查看: 7794|回复: 1
[LV工具模块] LabVIEW Report Generation Toolkit for Microsoft Office 2017 for LabVIEW 2017 Win32ENG 报表工具包RGT2017 适用LabVIEW2017 X86版本
    2 小时前
  • 签到天数: 3816 天
    连续签到: 9 天
    发表于 2019-12-21 11:15:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RGT报表生成工具包,从LabVIEW2014版开始,有64位版本。在LabVIEW2014-LabVIEW2015版中(含相应的SP1版本),32位的标准安装包中,集成了RGT工具包,但是64位中没有集成该工具包,需要单独下载安装。从LabVIEW2016版开始,则在32位版本、64位版本中,都集成了RGT工具包可选择安装,不需要另外安装。(这里限标准的安装包,即大小一般1-2GB大小的安装文件,各种套件可能不包含RGT的情况。)
    百度网盘下载地址和NI官方下载地址:
    请注册视觉论坛用户,登录后购买附件下载查看
    RGT2017.txt (317 Bytes, 下载次数: 24, 售价: 10 圆)
    LabVIEW 2017 Report Generation Toolkit for Microsoft Office Readme
    2017
    Version 17.0.0
    May 2017
    This file contains important information about the Report Generation Toolkit for Microsoft Office, including installation instructions, new features, a partial list of bugs fixed for LabVIEW 2017 Report Generation Toolkit for Microsoft Office, and known issues.
    System Requirements for the 32-Bit Version
    System Requirements for the 64-Bit Version
    Automatic Installation of NI Products
    The LabVIEW Report Generation Toolkit for Microsoft Office provides VIs you can use to create and edit reports in Microsoft Word and Microsoft Excel formats. You can use the Report Generation VIs to perform the following tasks:
    • Create and edit Word documents and Excel worksheets.
    • Use Word and Excel templates to create reports with a consistent style.
    • Insert, format, and edit text, tables, images, and graphs within Word documents and Excel worksheets.
    • Run Microsoft Visual Basic for Applications macros from Word documents and Excel worksheets.
    In addition to the system requirements for the LabVIEW Development System, the 32-bit version of Report Generation Toolkit for Microsoft Office has the following requirements:
    • Windows 10/8.1 (32-bit and 64-bit)1/7 SP1 (32-bit and 64-bit)2
    • Windows Server 2008 R2 SP1 (64-bit)2
    • LabVIEW 2017 Base, Full, or Professional Development System (32-bit)
    • At least 40 MB of disk space
    • Microsoft Office 2016/2013/2010/2007/2003/XP (32-bit) (Microsoft Office 2013 is also included in Microsoft Office 365)
      Note:  You must have both Microsoft Word and Microsoft Excel installed before installing the Report Generation Toolkit.
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2017.
    In addition to the system requirements for the LabVIEW Development System, the 64-bit version of Report Generation Toolkit for Microsoft Office has the following requirements:
    • Windows 10/8.1 (64-bit)1/7 SP1 (64-bit)2
    • LabVIEW 2017 Base, Full, or Professional Development System (64-bit)
    • Microsoft Office 2016/2013/2010/2007/2003 (32-bit) (Microsoft Office 2013 is also included in Microsoft Office 365)
    With this release, Report Generation Toolkit 2017 drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. Report Generation Toolkit 2017 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use Report Generation Toolkit 2017 to an unsupported OS. Additionally, after installing Report Generation Toolkit 2017, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Visit ni.com/security to view and subscribe in order to receive security notifications about National Instruments products. Visit ni.com/critical-updates for information about critical updates from National Instruments.
    • Refer to KB 4CJDP38M, Automating the Installation of a Single Installer for more information on automatic installations of individual NI products.
    • Refer to KB 4CJDR18M, How Can I Determine the Type and Version of My National Instruments Installer? for a description of the version of the NI Installer your product contains.
    The following items are the IDs and titles of a subset of issues fixed in the Report Generation Toolkit for Microsoft Office. This is not an exhaustive list of issues fixed in the current version of the Report Generation Toolkit for Microsoft Office. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    249185Unable to create report from Macro-enabled Word or Excel template (.dotm and .xltm file).
    463584Append Horizontal Line to Report VI generates incorrect HTML code with width units in percent and decimal separator set to ",".
    598515The default format in Excel Easy Table (num).vi is changed from "%.f3" to "%.; %_13g" to preserve precision and avoid problems on Systems with "," as decimal separator.
    626944Excel_Save_Workbook.vi is broken and needs to be relinked with some versions of office 2016.
    To find information on the compatibility of earlier versions refer to ni.com/support under the search term "LabVIEW Report Generation Toolkit for Microsoft Office Readme".
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Report Generation Toolkit for Microsoft Office.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Report Generation Toolkit for Microsoft Office are located in the labview\examples\office directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Microsoft Windows 10 is the latest version of the Windows operating system. Windows 10 features significant changes compared to previous versions. Windows 10 combines features from both Windows 7 and Windows 8. Moreover, the operating system introduces several new capabilities. For more information about NI support for Windows 10, visit ni.com/windows10.
    © 2009–2017 National Instruments. All rights reserved.
    375405C-01
    发表于 2023-1-17 22:20:04 | 显示全部楼层 来自:上海市浦东新区 电信
    GMT+8, 2026-3-5 10:32
