查看: 5568|回复: 1
[LV工具模块] LabVIEW 2018 Datalogging and Supervisory Control Module Run-Time System Win32Eng LV2018数据记录和监控模块运行时系统2018DSC-RTS
    昨天 08:12
  • 签到天数: 3787 天
    连续签到: 38 天
    发表于 2020-2-23 18:41:53 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    DSC2018RTS.txt (712 Bytes, 下载次数: 17, 售价: 10 圆)
    LabVIEW 2018 Datalogging and Supervisory Control Module Run-Time System Readme
    March 2018
    This file contains important information about the LabVIEW Datalogging and Supervisory Control (DSC) Module Run-Time System, including installation instructions, known issues, and a partial list of bugs fixed for the LabVIEW 2018 DSC Module Run-Time System.
    The LabVIEW DSC Module Run-Time System allows you to run applications built with LabVIEW, the DSC Module, and the LabVIEW Application Builder on a computer without the DSC Module installed. The DSC Module Run-Time System contains components that enable the DSC Module features in the built applications.
    The DSC Module Run-Time System has the following requirements:
    • Depending on the components you choose to install, the computer must have the following amount of free disk space:
      • 1.0 GB free disk space if you install all components of the DSC Module Run-Time System except the Shared Variable Logging Support component
      • 2.5 GB free disk space if you install all components of the DSC Module Run-Time System
    • At least 512 MB of RAM
    The DSC Module supports the following operating systems:
    • Windows 10 (version 1709)/8.11/7 SP12
    Note  In 2016 the LabVIEW DSC Module Run-Time System dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. The LabVIEW 2018 DSC Module Run-Time System will not install or run on an unsupported OS. You cannot deploy or distribute applications that use the LabVIEW 2018 DSC Module Run-Time System to an unsupported OS. Additionally, after installing the LabVIEW 2018 DSC Module Run-Time System, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Complete the following steps to install the DSC Module Run-Time System:
    • Log in to the computer as an administrator or as a user with administrative privileges.
    • Install the DSC Module Run-Time System from the LabVIEW 2018 DSC Module Run-Time System installation media.
    • Restart the computer.
    Note  The NI OPC Servers application installed with the DSC Module Run-Time System provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in the DSC Module Run-Time Engine.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2018 DSC Module Run-Time Engine. This is not an exhaustive list of issues fixed in the current version of the DSC Module Run-Time Engine. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    652654LabVIEW crashes when calling the Undeploy Libraries VI on an array of uninitialized path constants.
    © 2000–2018 National Instruments. All rights reserved.
    375311D-01
  • 签到天数: 2 天
    发表于 2020-12-11 20:43:44 | 显示全部楼层 来自:陕西省西安市 电信
    GMT+8, 2026-1-30 06:55
