查看: 5606|回复: 0
[NI软件产品] NI Vision Builder for Automated Inspection 2.6.1 Win32Eng 自动化检测视觉生成器VBAI2.6.1
    昨天 08:12
  • 签到天数: 3787 天
    连续签到: 38 天
    发表于 2020-2-8 18:21:52 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    标准图像处理软件,Windows系统32位英文版本。2005年发布,NI Vision Builder AI与LabVIEW7.1.1同期。部分功能需要LabVIEW7、LabVIEW7.1、NI VISION7.1以后版本支持。
    链接: 请购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载(不一定有效或无法完成下载):
    请购买附件下载查看
    VBAI2.6.1.txt (209 Bytes, 下载次数: 61, 售价: 100 圆)
    VBAI2.6.1自述文件
    All rightsreserved.
    General Information
    Note: You must be logged in with administrator privileges to install VisionBuilder AI.
    a.Insert the Vision Builder AI CD into your computer. If the CD startup screendoes not appear, use Windows Explorer to run the Setup.exe program from the Vision Builder AI CD.
    b.Follow the setup instructions on your screen.
    5) The Vision Builder AI installercreates the following directory structure under the Vision Builder AI 2.6directory:
    ·        ImageAcquisition and Digital I/O support for the NI PCI-8254R device.
    ·        Geometric Matching stepfor locating templates that are characterized by distinct geometric or shapeinformation.
    ·        ParticleClassification step for training and classifying samples in images based ontheir shape.
    ·        ColorMeasurement step for measuring color intensities in RGB, HSL, CIE L*a*b*, andCIE XYZ color images.
    ·        Run LabVIEW VIstep for running custom VIs from within a VisionBuilder AI script. Custom VIs must be written usingLabVIEW 7.1.
    ·        Modbus/TCPSupport for Modbus Slave step and Modbus Slave Product Selection.
    ·        TCP I/O Stepfor communicating with third-party devices over Ethernet.
    ·        ActiveXcomponent for the Vision Builder for AutomatedInspection engine.
    ·        Developmenttoolkit for creating custom Vision Builder AI steps inLabVIEW. Custom steps must be written using LabVIEW 7.1.
    How toActivate the Vision Builder AI License
    When you run VisionBuilder AI for the first time, it prompts you to activate a license for theproduct. If you do not activate a valid license, Vision Builder AI runs inEvaluation Mode and continues to prompt you to activate a license on eachsubsequent launch. While Vision Builder AI is in Evaluation Mode, all featuresare available, except Migrate Inspection to LabVIEW. The duration of theevaluation period is 30 days, at the end of which you are required to activatethe Vision Builder AI license to continue using the product.
    Complete the followingsteps to activate the Vision Builder AI license using an Internet connection.
    ·        IMAQ PCI-1405
    ·        IMAQ PCI/PXI-1407
    ·        IMAQ PCI/PXI-1409
    ·        IMAQ PCI-1410
    ·        IMAQ PCI/PXI-1411
    ·        IMAQ PCI/PXI-1422
    ·        IMAQ PCI-1424
    ·        IMAQ PCI-1426
    ·        IMAQ PCI/PXI-1428
    ·        IMAQ PCIe-1429
    Note: This version of Vision Builder AI supports the NI PCI/PXI-8252 and the NIPCI-8254R IEEE 1394 host adaptor.
    3) This version of Vision Builder AIsupports the following IMAQ I/O devices:
    Note: If you want to use the NI CVS-1450 Series device or the NI PCI-8254Rdevice with Vision Builder AI, you need to install NI-IMAQ for IEEE 1394Cameras driver software version 2.0.1 or later after you install VisionBuilder AI 2.6.1. Also, when you install this driver software, you must selectthe NI CVS-1450 Series Support feature or the NI-IMAQ I/O feature available onthe Features screen of the installer.
    4) In addition to IMAQ I/O devices,this version of Vision Builder AI also supports static digital I/O from anyNational Instruments device using NI DAQmx Global Channels. To support NIdigital output devices, Vision Builder AI requires NI-DAQmx driver softwareversion 7.1 or later.
    5) Use MAX to create DAQmx GlobalChannels. For information about creating DAQmx Global Channels, refer to the Creatinga Global DAQ Channel topic in the NI Vision Builder for AutomatedInspection: Configuration Help.
    6) To support digital I/O from bothIMAQ I/O devices and NI DAQ devices, this version of Vision Builder AI containsseparate digital I/O configuration and steps. Features available for NI CVS-1450 Series devices and NI PCI-8254Rdevices are prefixed with NI CVS/IMAQ IO, whereas features available forNI DAQ devices are prefixed with NI-DAQ.
    7) To support serial communication,Vision Builder AI requires NI-VISA driver version 2.6.0 or later, which isincluded with Vision Builder AI. You can use serial ports built into your PC,your NI CVS-1450 Series device, or the following NI serial interfaces: PCI 232/x,PXI 8420/x, or PXI 8422/x.
    Migration to LabVIEW
    Vision Builder AI 2.6.1 can createLabVIEW VIs that implement the steps of your inspection diagram. This featurerequires LabVIEW 7.0 or later and IMAQ Vision 7.1 or later.
    ActiveX Component forVision Builder AI
    The following section includesdocumentation for additional objects, properties, and methods that areavailable from the Vision Builder AI ActiveX component but are not documentedin the NI Vision Builder for Automated Inspection: ActiveX ComponentReference Help.
        UpdateMeasurementsOnRefresh Property(Read Only)
           Syntax
           DataType
           Purpose
           Remarks
           Name             Name of the measurement.
           Unit        Unit type of theNIVBAIStepMeasurement.Value.
           Count            Number of items in the collection.
           TimeStamp    Date and time the measurements were lastupdated internally.
           Item        Returns the specified object from thecollection.
           Measurements Property
           Syntax
           DataType
           Purpose
    ·        Enabling EnableInspection Selection and specifying an Inspection to run on for aparticular Product Select Value overrides the Inspection youselected in the Startup tab. The NI CVS-1450 Series device launches the Inspectionyou select for the first Product Select Value in the InspectionSelection tab rather than the Inspection you selected in the Startuptab. Refer to the Setting Remote Target Options topic in the NIVision Builder for Automated Inspection: Configuration Help for moreinformation about these settings.
    ·        If you areusing the Vision Builder AI ActiveX component from LabVIEW, you must useLabVIEW 7.1.
    ·        When using theVision Builder AI ActiveX component, the NIVBAITargetMode setting isnot available. Therefore, the connection to a target always allows fullcontrol.
    GMT+8, 2026-1-30 05:22
