查看: 3609|回复: 0
[LV工具模块] LabVIEW 2011 Datalogging and Supervisory Control Module Win32Eng LV2011数据记录和监控模块DSC2011
    昨天 21:26
  • 签到天数: 3790 天
    连续签到: 41 天
    发表于 2020-2-23 14:32:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    DSC2011.txt (780 Bytes, 下载次数: 15, 售价: 10 圆)
    LabVIEW 2011 Datalogging and Supervisory Control Module Readme
    Version 11.0.0
    June 2011
    This file contains important information about the LabVIEW 2011 Datalogging and Supervisory Control (DSC) Module, including installation issues and bug fixes. Refer to the LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes, which are available in your DSC Module software kit, for upgrade and compatibility issues of the DSC Module and a complete list of the new features and changes from the DSC Module 2010.
    Notice Regarding Microsoft Silverlight Installation and Redistribution
    Licensing
    The DSC Module supports the following operating systems:
    • Windows XP Service Pack 2 or later
    The DSC Module does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions. Refer to the LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes for a complete list of system requirements.
    Note: Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the Info Code PAESupport.
    You can install all of your LabVIEW products—including the DSC Module—using the LabVIEW 2011 Platform DVDs. You can find installation instructions for the DSC Module along with activation instructions in the following locations:
    • LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes, which are available in your DSC Module software kit.
    • LabVIEW 2011 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2011 Platform DVDs, refer to the National Instruments Web site.
    Using Microsoft Silverlight
    Licensing
    The DSC Module relies on licensing activation. You have a temporary license for a 30-day evaluation period. If you do not activate the DSC Module license, the DSC Module operates in evaluation mode, by default, for a 30-day evaluation period. When the evaluation period expires, you cannot use the DSC features, and LabVIEW hides the DSC VIs and user interfaces. You must activate a valid DSC Module license to continue using the DSC Module.
    Refer to the LabVIEW Release Notes for more information about licensing in LabVIEW.
    The NI OPC Servers application installed with the DSC Module provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the DSC Module.
    The following items are the IDs and titles of a subset of issues fixed in the DSC Module. If you have a bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the DSC Module.
    Bug IDFixed Issue
    93918User defined alarm that starts with "alarm" does not work.
    178809The hypertrend sometimes draws backwards horizontal lines while in live mode.
    195296HyperTrend Max and Min Cursors do not return correct Max or Min values.
    251949DataSet Marking I/O Server does not log correctly if in a nested lvlib.
    258747Historical Data Viewer cannot select a time in the future.
    280682Historical Data Viewer LV 2010 - Export/Import settings to XML file doesn't support localized OS.
    283892Error -1967362038 returns from Search Variable Container when accessing a process with an I/O Server.
    Important Information
    © 2011 National Instruments Corporation. All rights reserved.
    In regards to components that use Citadel 5, the following copyright applies. Copyright © 1994 Hewlett-Packard Company. Permission to use, copy, modify, distribute and sell this software and its documentation for any purpose is hereby granted without fee, provided that the above copyright notice appears in all copies and that both that copyright notice and this permission notice appear in supporting documentation. Hewlett-Packard Company makes no representations about the suitability of this software for any purpose. It is provided "as is" without express or implied warranty.
    GMT+8, 2026-2-2 05:01
