查看: 2872|回复: 0
[LV工具模块] LabVIEW 2012 SP1 Datalogging and Supervisory Control Module Win32Eng LV2012SP1数据记录和监控模块DSC2012SP1
    2 小时前
  • 签到天数: 3535 天
    发表于 2020-2-23 12:25:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    请购买附件下载查看
    DSC2012SP1.txt (695 Bytes, 下载次数: 13, 售价: 10 元)
    LabVIEW 2012 SP1 Datalogging and Supervisory Control Module Readme
    Version 12.0.1
    December 2012
    This file contains important information about the LabVIEW 2012 SP1 Datalogging and Supervisory Control (DSC) Module, including installation instructions, new features, a partial list of bugs fixed for the LabVIEW 2012 SP1 DSC Module, and known issues. Refer to the LabVIEW Datalogging and Supervisory Control Module Release and Upgrade Notes, which are available in your DSC Module software kit, for upgrade and compatibility issues of the DSC Module and a complete list of the new features and changes from the DSC Module 2011.
    The LabVIEW Datalogging and Supervisory Control (DSC) Module extends the LabVIEW graphical development environment with additional functionality for the rapid development of distributed measurement, control, and high-channel-count monitoring applications. The DSC Module enhances the LabVIEW shared variable, supports logging data to the Citadel and relational databases, enhances the Historical Data Viewer and the NI Distributed System Manager, provides support for Touch Panel devices running Windows Embedded Standard, and provides tools for graphing historical or real-time trends, enhancing the security of front panels, and writing custom I/O servers.
    In addition to the system requirements for the LabVIEW Development System, the DSC Module has the following requirements:
    • LabVIEW 2012 SP1 Base, Full, or Professional Development System (32-bit)
    • At least 800 MB of disk space
    • 512 MB of RAM. National Instruments recommends 1 GB of RAM
    • Internet Explorer 6 Service Pack 1 or later
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2012 SP1.
    Note  The LabVIEW 2012 SP1 DSC Module does not support Windows 8.
    You can install all of your LabVIEW products—including the DSC Module—using the LabVIEW 2012 SP1 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    Licensing
    The DSC Module relies on licensing activation. You have a temporary license for a 7-day evaluation period. When the evaluation period expires, you must activate a valid DSC Module license to continue using the DSC Module.
    The NI OPC Servers application installed with the DSC Module provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in the DSC Module.
    The following items are the IDs and titles of a subset of issues fixed in the DSC Module. This is not an exhaustive list of issues fixed in the current version of the DSC Module. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    351273The shared variable stays in subnormal state after the OPC server returns a bad status once.
    366890Node Name Array To Node Path VI and Node Path To Node Name Array VI run very slowly.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the DSC Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the DSC Module are located in the labview\examples\lvdsc directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Important Information
    © 2000–2012 National Instruments. All rights reserved.
    GMT+8, 2025-5-10 11:54
