查看: 2930|回复: 0
[LabVIEW] LabVIEW NXG3.1 下一代LabVIEW编程平台NXG3.1.0-NXG3.1.1版在线/离线安装版
    半小时前
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2019-12-16 17:10:57 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NXG是NI开发的下一代LabVIEW编程平台,LV NXG3.1版本包含了NXG3.1.0(软件版本名3.0.0_6.4.0,后面的版本号比较乱)、NXG3.1.1(软件版本名3.0.0_6.4.1)等多个小版本,请根据实际情况使用具体的版本。
    NXG3.1.0/3.1.1百度网盘和NI官方在线/离线安装版下载:
    NXG3.1.txt (908 Bytes, 下载次数: 85, 售价: 15 元)
    LabVIEW NXG 3.1 Readme
    March 2019
    This file contains important information about LabVIEW NXG, including system requirements and known issues.
    Patch Details
    LabVIEW NXG Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 (32- and 64-Bit), and All 32-Bit Operating Systems in 2021
    LabVIEW NXG has the following minimum system requirements:
    • 64-bit version of Windows 10 (version 1809)/8.1 Update 11/7 SP12/Server 2012 R2 Update1/Server 2008 R2 SP12
    • 10 GB disk space
    • 1 GB RAM
    • .NET Framework 4.6.2
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    note  Refer to LabVIEW NXG 3.1 Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 (32- and 64-Bit), and All 32-Bit Operating Systems in 2021 for information about future OS support.
    LabVIEW NXG 3.1 adds new functionality to the previous release. Refer to LabVIEW NXG 3.1 New Features for a list of new features and changes.
    You can access an up-to-date list of known issues for a particular release of LabVIEW NXG on the NI website.
    Patch Details
    You can access a list of issues fixed for a particular release of LabVIEW NXG on the NI website.
    Search for items using the search bar in the upper right corner of the LabVIEW window.
    View context help in LabVIEW NXG by pressing and hovering over an object. Refer to the LabVIEW NXG Help, accessible from Help»Online Help, for more information about LabVIEW NXG.
    To learn the theory behind the code, use interactive lessons in the Learning tab that contain example code within the environment.
    LabVIEW NXG Drops Support for Windows 7 (32- and 64-Bit), Windows Server 2008 R2, and All 32-Bit Windows Operating Systems in 2021
    LabVIEW NXG will drop support for Windows 7 (32- and 64-bit), Windows Server 2008 R2, and all 32-bit Windows operating systems starting in 2021. Versions of this product that ship after May 1, 2021, will not install or run on these operating systems. For detailed information about NI operating system support, visit ni.com/r/win32bitsupport.
    Info Code
    LabWindows/CVIcvi_lifecycle
    © 2017-2019 National Instruments. All rights reserved.
    copyright
    End-User License Agreements and Third-Party Legal notices
    • notices are located in the \_Legal Information and directories.
    IVI Foundation copyright notice
    For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent notice at ni.com/patents.
    376808F-01
    GMT+8, 2025-7-25 11:21
