crosspsd
      • psd_burg
      • psd_covar
      • psd_mcovar
      • psd_periodogram
      • psd_welch
      • psd_yule
      • pspec_eign
      • pspec_music
      • root_eign
      • root_music
      • spectrogram
      • tf_estimateplot
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the MathScript RT Module.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2010 MathScript RT Module. This is not an exhaustive list of issues fixed in the current version of the MathScript RT Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    221496The index output of the 'sortrows' function should be one-based, not zero-based.
    213325Loading 2D plots should not take as long as loading 3D plots
    212439'any', 'all', 'and', 'or', and 'xor' functions unnecessarily upcast Boolean inputs
    210616'global' function should accept variable input strings
    208621Saved .m filename persists in the MathScript Script Editor even after creating a new script
    208615Documentation for some MathScript function not supported in the Run-Time Engine is confusing
    208395'sort' function should allow sorting elements in either ascending and descending order
    206150Graph legends and palettes cannot be used in MathScript plot windows
    205801'load' function fails to open read-only .mat files
    205136Legacy names need explanation in MathScript function documentation
    204405MathScript should return errors for unsupported ND array indexing
    203852Changing a .m file while in use by LabVIEW produces empty code
    202693Documentation about RT support of 'load' function should list supported syntax a = load(file)
    202249Changing a .m file from a script to a function does not recompile the calling script
    201119Context help for rt functions is missing
    200816MathScript Window and MathScript probe's "Swap X-Y" option does not work
    200735Saving a pie plot as BMP does not include percentage number labels
    200723Plot generated by 'bar3' function does not have first bar outlined with black lines
    199534Growing an empty array in a loop does not work
    197580Opening a MathScript VI created on a different machine results in a search dialog for MCStatic_ VIs
    196706VIs that call certain functions load with 'Failed to compile' error
    195487Indexing a constant variable, such as 'i' in a = i(1,:) using a colon does not work if code contains a warning glyph
    194745'mod' and 'rem' functions with integer inputs should not upcast the values
    194665MathScript Nodes return automatic error handling dialog box even if 'error out' cluster on node is wired
    194138'psd_welch' and other functions in the spectral analysis class do not accept complex input signals
    194037MathScript probe should show values of variables rather than dimension, display 'String' view for strings by default, and allow resizing much smaller
    193324MathScript search path is corrupted in unsaved LabVIEW projects
    191788'interpolate1d' function output dimension behavior change when upgrading from 8.6 to 2009
    190836VI with a MathScript Node that calls .m files can sometimes be broken even if there is no error
    189608'median' function should return a vector when possible instead of an array
    187850Documentation correction: 'bin_to_dec' function does not consider letters or digits other than 0 and 1 in 'a' to be zeros in 2009 release
    187299Documentation addition: Behavior of numeric conversion functions 'int8', 'int16', etc. when input is of complex data type
    186041Script in MathScript Node appears to execute out of order with execution highlighting on
    185013Execution highlighting in MathScript Node appears to skip lines
    184237MathScript Node returns an error code but no error source description when a plot object is invalid
    183304Creating a new subplot removes the title of the first subplot
    183244Using unwired user-defined function inputs with short circuit operators can cause errors
    181131The title & X-Y labels are not correct for plot from function 'crosspsd' when no output arguments are specified
    180281Documentation correction: 'repeatmx' function help refers to 'c' as output when 'd' is the output
    177781"An error occurred in a SubVI call" path error not descriptive
    176786MathScript Node inputs with void data types cause brief unresponsiveness
    176211Attributes don't work unless specified for all plots
    176135The 'resample' function does not return a "memory full" error
    175691Changing the contents of a .m file while calling VI is running causes crash
    175388A conditionally defined variable from a user-defined function should not break VI if it will never execute
    174790Using the 'cd' in a MathScript Node displays a warning glyph even if no input arguments are specified
    174206Return meaningful errors for 'sound', 'soundscaled', 'wavplay', and 'wavrecord' functions
    173756Calling 'path' function with an integer input, such as 'path(1)', gives unhelpful error and clears path list in MathScript Window
    172387fwrite_xls and fread_xls needs to give meaningful error if computer does not have appropriate software installed
    171509'updatechol' function returns less accurate results for CDB downdated case
    171353'nchoosek' function should not accept inputs of Control Design and Simulation Module data types
    171022Tools>>Option>>MathScript page in French version of LabVIEW has overlapping text
    168379When plotting multiple vectors or matrices, cannot specify attributes for just one vector or matrix
    164712Documentation correction: List of functions not supported on RT does not denote functions installed with Control Design and Simulation Module
    158848Dragging a variable from 'Local' to 'Global' section in the MathScript Window 'Variables' list doesn't work
    158061Returning help for some legacy function names fails to return help for corresponding function name
    155368Variables you define but do not use later in a script don't appear in the MathScript probe
    154867Returning help for some legacy function names fails to return help for corresponding function name
    153539Output on MathScript Node with void data types gives confusing error message
    151999Indexing a variable using Boolean indices does not work as expected in the MathScript Window
    148323MathScript 'help' function should map incomplete legacy names to new names
    147028German string in LV German (Vista) cut off in Tools>>Options>>MathScript dialog box
    144739Tools>>Option>>MathScript page in German version of LabVIEW has overlapping text
    142972Replace indexing needs to support multiple assignments
    137913'std' and 'var' functions should allow specifying the dimension of an input matrix across which to calculate the standard deviation/variance
    Important Information
    © 2009–2010 National Instruments Corporation. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in the MathScript RT Module, refer to the Copyright topic of the LabVIEW Help.
    GMT+8, 2025-5-19 12:55
