查看: 4730|回复: 1
[LabVIEW] NI LabVIEW 8.6.1 Win32Eng LV8.6.1 32位英文版下载
    昨天 08:56
  • 签到天数: 3596 天
    连续签到: 4 天
    发表于 2020-2-7 21:31:35 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW可提供简单易用的交互式图形化编程软件,同时适用于工程设计和科学研究。 LabVIEW能从数千种仪器以及数据采集和测量设备上快速获取数据,各种交互式向导和500多个内置的LabVIEW测量分析和信号处理函数可用于抽取用户数据的有用信息,并将结果以图形化方式显示在自定义用户界面、图形图表以及报表中。
    NI官方已经不提供下载地址,石鑫华视觉网/机器视觉论坛专供。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    注意,ISO文件中,有个LabVIEW8.6.1CD2的文件夹,也就是说这个版本的原始文件是双CD版本的,如果在安装过程中弹出窗口要查找CD2,请定位到该目录。
    LV8.6.1ENG.txt (207 Bytes, 下载次数: 18, 售价: 50 元)
    LabVIEW 8.6.1 Readme for Windows
    December 2008
    This file contains important last-minute information about LabVIEW 8.6.1 for Windows, including installation and upgrade issues, compatibility issues, a partial list of bugs fixed in the current version of LabVIEW, and changes from LabVIEW 8.6. Refer to the LabVIEW Upgrade Notes for more information about upgrade and compatibility issues and for a complete list of new features in LabVIEW 8.6.x. Refer to the LabVIEW Release Notes for installation instructions and a complete list of system requirements. After you install LabVIEW, you can access both of these documents by selecting Help»Search the LabVIEW Help in LabVIEW and navigating to the topic for the LabVIEW Documentation Resources topic.
    Refer to the National Instruments Web site for the latest information about LabVIEW 8.6.1.
    Refer to the labview\readme directory for readme files about LabVIEW add-ons, including modules and toolkits.
    Installing LabVIEW 8.6.1
    Installing Another Language Version
    Licensing
    Additions to the LabVIEW Help
    If you have LabVIEW 8.6 installed, you can install LabVIEW 8.6.1 without first uninstalling LabVIEW 8.6. Note: Because LabVIEW installs 8.6.1 over 8.6, you cannot have both LabVIEW 8.6 and 8.6.1 installed simultaneously.
    If you do not have LabVIEW 8.6 installed, you can install LabVIEW 8.6.1 without first installing LabVIEW 8.6.
    Refer to the LabVIEW Release Notes for more information about installing LabVIEW on Windows.
    If you have another language version of LabVIEW 8.6.x installed on your computer, uninstall that version before you install the new language version.
    Licensing
    LabVIEW relies on licensing activation. You must activate a valid LabVIEW license before you can run LabVIEW. To activate LabVIEW, use the serial number you received as part of your installation package. If you upgrade to 8.6.1 from 8.6, use your existing 8.6 serial number during the installation.
    Refer to the LabVIEW Release Notes for more information about licensing in LabVIEW.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in LabVIEW 8.6.x.
    • Click the Update button in the Preview Pane of the LabVIEW MathScript Window to synchronize the value of the variable you select from the Variable List with the same value in any location where the variable appears in MathScript, including outside the LabVIEW MathScript Window. If you change the value of the variable in the Preview Pane, click the Update button to send the new value to any location where the variable appears in MathScript. If you do not change the value of the variable in the Preview Pane, click the Update button to refresh the variable with the latest value from another location in MathScript.
    • The quad MathScript function is not supported in the LabVIEW Run-Time Engine. You cannot use this function in a stand-alone application or shared library.
    • If you install LabVIEW 8.6.x or the latest NI Device Drivers media without upgrading to LabVIEW SignalExpress 3.0, some SignalExpress VIs break after code generation. Refer to the National Instruments Web site for more information about repairing code generation and upgrading to SignalExpress 3.0.
    • The Wait (ms) function behaves differently on Windows and the LabVIEW Real-Time Module. On Windows, the Wait (ms) function waits up to the value specfied in the milliseconds to wait input. On the RT Module, the Wait (ms) function waits at least the value you specify in the milliseconds to wait input. The Wait (ms) function has a margin of error of plus or minus one millisecond.
    The following items are the IDs and titles of a subset of issues fixed between LabVIEW 8.6 and LabVIEW 8.6.1. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    IDLegacy IDFixed Issue
    441144GPD8CUDUsing Reinitialize to Default Value on XControl resets data, but not the display of the control.
    5701644DLSS7QMajor grids disappear on waveform graph
    90672400C2N00The server.tcp.acl config token is not copied over during a build application
    100582-NIReport.llb: "report in" and "report out" parameters are not localized in any of the VIs
    106270-Custom probes not cached for any wire type that has an embedded LabVIEW class (cluster, array, refnum)
    109046-Custom probe of any type containing LabVIEW class doesn't show up in Custom Probe menu
    109454-Custom Wire Artwork does not immediately redraw when replacing LabVIEW class
    110820-Right-click copy data in reentrant clones crashes LabVIEW when nested typedefs are involved
    112372-LabVIEW installer "insufficient OS" dialog has a trailing "\n"
    113638-Connectivity palette is not set to sync to directory, but should
    115082-Application Builder[LV DVD] Product missing in the LV startup dialog box
    115978-Breakpoint Failure
    116663-MathScript in Linux - Pop up plot freezes after saving an eps image.
    116882-Negative constant wired directly to count terminal (N) of For Loop with auto-indexing output tunnels produces "out of memory" error or crash
    117216-Instrument Driver Project Wizard reports empty dependency error in report
    117382-Application builder requests password for dynamic VI
    117659-Control drag copy of multiple controls within a cluster throws internal error
    117709-Unbundling class private data control elements by name follows different rules than regular typedefs
    118210-Language info is not shown at uninstallation dialog
    118665-In-place Variant To/From Element is always broken
    118826-Numeric localization codes do not work
    119144-Wide string caching is very problematic for SCC case sensitivity issues, causes other odd behavior
    1196154EI92JAIApplication created after converting a build script is missing menu bar
    119890-LabVIEW UDP Broadcast on Multiple NICs Does Not Work On Vista
    119916-Perforce Command Line provider slower than Perforce SCM on operations involving large number of files.
    120012-NI_AB_API_SDIST Build.vi displays popup dialogs
    120048-lvanlys.out and lvblas.out have duplicate symbols
    120322-crash after running express save for previous
    120393-The Web server returns a 405 error in response to PUT requests
    120456-Loading a Model in the Sensor Mapping Express VI Crashes LabVIEW
    120749-Can't drag and drop test file items into libraries
    120751-Add UTF preference pages to built-in preferences dialog
    120793-dependencies that don't report callers
    121448-ni::variable::Variable leaks a Variant
    121526-Loading a class when its ancestry is reserved can crash
    121636-LabVIEW hangs on 3D_Graph when running Analyzer test if SCC is enabled.
    121671-Switching to "Files" tab is slow with large project
    121833-Alarm dialog rounds alarm limits to integers when opened - erases previous settings
    121889-Conditionally used variable actually used as variable definition in nested if statement
    121981-MathScript Node breakpoint popup behavior is different when VI is running
    122079-Application Builder build spec ignores remove front panel and block diagram flags at build time for the items listed in the dependencies node of the project tree.
    122604-Possibly Corrupt Type Def Cluster Controls will not print in multiple versions of LabVIEW
    122856-The XControl Facade does not get the Panel Resize event when the XControl is inside a reentrant clone
    122857-Bundle by Name does not work for XControls which contain Cluster Typedefs
    123115-The feedback node terminals can turn black and lose data type when connected to structures
    123312-100ms delay when sending small packets with Logos XT on VxWorks
    123406-Upgrade llb from 8.5 to 8.6 - llb now crashes whenever you click the broken run arrow
    123618-Incorrect behavior of copy and paste XControl.
    123651-Labview crashes when you change plot names in mixed signal graph
    123716-Unflattening LV object array from xml results in error
    123728-Decimate Array wired to Feedback Node Initializer within Loop Crashes LabVIEW on Second Iteration
    123755-VI conversion fails within a lvlib
    124319-Call to VI server method App.Get VI.CPTM RC is slower in 8.6
    124463-LabVIEW Hanging on Launch With Expired VI Analyzer License
    124781-Reverting lvlibs in Project Explorer breaks links
    124804-System Exec VI does not work on Russian Windows XP
    124834-Error 1106 using Unflatten from XML on Class with Enum
    125185-FB Typedef Ring Controls show up as #'s when you create a constant
    125408-Attempt to read consolidated type info from future version VI
    125525-Interpolate 2D throws error -20145 whenever non-square array is input into Z terminal.
    125695-Some dialogs don't allow to input eastern characters
    125724-When the Address Book Web Service example is executed after deployed, the internal server error occurred.
    125835-LabVIEW Remote Front Panel 8.6 on Linux Distribution
    125899-Memory Leak when reading from binary file in While Loop
    126200-Call by Reference crashes LV 8.6 when using application refnum
    128091-Typing values in cursor legend of Intensity graph will crash LabVIEW 8.6
    128115-Incorrect Behavior in case structure execution
    128247-LabVIEW Call Library Node has incorrect "data type" for Waveforms and therefore does not work in 8.6
    128520-LabVIEW 8.6 Crashes if TDMS Write has Invalid File Reference
    128657-Locked (No Password) VI property does not save in 8.6
    129245-Revert VI with function blocks not updating project tree
    129282-The LabVIEW 8.6 Standard Run-Time Engine Installer available online updates the USI component
    129876-Desktop Execution Trace Toolkit help server plug-in doesn't return localized target name
    130294-Digital Graph causes LabVIEW to crash when displaying digital signal subsets
    130634-The search results are broken for lverror.chm in Korean and Japanese
    131181-Web Services application builder servers page broken
    131428-I/O control drop-down commands broken
    131714-Access violation in LabVIEW while using digital waveform graph
    Recompiling VIs for Bug Fixes
    The following fix in LabVIEW 8.6.1 requires you to manually recompile the VIs to correct the problem. To force a recompile of a VI without recompiling its subVIs, -click the Run button. To force a recompile of all VIs in memory, --click the Run button. To force a recompile of the entire current VI hierarchy, close all VIs currently opened, open the top-level VI, and --click the Run button. This method will not recompile any of the VIs called dynamically in the hierarchy.
    You also can force recompile all VIs in a specified directory using the following steps. Note that you do not need to perform these steps for VIs installed with LabVIEW 8.6.1.
    • Use a standard text editor to open the LabVIEW.ini file located in the LabVIEW directory.
    • Add massCompAll=True as a new line at the end of the file.
    • Save and close the LabVIEW.ini file.
    • Open LabVIEW.
    • Select Tools»Advanced»Mass Compile to display the Mass Compile dialog box.
    • Navigate to the desired directory and click the Current Folder button.
    • Click the Mass Compile button to force recompile all VIs in that directory.
    • Click the Done button to return to LabVIEW.
    • Once you finish the force recompile, reopen the LabVIEW.ini file.
    • Remove massCompAll=True from the file.
    The following fix requires you to manually recompile the VIs to correct the problem.
    • 128115: Incorrect Behavior in case structure execution
    © 2004–2008 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or ni.com/patents.
    GMT+8, 2025-7-18 09:12
