查看: 4342|回复: 0
[LV工具模块] LabVIEW Report Generation Toolkit for Microsoft Office 2012 LV报表工具包RGT2012
    昨天 09:24
  • 签到天数: 3602 天
    连续签到: 10 天
    发表于 2019-12-21 10:30:43 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW Report Generation Toolkit for Microsoft Office 2012 for LabVIEW 2012 报表工具包RGT2012适用LabVIEW2012
    RGT报表生成工具包,从LabVIEW2014版开始,有64位版本。在LabVIEW2014-LabVIEW2015版中(含相应的SP1版本),32位的标准安装包中,集成了RGT工具包,但是64位中没有集成该工具包,需要单独下载安装。从LabVIEW2016版开始,则在32位版本、64位版本中,都集成了RGT工具包可选择安装,不需要另外安装。(这里限标准的安装包,即大小一般1-2GB大小的安装文件,各种套件可能不包含RGT的情况。)
    June 2012 Version 12.0.0
    LabVIEW2009-LabVIEW2013SP1版本的RGT工具包,都是单独安装的。从LabVIEW2014版后,在LV中集成RGT工具包,不需要再单独下载安装。
    The LabVIEW Report Generation Toolkit for Microsoft Office provides VIs you can use to create and edit reports in Microsoft Word and Microsoft Excel formats. You can use the Report Generation VIs to perform the following tasks:
    Create and edit Word documents and Excel worksheets.
    Use Word and Excel templates to create reports with a consistent style.
    Insert, format, and edit text, tables, images, and graphs within Word documents and Excel worksheets.
    Run Microsoft Visual Basic for Applications macros from Word documents and Excel worksheets.
    The computer you are using must meet the following minimum system requirements to run the Report Generation Toolkit:
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP Service Pack 3 or later (32-bit)
    Windows Server 2003 R2 (32-bit)
    Windows Server 2008 R2 (64-bit)
    40 MB of hard drive space
    LabVIEW 2012 Base, Full, or Professional Development System (32-bit)
    Microsoft Office 2010/2007/2003/XP
    Note:  You must have both Microsoft Word and Microsoft Excel installed before installing the Report Generation Toolkit.
    请注册视觉论坛用户,登录后购买附件下载查看
    RGT2012.txt (653 Bytes, 下载次数: 21, 售价: 10 元)
    LabVIEW 2012 Report Generation Toolkit for Microsoft Office Readme
    Version 12.0.0
    June 2012
    This file contains information to introduce you to the LabVIEW 2012 Report Generation Toolkit for Microsoft Office. The file contains the following information that you need to understand.
    Important Information
    • Create and edit Word documents and Excel worksheets.
    • Use Word and Excel templates to create reports with a consistent style.
    • Insert, format, and edit text, tables, images, and graphs within Word documents and Excel worksheets.
    • Run Microsoft Visual Basic for Applications macros from Word documents and Excel worksheets.
    • Windows XP Service Pack 3 or later (32-bit)
    • 40 MB of hard drive space
    • LabVIEW 2012 Base, Full, or Professional Development System (32-bit)
    • Microsoft Office 2010/2007/2003/XP
    You can install all of your LabVIEW products—including the Report Generation Toolkit—using the LabVIEW 2012 Platform DVDs. Refer to the LabVIEW Installation Guide on the LabVIEW Platform DVD 1 for installation instructions and system requirements.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments website.
    The following items are the IDs and titles of a subset of issues fixed in the LabVIEW 2012 Report Generation Toolkit. This is not an exhaustive list of issues fixed in the current version of the LabVIEW 2012 Report Generation Toolkit. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    339443The "Excel Set Cell Color and Border" VI sets the background color to white by default instead of transparent.
    339092Using the "Append Table to Report" VI to add strings of Cyrillic font to a table in an MS Word report results in gibberish being added to the report.
    174794Report Generation Toolkit for MS Office does not allow to save files with the extension *.xlsm.
    200345The "Append Table to Report" VI displays incorrect values in MS Word 2010 and Report Generation Toolkit 2010.
    343162The "Excel Set Cell Color and Border" VI does not work with MS Office 2010.
    227947When exporting data as a graph using the "Word Easy Graph" VI, the selected graph type is not the one created in the report.
    285658When trying to set the background of an Excel cell to transparent, the cell is always set to black.
    349986When using the "Save Report to File" VI to save a report in HTML format, the VI uses incorrect image paths.
    313610Excel ActiveX methods lead to an error in Report Generation Toolkit 2011.
    309707Printing a document with Report Generation Toolkit and MS Office 2010 on a printer, whose name contains uppercase characters, leads to an error.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the LabVIEW 2012 Report Generation Toolkit for Microsoft Office.
    © 2012 National Instruments Corporation. All rights reserved.
    GMT+8, 2025-7-24 08:57
