查看: 5217|回复: 1
[LV工具模块] NI Vision Development Module 2016 f1 Patch update Win32/64Eng 视觉开发模块VDM2016 f1补丁升级程序 适用LabVIEW2016
    昨天 08:13
  • 签到天数: 3815 天
    连续签到: 8 天
    发表于 2020-2-19 21:38:32 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    该版本VDM2016F1为VDM2016的升级程序,不是独立的安装包,需要先安装VDM2016版,再安装该升级程序。应该是针对VDM2016进行升级的:
    NI Vision Development Module 2016 Win32/64Eng 视觉开发模块VDM2016 适用LabVIEW2016
    http://visionbbs.com/thread-14099-1-1.html
    而对于VDM2016_1的程序,我方安装后,无法再升级了。也就是以下的VDM2016_1 August版本,应该是已经升级过了的:
    NI Vision Development Module 2016_1 August for LabVIEW2016 Win32/64Eng VDM2016_1August视觉开发包适用32位/64位LV2016版下载
    http://visionbbs.com/thread-22808-1-1.html
    F1升级包主要升级的是FPGA,升级资源包中的都是FPGA资源。如果没有使用到,不升级也可以。
    VDM2016F1下载:
    标准下载:
    EXE版:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    ZIP版:
    提取码: 请购买附件下载查看
    NI下载器下载:
    提取码: 请购买附件下载查看
    标准下载:
    请购买附件下载查看
    下载器下载:
    请购买附件下载查看
    VDM2016F1 Patch.txt (678 Bytes, 下载次数: 69, 售价: 5 圆)
    NI Vision Development Module 2016 f1 Readme
    September 2016
    This file contains important information about National Instruments Vision Development Module, including installation instructions, new features, fixed issues, and known issues.
    External Library Support
    Updates and Improvements
    How to Activate the NI Vision License
    Deploying Vision Applications
    Documentation and Examples
    The NI Vision Development Module provides hundreds of image processing and machine vision functions. Along with programming libraries, the NI Vision Development Module also includes NI Vision Assistant. Installing this software may remove previous versions of the NI Vision Development Module that are currently installed.
    Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
    Refer to the NI Vision website at ni.com/vision for the latest information about the NI Vision Development Module.
    The development computer must meet the following system requirements to run the NI Vision Development Module.
    MinimumRecommended
    Processor233 MHz Pentium or equivalentPentium 4/M or equivalent
    Memory256 MB RAM512 MB RAM
    Display (Vision Assistant)1,152 × 864 resolution video adapter with a 16-bit display1,152 × 864 resolution video adapter with a 24- or 32-bit display
    Display (other environments)1,024 × 768 resolution video adapter with a 16-bit display1,024 × 768 resolution video adapter with a 24- or 32-bit display
    Free Hard Disk Space
    3.2 GB
    Operating System
    • Windows 10 (32- and 64-bit)
    • Windows 8.1 (32- and 64-bit)1
    • Windows 7 SP1 (32- and 64-bit)2
    • Windows Server 2012 R2 (64-bit)1
    • Windows Server 2008 R2 SP1 (64-bit)2
    NI Vision Development Module 2016 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, NI Vision Development Module drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. NI Vision Development Module 2016 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Vision Development Module 2016 to an unsupported OS. Additionally, after installing NI Vision Development Module 2016, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    The following table lists the NI application software versions, including service packs, supported by the NI Vision Development Module. The installer specifically allows side-by-side installations of Vision Development Module for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, or any other supported development environment, before installing the NI Vision Development Module.
    NI Application SoftwareVersions Supported by NI Vision Development Module
    NI LabVIEW
    2013, 2014, 2015, 2016
    NI LabVIEW Real-Time Module
    NI LabVIEW FPGA Module
    2014, 2015, 2016
    NI LabWindows™/CVI™
    2010, 2012, 2013, 2015
    NI Vision Development Module .NET Support
    NI Vision Development Module 2013 SP1 was the last version to release updated support for the .NET Framework 1.1, .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported.
    New versions of NI Vision Development Module will not provide new .NET feature support or development. It is recommended that you begin new development in other supported development environments.
    The NI Vision Development Module supports the external vision library OpenCV. Refer to the National Instruments Web site to download the NI Vision OpenCV support utilities.
    NI Vision OpenCV support utilities enable the use of OpenCV algorithms in LabVIEW and NI Embedded hardware. NI Vision OpenCV support utilities provide:
    • Pre-built OpenCV binaries for Windows and NI Linux RT
    • C++ development files to create an interface between NI Vision Image and OpenCV Mat.
    • Utilities to create LabVIEW APIs to call OpenCV entry points
    • LabVIEW examples
    New Features in Vision Development Module 2016
    This release of the Vision Development Module includes the following new features:
    • Vision FPGA
      • Added FPGA IPs capable of processing 8 pixels in parallel for higher throughput applications. This feature is available only on Kintex-7 FPGA targets.
      • Added new single-pixel (x1) FPGA IP for Local Threshold Niblack and Sauvola methods.
    • Enabled AVI support on NI Linux Real-Time hardware targets.
    • Added the Sauvola local threshold algorithm.
    • Improved performance for the following algorithms:
      • IMAQ Correct Calibrated Image
      • IMAQ Local Threshold
      • IMAQ AutoBThreshold 2
    NI Vision Assistant includes the following new features:
    • Added FPGA code generation support for multiple-pixel (x8) FPGA IPs for Kintex-7 FPGA Targets.
    • Added Sauvola local threshold algorithm to the Threshold Step and Calibration Training Interface.
    The following list describes issues in previous versions of NI Vision Development Module that are fixed in this update. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI Vision Development Module.
    590374The IMAQ FPGA Local Threshold VI needs to operate at 30 MHz on IC-317x targets when using the Niblack method. If operated above 30 MHz, it results in a distorted image.
    FlexRIO devices can operate at default clock rates for the IMAQ FPGA Local Threshold VI, but their maximum throughput is not optimized.
    Note: This patch corrects these issues in LabVIEW 2014 and later. Vision Assistant users will require additional files to correct this problem for FPGA code generation. Refer to the National Instruments Web site for more information and detailed notes on operating frequencies for supported targets.
    The following list describes issues related to NI Vision Development Module that are fixed in a separate update, NI Vision Common Resources 2016 f1. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI Vision Development Module.
    591845Calling the IMAQ Distance VI in a loop crashes LabVIEW with an access violation.
    593465Data Matrix ISO 15415:2004 grading crash.
    594153Inconsistent fixed pattern damage grading for ISO 15415:2004 rectangular Data Matrix codes.
    594766LabVIEW crashes with error 0xC0000005 when using IMAQ Extract Countour VI with certain images.
    601519Data Matrix decoding is not consistent with a given ROI for rectangular codes and can return incorrect data.
    The following list describes issues in previous versions of NI Vision Development Module that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI Vision Development Module.
    445346The IMAQ Rake VI provides inconsistent edges at image boundary when search line width is 1.
    481652, 413948Code generated for some algorithms in Vision Assistant do not work the second time the main VI is called if the user disposes all buffers in the main VI. The following algorithms are affected: Color Location, Color Pattern Matching, Compare Contour Template, Defect Inspection, Flat Field Correction, Image Calibration, Mask from Image File, Match Geometric Pattern, Match Pattern, and Shape Matching
    535749The Ready for Input parameter never becomes true in desktop simulation for some Vision FPGA VIs using IPINs.
    565142Extracting part of a calibrated image causes the IMAQ Particle Analysis VI to return negative areas.
    566174A created FPGA Project shows a missing dependency to IVA FPGA Image Processing.vi if the user chooses to generate the code with a different implementation name.
    572062The IMAQ Particle Filter 3 VI runs slowly on Linux Real Time targets.
    572266The IMAQ OCR Train VI returns error -1074395550 when the user trains certain Cyrillic characters.
    572494nivision.lib for MSVC is missing DLL entry points.
    574030The IMAQ Read Barcode 2 VI does not work for certain Code 128 barcodes.
    574662Convolution using an integer kernel was 4x slower in Vision Development Module 2015 SP1 compared to a previous release.
    574663Binary Erosion was 3x slower in Vision Development Module 2015 SP1 compared to a previous release.
    576135The IMAQ Extract Tetragon VI leaks memory.
    578844The IMAQ Pattern Match 4 VI generates error -1074395720 for certain angles of rotated ROIs.
    579853The IMAQ Overlay VI can sometimes crash in applications which also contain NI-IMAQdx VIs.
    582138The FPGA Flat Field Correction example does not run on Linux targets.
    5843252D Barcode options (ISO 15415:2004 and AIM DPM-1-2006) are not available when C or .NET is the selected language for code generation in Vision Assistant.
    587959The Watershed Segmentation step in Vision Assistant does not display the image with a binary palette on edit.
    588854The imaqMatchPattern4 function leaks memory.
    590502The Golden Template Comparison step in Vision Assistant returns a larger defect area than expected when regions to ignore are added to the template and then later removed.
    Installation InstructionsInstalling from the LabVIEW Platform DVDs
    If you purchased LabVIEW, you can install all of your LabVIEW products—including the NI Vision Development Module—using the LabVIEW Platform DVDs.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments Web site.
    Installing from the NI Vision Development Module Installation Media
    Complete the following steps to install the NI Vision Development Module from the NI Vision Development Module installation media.
    • Insert the NI Vision Development Module installation media.
    • If you do not have autorun enabled, double-click autorun.exe. If you have autorun enabled, autorun.exe runs automatically.
    • (Optional) Activate NI Vision Development Module when prompted by the installer, or activate at a later time using the NI License Manager.
    When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision license through an Internet connection.
    • Run the product you want to license.
    • Click Yes when prompted to interactively activate your product.
    • Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
    • Enter the product serial number, and click Next.
    • Enter your registration information, and click Next.
    Tip: Enter your email address to receive a copy of your activation code for your records.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
    • The ability to create NI Vision Runtime installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or a custom installer.
    • The ability to install the NI Vision Runtime directly from the NI Vision Development Module installation media.
    • One NI Vision Runtime License, which allows you to install a custom application on a single machine.
    The NI Vision Development Module installer contains the runtime installer for NI Vision. The runtime installer is installed at \Run-Time Engine, where is the location to which the NI Vision Development Module is installed. Visit the ni.com to download software upgrades for NI Vision and the NI Vision Runtime installers.
    Purchasing NI Vision Deployment Licenses
    You must purchase an NI Vision Runtime License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Runtime directly from the NI Vision Development Module installation media. The NI Vision Development Module ships with one runtime license. Contact a National Instruments sales representative or visit ni.com to purchase additional runtime licenses.
    Note: Additional NI Vision Runtime licenses do not include installation media. To install additional licenses, use the original NI Vision Development Module installation media and the serial number provided by National Instruments.
    Using the NI Vision Runtime
    You can call the NI Vision Runtime installer from the application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can direct the installer to call the NI Vision Runtime installer.
    Refer to the LabVIEW Help for more information about the LabVIEW Application Builder. Refer to the NI LabWindows/CVI Help for more information about building and distributing LabWindows/CVI applications.
    You can also direct a custom application installer to call the NI Vision Runtime installer. This may be useful if you are creating an installer for applications created in other development environments. Refer to the documentation that came with the installer software to learn how to call executables from the custom installer. If you are using a custom installer, call the NI Vision Runtime installer at the end of the installation procedure because the installer may require the system to be restarted.
    To call the NI Vision Runtime installer silently (non-interactively), you must add /q /AcceptLicenses yes as command line arguments to the runtime installer. For example, enter \Run-Time Engine\visionrte.exe /q /AcceptLicenses yes, where is the location to which NI Vision is installed, and is the version number of the NI Vision Runtime installed. Refer to the Automating the Installation of NI Products section for more information on how to change the level of interactivity of the installer or whether it automatically initiates a system restart.
    Distributing LabVIEW Applications
    The NI Vision Runtime installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Runtime as part of the installation.
    Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Runtime.
    Distributing LabWindows/CVI Applications
    In addition to including the NI Vision Runtime with the installer, you must include the appropriate LabWindows/CVI Runtime. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the NI Vision Development Module.
    National Instruments is aware of the following issues you may encounter while using NI Vision Development Module.
    • The IMAQ Compare Golden Template VI returns different defect image results for LabVIEW 32-bit and LabVIEW 64-bit versions.
    • LabWindows/CVI 2015 examples for the Vision Development Module can give null pointer dereference crashes if Vision development or runtime licenses are not activated.
    • Reading a frame from an AVI compressed using the codec "Cinepak Codec by Radius" with the IMAQ AVI Read Frame VI corrupts memory, and prevents LabVIEW from displaying a file dialog.
    • The IMAQ Learn Distortion Model VI with the Distortion Model set to Polynomial generates an inconsistent calibration template if the X Step and Y Step values from the IMAQ Calibration Target to Points - Circular Dots 2 VI are less than 0.0001.
    • The OCR Training Interface crashes intermittently on exit when using a character file with more than 255 samples.
    • When an FPGA target is active in a LabVIEW project, the Vision Assistant executable cannot generate code for a non-FPGA LabVIEW target into that same instance of LabVIEW.
    • When zoom factors above 30 are used, the Image Display Control on NI Linux Real-Time targets leaves black-colored border space.
    • The snapshot property node for the Image Display Control on NI Linux Real-Time targets returns an error even though the control is functioning properly. This issue is present only when the target is connected to the host.
    • The Image Display Control on NI Linux Real-Time targets may not work properly when an image is set using a property node value and the target is connected to the host. The property node value works properly when the target is disconnected from the host.
    • Vision FPGA VIs may be broken when opened on one target after being used on another target. You can fix the broken VI by forcing LabVIEW to recompile it by pressing + + Run Button.
    • Vision FPGA Filter VIs with a mask using a 9x9 kernel support image widths up to 2,000 pixels.
    • The IMAQ FPGA GrayMorphology Dilation 5x5 U8x1 VI left border will give incorrect values on Kintex-based NI FPGA targets.
    • The AVI2 VIs do not support writing extra data to AVIs.
    • The IMAQ AVI2 Open and Close VIs leak when opening and closing a session with Built-in Codecs.
    • Japanese and Simplified Chinese for text overlays are not supported on NI Linux Real-Time targets.
    • The Calibration Axis is not set properly in the Calibration Training Interface, resulting in wrong real-world coordinates, when the Calibration Type is set to Point Coordinate Calibration and the Implicit Calibration Axis option is deselected.
    • The IMAQ Read QR Code VI may hang when the QR Code Cell Size has a minimum size of 2 or less. Setting the minimum size to 3 or higher will prevent this issue.
    • The IMAQ Read Data Matrix Barcode 3 VI may hang on some I16 images.
    • Zooming out on a large 32-bit image in the Image Display Control in LabVIEW will cause the image to black out. Only the displayed image is affected. The image itself is not modified.
    • To store error statistics on corrected images, you must run the IMAQ Get Calibration Info2 VI before correcting the calibration template image. The Return Error Information input must be set to TRUE.
    • Vision Assistant cannot generate C code if a double-byte character exists in the path to Vision Assistant or in the destination path for the generated code.
    • Some Vision Development Module .NET examples only work if Measurement Studio 8.6 or later is installed.
    • The Visual Basic .NET Label example does not compile.
    • There is no 64-bit Vision API for .NET.
    • Installing the Vision Development Module on a Windows Vista 64-bit computer where Visual Studio 2005 has been recently installed causes compatibility warnings.
    • On some systems, the Vision Development Module cannot open two of the installed AVI files, SideCrash2.avi, when running as a 64-bit application.
    • The IMAQ Overlay Multiple Lines 2 VI returns an error when Fill is the selected Drawing Mode.
    • The IMAQ Edge Tool 3 VI changes the position of edges found when image was calibrated with point coordinates calibration.
    Documentation and examples are installed onto your hard drive with the NI Vision Development Module. To view the documentation, select Start»All Programs»National Instruments»Vision»Documentation»Vision Documentation, or navigate to \Public\Public Documents\National Instruments\Vision\Documentation.
    Refer to the National Instruments Product Manuals Library at ni.com/manuals for the most recent versions of product documentation.
    The following sections describe the documents available for each application development environment and where to find examples.
    • NI Vision Concepts Help—Describes the basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
    NI Vision for LabVIEW
    • NI Vision for LabVIEW Help—This document contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. It describes how to create machine vision and image processing applications in LabVIEW. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module, and how to use the Vision FPGA VIs with an FPGA target and the LabVIEW FPGA Module. You can access this help in LabVIEW by selecting Help»NI Vision for LabVIEW Help.
    • NI Vision for LabVIEW Examples—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. NI Vision examples for LabVIEW are installed to \examples\Vision FPGA, where is the location LabVIEW is installed.
    NI Vision for LabWindows/CVI
    • NI Vision C Support Help—Contains reference information about NI Vision C functions.
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at National Instruments\Shared\CVI\Bin\NIVision.lfp.
    • NI Vision LabWindows/CVI example programs are installed at \Public\Public Documents\National Instruments\CVI\samples\Vision.
    NI Vision for Eclipse and other Text-based Development Environments
    • Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition with the NI Vision Development Module and NI-IMAQdx—Describes how to use the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition to develop an example C application using the NI Vision Development Module API and/or NI-IMAQdx, and deploy it on a Linux remote target. This tutorial outlines the basic steps required to build and deploy an example application.
    • To view text-based example programs, select Start»All Programs»National Instruments»Vision»Examples»Vision Examples, or navigate to \Public\Public Documents\National Instruments\Vision\Examples.
    NI Vision Assistant
    • To access Vision Assistant documentation from the Start menu, select Start»All Programs»National Instruments»Vision»Documentation»Vision Assistant Documentation, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Documentation.
    • To access Vision Assistant examples from the Start menu, select Start»All Programs»National Instruments»Vision»Examples»Vision Assistant Examples, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Examples.
    • NI Vision Assistant Tutorial—Describes the Vision Assistant software interface and guides you through creating example image processing and machine vision applications.
    • NI Vision Assistant Help—Contains descriptions of Vision Assistant features and functions and provides instructions for using them. In Vision Assistant, select Help»Online Help.
    • NI Classification Training Interface Help—Contains information about how to use the NI Classification Training Interface to classify binary samples. In the NI Classification Training Interface, select Help»Online Help.
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
    • NI OCR Training Interface Help—Contains information about how to use the NI OCR Training Interface to learn characters, save character sets, and verify characters by comparing them to a reference character. In the NI OCR Training Interface, select Help»Online Help.
    • NI Texture Training Help—Contains information about how to use the NI Texture Training Interface to train a texture classifier file for use in texture defect detection applications. In the NI Texture Training Interface, select Help»Online Help.
    • NI Calibration Training Help—Contains information about how to use the NI Calibration Training Interface to select and create a calibration for use in machine vision applications. In the NI Calibration Training Interface, select Help»Online Help.
    • NI Vision Template Editor Help—Contains information about how to use the NI Vision Template Editor to learn and edit template images that you can use with pattern matching, geometric matching, and golden template comparison functions. In the NI Vision Template Editor, select Help»Online Help.
    • NI Flat Field Creation Wizard Help—Contains information about how to use the NI Flat Field Creation Wizard to create a dark or bright field image and perform flat field correction in a machine vision application. In the NI Vision Flat Field Creation Wizard, select Help»Online Help.
    © 2016 National Instruments. All rights reserved.
    375127E-01
  • 签到天数: 42 天
    发表于 2020-12-5 10:14:09 | 显示全部楼层 来自:广东省东莞市 电信
    NI Vision Development Module 2016F1 Patch for LabVIEW2016 Win32/64Eng VDM2016F1视觉开发包适用32位/64位LV2016版下载补丁升级程序
    1111111111111
    GMT+8, 2026-3-5 07:11
