查看: 5254|回复: 0
[LabVIEW] NI LabVIEW 2019 Full Linux64Eng LV2019Linux系统完整版下载
    3 小时前
  • 签到天数: 3791 天
    连续签到: 42 天
    发表于 2020-2-21 21:24:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    本文件为ISO文件,集成了LabVIEW2019 Linux Full完整版。完整版与专业版比较,少了应用生成等功能,具体请查看自述文件。
    LabVIEW 2019 Linux完整版
    发布日期:2019-5-17
    CentOS 7
    Red Hat Enterprise Linux 7
    openSUSE Leap 42.3
    语言:英文
    文件名: 2019SP1LV-LinuxFull.iso
    文件大小: 1104433152 字节 (1.03 GB)
    修改日期: 2023-03-09 11:40
    MD5: 2c0cd7f010d6bc1cb7eeca70eb079bc7
    SHA1: 3a021024f8262922a1be0abe35946e5851edfa3f
    SHA256: 77fc4ed8bb6e0bf5e026ee28fd5eae7d9bf6f0d7e402f89d0ae19cb1507c271a
    CRC32: fec90251
    请注册视觉论坛会员登录后购买附件下载查看
    LV2019Linux Full.txt (390 Bytes, 下载次数: 27, 售价: 80 圆)
    LabVIEW 2019 Media Readme for macOS/Linux
    April 2019
    With the LabVIEW media for macOS/Linux, one installation gives you access to the LabVIEW Development System and nearly all the LabVIEW for macOS/Linux modules and toolkits. This file contains important information about the LabVIEW 2019 media for macOS/Linux, including supported operating systems and installation instructions.
    Products Included on the LabVIEW Media for macOS/Linux
    You can run the LabVIEW for macOS/Linux installer on the following operating systems:
    • (macOS) macOS 10.13 or 10.14
    • (Linux)
      • openSUSE LEAP 15.0
      • openSUSE LEAP 42.3
      • Red Hat Enterprise Linux 7.x
      • Red Hat Enterprise Linux 8.x
      • CentOS 7
      • CentOS 8
    The LabVIEW media for macOS/Linux includes the following products. You can refer to the readme for each product in the Product ReadMes directory for information including system requirements, known issues, and bug fixes.
    • LabVIEW Full and Professional Development Systems
    • MathScript Module2
    • VI Analyzer Toolkit3
    • Application Builder3
    3 The VI Analyzer Toolkit and Application Builder install with the LabVIEW Professional Development System.
    You can install your LabVIEW products—including the modules and toolkits—using the LabVIEW 2019 media for macOS/Linux.
    To request additional LabVIEW media, refer to the NI website.
    Installing the LabVIEW Development System
    Complete the following steps to install the LabVIEW Development System.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and open LabVIEW2019-Pro.dmg located under the LabVIEW/macOS directory.
    • Select Continue to run a program to determine if the LabVIEW Development System can be installed on your system.
    • Follow the instructions that appear on the screen to install LabVIEW.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount lv2019pro-linux.iso located under the LabVIEW/Linux directory.
      • Create the directory which is the mount point:
        # mkdir -p /mnt/lv2019
      • Use the following mount command to mount the ISO file:
        # mount -o loop <path to lv2019full-linux.iso or lv2019pro-linux.iso> /mnt/lv2019
      • Change the directory to list files stored in the ISO image:
        # cd /mnt/lv2019
    • On the mounted media, to run the installation script, enter the following command:
      sh ./UNINSTALL
    Installing the Control Design and Simulation Module
    Complete the following steps to install the Control Design and Simulation Module.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and double-click LabVIEW Add-ons/Control Design and Simulation directory.
    • Open macOS directory.
    • Select Continue to run a program to determine if the Control Design and Simulation Module can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Installation Type screen.
    • In the Installation Type screen, select Change Install Location to select the location where a compatible version of LabVIEW is installed. Otherwise, the installation will not complete.
    • After you select the installation location, continue to follow the instructions that appear on the screen.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount CD&Sim2019.iso. Refer to the Installing the LabVIEW Development System section to mount an ISO image on Linux.
    • On the mounted media, find the Control Design and Simulation Module installer in the Linux directory.
      sh ./UNINSTALL
    Installing the MathScript Module
    Complete the following steps to install the MathScript Module.
    (macOS)
    • Insert the LabVIEW media for macOS/Linux and double-click LabVIEW Add-ons/MathScript RT directory.
    • Select Continue to run a program to determine if the MathScript Module can be installed on your system.
    (Linux)
    • Insert the LabVIEW media for macOS/Linux. Mount MathScript2019.iso. Refer to the Installing the LabVIEW Development System section to mount an ISO image on Linux.
    • On the mounted media, find the MathScript Module installer in the Linux directory.
      sh ./UNINSTALL
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW.
    © 2017–2019 National Instruments. All rights reserved.
    GMT+8, 2026-2-2 13:32
