查看: 4040|回复: 0
[LabVIEW] NI LabVIEW 2014 SP1 MAC OS X64Eng LV2014SP1苹果系统评估版下载
    昨天 08:11
    发表于 2020-2-16 22:42:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址:
    请购买附件下载查看
    LV2014SP1MAC.txt (192 Bytes, 下载次数: 46, 售价: 10 圆)
    LabVIEW 2014 Service Pack 1 Readme for MAC OS X
    December 2014
    This file contains important information about LabVIEW 2014 Service Pack 1 (SP1) for MAC OS X, including system requirements, installation instructions, new features, known issues, and a partial list of bugs fixed for LabVIEW 2014 SP1.
    Refer to the National Instruments website for the latest information about LabVIEW 2014 SP1.
    LabVIEW 2014 SP1 (64-bit)
    OS XRun-Time EngineDevelopment Environment
    RAM256 MB2 GB
    Screen Resolution1024 x 768 Pixels1024 x 768 Pixels
    Operating SystemOS X 10.8, 10.9, or 10.10OS X 10.8, 10.9, or 10.10
    Disk Space656 MB - 1.3 GB1.3 GB for the complete installation
    Temporary Files DirectoryN/ALabVIEW uses a directory for storing temporary files. National Instruments recommends that you have several megabytes of disk space available for this temporary directory.
    Note  National Instruments recommends that you use Firefox 10.0 or later or Safari 6.0 or later to view the LabVIEW Help.
    Depending on whether you are installing LabVIEW for the first time or upgrading from a previous version, refer to one of the following documents for information about installing LabVIEW:
    • LabVIEW Installation Guide—Includes information about installing LabVIEW, modules and toolkits, drivers, and hardware.
    • LabVIEW Upgrade Notes—Includes information about protecting existing VIs and projects before you install a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2014 and LabVIEW 2014 SP1.
    You can access the LabVIEW Installation Guide and the LabVIEW Upgrade Notes at ni.com as well as on the installation media.
    Visit ni.com/security for security information about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
    LabVIEW 2014 SP1 includes the Profile Buffer Allocations window to identify and analyze buffer allocations in a LabVIEW application. Select Tools» Profile» Profile Buffer Allocations to display this window. You can use this window to complete the following tasks:
    • Identify the large buffers that an application allocates. Click Start to start profiling, run a VI or multiple VIs that you want to profile, and click Stop to end the profiling session. The Profile Data table displays the largest buffer allocations. The number of buffer allocations in the table is no greater than the Maximum buffers to display.
    • Analyze the cause of a buffer allocation. Double-click a row in the Profile Data table to open the block diagram of the VI that causes the buffer allocation. LabVIEW highlights the node, wire, or tunnel which causes the buffer allocation.
    • Save and load profiles for analysis. Select File»Save Profile to save the profile data to a binary file on the disk. You can load the saved profile back into this window by selecting File»Load Profile. You can also export the profile data to a CSV file by selecting File»Export Table. You can load the CSV file in either Microsoft Excel or Notepad.
    This window includes the following components:
    • Application Instances—Filters application instances that contain buffer allocations. By default, the Profile Buffer Allocations window shows VIs from all the application instances that allocate large buffers during the profiling session.
    • Maximum buffers to display—Specifies the maximum number of buffer allocations to display in Profile Data.
    • Size unit—Specifies the unit of size (bytes, kilobytes, or megabytes) LabVIEW uses to display the results in Profile Data.
    • Profile Data—Displays a list of buffer allocations that LabVIEW identifies during the profiling session. Click the column header to sort data by column.
    • Time vs Memory Graph—Plots the size of a buffer allocation over time.
    • Threshold—Specifies the minimum size of buffer allocations to record. The Profile Data table only displays buffer allocations larger than Threshold.
    • Start/Stop—Starts or stops the profiling session.
    You can access the software and documentation known issues list online. Refer to the National Instruments website for an up-to-date list of known issues in LabVIEW 2014 and LabVIEW 2014 SP1.
    At the time of release, LabVIEW 2014 SP1 (64-bit) for OS X supports a limited number of National Instruments drivers, modules, and toolkits. Refer to the National Instruments Product Compatibility for LabVIEW (64-bit) for Mac OS X support document at ni.com for more information.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2014 SP1. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    476710Opening a VI Server Reference to two or more identically named VIs, contained in separate LabVIEW libraries in a running executable, can result in Error 1031.
    487258A LabVIEW 2014 Web Service does not run when it is built into an executable and then installed via an NI Installer.
    491159Type Definition instance does not require manual update (new to LabVIEW 2014) if last element of enum was deleted.
    491225Installing the LabVIEW 2014 Run-Time Engine via an NI Installer can prevent the NI System Web Server from starting if older versions of LabVIEW are also present or installed.
    491714Using Probes while Remote Debugging with General Error Handler VI present can cause LabVIEW 2014 to hang.
    492159Uninitialized array elements in block diagram array constants are less transparent in LabVIEW 2014.
    492898Open VI Reference hangs on second call.
    493375In certain cases, LabVIEW 2014 crashes when loading a VI with an updated type definition.
    500664Under certain conditions, the LabVIEW Digital Waveform Graph appears blank even with valid data present.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2014 SP1.
    © 2004–2014 National Instruments. All rights reserved.
    374717B-01
    GMT+8, 2026-3-13 05:08
