查看: 4097|回复: 0
[LV工具模块] NI Vision Development Module 8.0 Win32Eng 视觉开发模块VDM8.0版 适用LabVIEW8.0
    7 小时前
  • 签到天数: 3794 天
    连续签到: 45 天
    发表于 2019-12-27 12:10:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    美国国家仪器机器视觉与图像处理库NI VISION 8.0版本,视觉论坛visionbbs.com珍藏版。NI不再提供老旧版本的下载服务或是SSP服务才可以下载,本论坛会收取一定的费用用于论坛日常维护。
    VDM是机器视觉与图像处理专用的工具包,8.0版本针对LabVIEW版本。本论坛提供LabVIEW8的下载。另外还需要视觉采集软件VAS,可在本论坛搜索下载。
    链接: 购买附件下载
    提取码: 购买附件下载
    压缩包需要解压密码,请关注论坛顶上微信公众号,回复“密码”获取
    NI VDM8.0.txt (689 Bytes, 下载次数: 69, 售价: 100 圆)
    All rightsreserved.
    NI Vision 8.0Development Module
    README.rtf containsthe following sections:
    ·        General Information
    ·        New Features
    ·        How to Activate the NI Vision 8.0License
    ·        Using NI Vision 8.0 with MicrosoftVisual Studio .NET 2003
    ·        Known Issues
    General Information
    Installing this program may remove previous versions of IMAQVision for LabVIEW, IMAQ Vision for Measurement Studio, NI OCR, NI-IMAQ, andMeasurement & Automation Explorer (MAX) that are currently installed.
    NI Vision 8.0 supports LabVIEW 7.0 or later, Visual Studio 6.0 orlater, and LabWindows™/CVI™ 7.0 or later. The installer specifically allowsside-by-side installations of NI Vision 8.0 for each of the supported versionsof LabVIEW, enabling you to use the NI Vision 8.0 Development Module withmultiple versions of LabVIEW. National Instruments recommends that you installLabVIEW, or any other supported development environment, before installing the NIVision 8.0 Development Module.
    NOTE: The NI Vision8.0 Development Module overwrites existing NI-IMAQ examples, NI Visionexamples, and NI Vision VIs. Move modified examples or VIs that you want tosave to another directory before installing the NI Vision 8.0 DevelopmentModule.
    For installation instructions and a complete list of systemrequirements, refer to the NI Vision 8.0 Development Module Release Notes.
    All submodulesof the NI Vision 8.0 Development Module have the following new features:
    • Golden Template     Comparison—Functions for comparing images to a golden template     reference image.
    • Data Matrix Enhancements—In     addition to enhancements regarding speed and accuracy, the Data Matrix     functions now can output the ISO 16022 (AIM) grade for a given Data Matrix     barcode.
    • Optical Character     Verification—Functions for verifying the accuracy of characters     within an image.  For each character,     the algorithm compares the character from the image with the reference     character, and outputs a score based on the comparison.
    • Geometric Matching     Enhancements—In addition to enhancements regarding     speed and accuracy, Geometric Matching now supports searching for multiple     templates within a single target image, and searching for templates within     a calibrated image.
    • Shape Detection—Functions     for searching for rectangles, lines, ellipses, and circles within an     image.
    • Watershed     Transform—computes the watershed transform on an image. Refer     to the NI Vision Concepts Manual for more information about     watershed transform.
    • Local Adaptive     Threshold—Thresholds an image into a binary image based on the     specified local adaptive thresholding method (e.g. Niblack, Background     Correction).
    • JPEG2000 File I/O—Support     for reading and writing JPEG2000 files.
    VisionAssistant 8.0 has the following additions:
    • Run LabVIEW VI     Step—Allows     users to call custom LabVIEW VIs from within Vision Assistant scripts.
    • Japanese Language     Support—Vision Assistant software and documentation are     available in Japanese.
    How to Activate the NI Vision 8.0  License
    When you run an NI Vision 8.0 application for the first time, itprompts you to activate a license for the product. If you do not activate avalid license, the NI Vision 8.0 application will run in Evaluation Mode andcontinue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision 8.0 licensethrough an Internet connection.
    • Run the     product you want to license.
    • Click Yes     when prompted to interactively activate your product.
    • Ensure     that Automatically activate through a secure Internet connection is     selected, and click Next.
    • Enter     the product serial number, and click Next.
    • Enter     your registration information, and click Next.
    TIP: Enter your email address to receive a copy ofyour activation code for your records.
    Using NI Vision 8.0 with Microsoft VisualStudio .NET 2003
    NI Vision 8.0 supports interoperability between the Vision 8.0ActiveX control and Microsoft Visual Studio .NET 2003. NI Vision installs thefollowing Interop Assemblies that allow .NET languages to correctly communicatewith the ActiveX controls:
    ·        NationalInstruments.AxCWIMAQControlsLib.Interop.dll—cwimaq.ocx
    ·        NationalInstruments.AxCWIMAQHelpButton.Interop.dll—CWIMAQHlpBtn.ocx
    ·        NationalInstruments.AxCWMV.Interop.dll—cwmv.ocx
    ·        NationalInstruments.AxNIOCRLib.Interop.dll—niocr.ocx
    You can find these assemblies in the \dotNET\Assemblies\Current directory.The assemblies installed by NI Vision correctly wrap several methods thatgenerate errors if you call the methods using the assemblies generated byVisual Studio .NET. For information about the properties, methods, and eventsavailable with these assemblies, refer to the NI Vision for Visual BasicReference Help and the NI Vision for Visual Basic User Manual.
    Creating a New .NET Application using NI Vision8.0
    You must first add the NI Vision controls to your toolbox whencreating a new application. Complete the following steps to add the NI Visioncontrols to the Microsoft Visual Studio .NET 2003 Toolbox:
    • In     Visual Studio .NET, either create a new application or open an existing     one.
    • Open a     form in Design View.
    • Select View»Toolbox.
    • Select     the category in which you want the NI Vision controls to appear, such as General,     Components, and so on.
    • Select Tools»Add/Remove     Toolbox Items.
    • In the .NET     Framework Components tab, select the controls you want to add to your     application. Choose from CWIMAQ, CWIMAQVision, CWIMAQViewer, CWMachineVision, and NIOCR.
    When the controls are in the toolbox, you can add them to yourforms by clicking the tool and drawing an area on the form. References to the NIVision Interop Assemblies are automatically added to your project.
    Viewing the NI Vision 8.0 Examples
    The NI Vision examples for Microsoft Visual Studio .NET 2003 areconverted from the NI Vision for Visual Basic examples. The .NET examples arewritten in Visual Basic .NET and demonstrate use of the NI Vision 8.0 InteropAssemblies. The examples are located in the \Examples\MSVB.NET directory, and the images for the examples arelocated in the \Examples\Images directory.
    Converting an Existing Microsoft Visual Basic6.0 Application
    Microsoft's automatic upgrade engine often generates its own Interopassemblies rather than referencing the official NI Vision 8.0 Interopassemblies. When this happens, your project will have two references for every NIVision assembly needed. Complete the following steps to correctly reference theNI Vision 8.0 Interop assemblies:
    • In     Visual Studio .NET, select Edit»Find and Replace»Replace     in Files.
    • Replace     the following with NationalInstruments.CWIMAQControls:
    -        AxCWIMAQControlsLib
    -        AxCWIMAQHelpButtonLib
    -        AxCWMVLib
    -        AxNIOCRLib
    • Select View»Solution     Explorer.
    • Expand     the Project References.
    • Remove     the following references if they are present:
    -        AxCWMV
    -        AxNIOCRLib
    • AVI     functionality requires Microsoft DirectX 8.1 or later.
    • On     Windows XP with Service Pack 2 installed, NI Vision 8.0 does not support     reading AVI files located in the Local Settings folder, or any subfolders of this folder,     when the AVI file uses any of the following compression filters:
    -        Indeo® Video 5.10 CompressionFilter
    -        Intel Indeo® Video R3.2
    -        Intel Indeo® Video 4.5
    -        Indeo® Video 5.10
    Copying the AVI file to another folder resolvesthis problem.
    • Viewing     the online help files requires Microsoft Internet Explorer 5 or later.
    • Using     NI Vision 8.0 with LabWindows/CVI on a machine that does not support the     MMX instruction set may cause an Illegal Operation exception to occur     within the LabWindows/CVI environment. This error occurs when DirectX     checks for the availability of the MMX instruction set on the machine.
    • The     Visual Basic .NET examples may display the UI controls with incorrect size     and location settings if you use a computer with a DPI display setting     other than 96 DPI. 96 DPI is     the default setting for most Windows operating systems.
    • NI     Vision 8.0 does not support the use of Image Display control invoke nodes     when using LabVIEW 7.0 Real-Time. The following examples use Image Display     control Invoke nodes. Avoid downloading these examples to a LabVIEW 7.0     Real-Time target.
    -        examples\Vision\2.Functions\Analysis\Histogram Example.vi
    -        examples\Vision\2.Functions\Analysis\LineProfile Example.vi
    -        examples\Vision\2. Functions\Calibration\PerspectiveCalibration Example.llb
    -        examples\Vision\2.Functions\Caliper\Clamp Example.vi
    -        examples\Vision\2.Functions\Caliper\Edge Detection Example.llb
    -        examples\Vision\2.Functions\Classification\Classification.vi
    -        examples\Vision\2. Functions\Color\ColorDistance.llb
    -        examples\Vision\2.Functions\Color\ColorLearn Example.vi
    -        examples\Vision\2.Functions\Color Pattern Matching\Color Pattern Matching Example.llb
    -        examples\Vision\2.Functions\Grayscale Processing\MagicWand Example.vi
    -        examples\Vision\2.Functions\Image Management\Extract Example.vi
    -        examples\Vision\2.Functions\Image Management\ImageToArray Example.vi
    GMT+8, 2026-2-5 17:31
