查看: 3521|回复: 0
[LV工具模块] LabVIEW 2010 Datalogging and Supervisory Control Module Win32Eng LV2010数据记录和监控模块DSC2010
    昨天 07:57
  • 签到天数: 3556 天
    发表于 2020-2-23 14:29:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    DSC2010.txt (872 Bytes, 下载次数: 13, 售价: 10 元)
    LabVIEW 2010 Datalogging and Supervisory Control Module Readme
    Version 10.0.0
    June 2010
    This file contains important information about the LabVIEW 2010 Datalogging and Supervisory Control (DSC) Module, including installation issues and changes from the DSC Module 2009 SP1. Refer to the LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes, which are available in your DSC Module software kit, for upgrade and compatibility issues of the DSC Module.
    DSC Module 2010 Features and Changes
    Additions to the DSC Module Help
    The DSC Module supports the following operating systems:
    • Windows XP Service Pack 2 or later
    The DSC Module does not support Windows NT/Me/2000/98/95 or the Windows Server non-R2 editions. Refer to the LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes for a complete list of system requirements.
    Note: Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might have to take, visit ni.com/info and enter the Info Code PAESupport.
    You can install all of your LabVIEW products—including the DSC Module—using the LabVIEW 2010 Platform DVDs. You can find installation instructions for the DSC Module along with activation instructions in the following locations:
    • LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes, which are available in your DSC Module software kit.
    • LabVIEW 2010 Readme for Windows, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2010 Platform DVDs, refer to the National Instruments Web site.
    This version includes the following enhancements:
    • Navigation controls—The Navigation Controls Manager dialog box includes the Align and Customize pages. You can use the Align page to align navigation controls and front panel windows of VIs in a project library. You can use the Customize page to select a control file to use as a navigation control. You can set the string text on the Previous Button, Next Button, and Jump Button programmatically by using the Button Text property.
    • Logging Data to Relational Databases—Use the Relational Database page on the DSC Settings: Database page of the Project Library Properties dialog box to enable logging to a supported relational database. You can log shared variable data, alarms, and events to the following supported relational databases: Microsoft Access, MySQL, Oracle, PostgreSQL, and SQL Server.
    • DSC Module Web Services—The DSC Module includes the following built-in LabVIEW Web services:
      • Alarms & Events Web service—Web service for sending and receiving alarm and event information.
      • Citadel Web service—Web service for querying historical data in the Citadel database.
    • DSC Module Support for Touch Panel devices—The DSC Module supports Touch Panel devices running Windows XP Embedded. You use a LabVIEW project to define a Touch Panel target for which you can build, deploy, and run a Touch Panel application on a Touch Panel device. You can create a project by using the Touch Panel Project Wizard.
    • Historical Data Viewer—The Historical Data Viewer in the Measurement & Automation Explorer (MAX) contains the Import Settings and Export Settings buttons in the Trace Properties view and Display view of the trace view. Use the Import Settings button to import display configuration settings from a file to a trace view. Use the Export Settings button to export display configuration settings to a file from a trace view. The display configuration settings import from and export to an XML file.
    • NI Distributed System Manager—In the NI Distributed System Manager, you can synchronize the time of computers on the network with a central time server. Select View»Configure Time Servers to display the Shared Variable Engine Time Server Configuration dialog box, which you use to configure time synchronization.
    • Data Type Support for Shared Variable Properties—The DSC Module supports logging deadband and resolution values and updating deadband settings for shared variables with a data type of Single. The DSC Module also supports setting the initial value for shared variables with a data type of Single or integer data type.
    This version includes the following new VIs:
    • Write Filters VIs for Touch Panel Devices—Use the Enhanced Write Filter VIs to protect volumes and redirect writes to a disk location or to the RAM. Use the File-Based Write Filter VIs to protect files and folders in a volume and redirect writes to the memory cache. The Enhanced Write Filter VIs and File-Based Write Filter VIs are located on the Write Filters palette. The Write Filters VIs are located on the Touch Panel palette. The Touch Panel VIs are available for Touch Panel devices running Windows XP Embedded.
    • EPICS VIs—Use the EPICS VIs to create, configure, and delete EPICS Server I/O servers on the Windows platform or real-time target. The EPICS VIs are located on the Data Communication palette.
    • Get Computer List—Use the Get Computer List VI to return an array of computers on the local network.
    • Get Database List—Use the Get Database List VI to list all Citadel databases under a computer.
    This version includes the following changed VIs:
    • Configure Initial Value—The data type (deprecated) input replaces the data type input. This VI automatically detects the data type of the shared variable you specify in the variable reference in input.
    • Configure Logging—The data type (deprecated) input replaces the data type input. This VI automatically detects the data type of the shared variable you specify in the variable reference in input.
    • Configure Scaling—The data type (deprecated) input replaces the data type input. This VI automatically detects the data type of the shared variable you specify in the variable reference in input.
    • Data Set Internal ID String to ID Cluster—The internal ID raw data input replaces the internal_ID raw data input.
    • Open Trace—Use the lifespan in days input to specify the number of days that LabVIEW stores a trace in the Citadel database.
    • Read Events—Use the shared variable input to specify a list of shared variables for which you want to read event information.
    • Write Traces to Spreadsheet—Use the formatValue variable, which you can apply to the row format input, to specify the export format of a numeric variable.
    • Write Traces to Spreadsheet File—Use the formatValue variable, which you can apply to the row format input, to specify the export format of a numeric variable.
    This version includes the following new SharedVariable IO properties:
    • Initial Value:Int8
    • Initial Value:Int16
    • Initial Value:Int32
    • Initial Value:Int64
    • Initial Value:Single
    • Initial Value:UInt8
    • Initial Value:UInt16
    • Initial Value:UInt32
    • Initial Value:UInt64
    Refer to the LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes for a complete list of the new features and changes.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the DSC Module.
    This section corrects the information in the Accessing the Alarms & Events Web Service topic of the LabVIEW Help. The LabVIEW Help is accessible by selecting Help»LabVIEW Help from the pull-down menu in LabVIEW.
    You can acknowledge alarms and events by using the nialarm Web service. Refer to the following table to specify the URL pattern, which consists of the Web method and tag URL, and input parameters of the URL. An asterisk (*) appears next to required parameters.
    DescriptionURL patternHTTP methodInput parameters
    Acknowledges alarms by alarm.alarmsPOST
    Post data:
    AlarmUrl=ALARMURL*
    ackUser=ACKUSER
    comment=TEXT
    None
    Acknowledges alarms by alarm area.alarmsPOST
    Post data:
    alarmArea=AREATEXT*
    ackUser=ACKUSER
    comment=TEXT
    None
    Acknowledges alarms by shared variable.alarms/POST
    Post data:
    ackUser=ACKUSER
    comment=TEXT
    host=HOSTNAME (localhost)
    Acknowledges events by shared variable.events/POST
    Post data:
    N/A
    Acknowledges alarms and events by shared variable.all/POST
    Post data:
    ackUser=ACKUSER
    comment=TEXT
    The following table shows possible example URLs for the previous Web methods.
    Web methodExample URLDescription
    alarmshttp://localhost:3580/nialarm/alarms
    HTTP method: POST
    Post data:AlarmUrl=\\server1\library1\variable1.Alarms.HiHi&AlarmUrl=\\server2\library2\variable2.Alarms.Hi&ackUser=operator1
    Invokes the alarms Web method to acknowledge alarms specified by the AlarmUrl tag in the post data. You can specify optional parameters, such as ackUserand comment, by delimiting these parameters with an ampersand (&). You can specify multiple alarms you want to acknowledge by delimiting them with an ampersand.
    eventshttp://localhost:3580/nialarm/events/library1/variable1
    HTTP method: POST
    Post data: N/A
    Invokes the events Web method to acknowledge the events associated with the shared variable at \\localhost\library1\variable1.
    allhttp://localhost:3580/nialarm/all/library1/variable2
    HTTP method: POST
    Post data: ackUser=operator1&comment=test
    Invokes the all Web method to acknowledge the alarms and events associated with the shared variable at \\localhost\library1\variable2. This example also specifies that the alarms and events are acknowledged by the user operator1 with a comment test.
    The following items are the IDs and titles of a subset of issues fixed in the DSC Module. If you have a bug ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the DSC Module.
    Bug IDFixed Issue
    98000Alarm behaves differently if you disable alarm via Property Node or by Network Binding to its Enable property
    107248Remote ghost point sync will sometimes fail
    132994Setting an alarm level for single variables not possible in Multiple Variable Editor, but can be set in Shared Variables Property page
    147498Unable to browse Lookout OPC Server
    158511Value Change Event Registration on Remotely Deployed SVs Produces Runtime Error
    169880Tag Server Crashes on multicore systems with large number of tags
    177723In Multiple Variable Editor, all variables are listed directly under "*.lvproj" when you configure the "Network Published: Project Path"
    189616Error 1003 (Unable to load configuration) in Distributed System Manager with Custom I/O Server
    192888Log Alarms & Events property affects other shared variables
    193035Reading some Citadel database will cause application crash
    195294Left-clicking empty column in HyperTrend Cursors window crashes Distributed System Manager and Measurement & Automation Explorer
    197182[Modbus Master/Slave] 4-byte IO item like F300001-F365534 is un-recognizable on VxWorks due to ending issues
    197859Cannot import/export Historical Data Viewer views
    198019Acknowledge Alarms VI can't acknowledge events
    199905Alias address is wrong when adding a range of modbus digital arrays
    201089DSC Module causes error 1055 while building Application under LabVIEW 2009
    212581OPC Bound Variables URL only includes Channel when lvlib is included in an EXE build
    Important Information
    © 2010 National Instruments Corporation. All rights reserved.
    In regards to components that use Citadel 5, the following copyright applies. Copyright © 1994 Hewlett-Packard Company. Permission to use, copy, modify, distribute and sell this software and its documentation for any purpose is hereby granted without fee, provided that the above copyright notice appears in all copies and that both that copyright notice and this permission notice appear in supporting documentation. Hewlett-Packard Company makes no representations about the suitability of this software for any purpose. It is provided "as is" without express or implied warranty.
    GMT+8, 2025-6-4 03:13
