查看: 3003|回复: 0
[LabVIEW] LabVIEW NXG3.0 下一代LabVIEW编程平台NXG3.0.1-NXG3.0.2版在线/离线安装版
    27 分钟前
  • 签到天数: 3604 天
    连续签到: 12 天
    发表于 2019-12-16 10:23:11 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NXG是NI开发的下一代LabVIEW编程平台,LV NXG3.0版本包含了NXG3.0.1(软件版本名3.0.0_6.2.1,后面的版本号比较乱)、NXG3.0.2(软件版本名3.0.0_6.2.2)等多个小版本,请根据实际情况使用具体的版本。
    3.0.1/3.0.2百度网盘和NI官方下载地址:
    NXG3.0.txt (833 Bytes, 下载次数: 65, 售价: 15 元)
    LabVIEW NXG 3.0 Readme
    November 2018
    This file contains important information about LabVIEW NXG, including system requirements and known issues.
    Use LabVIEW NXG to automate benchtop measurements using NI data acquisition hardware and benchtop instruments. Start taking measurements quickly with interactive panels to acquire and visualize data sets. When you need more customization, you can create your own applications using the graphical programming environment.
    LabVIEW NXG 3.0 has the following requirements:
    • At least 8.5 GB of disk space
    • 1 GB RAM
    • .NET Framework 4.6.2
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    LabVIEW NXG 3.0 supports the following systems:
    • 64-bit version of Windows 10 (version 1803)/8.1 Update 11/7 SP12
    • Windows Server 2016 R22
    2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2016 R2 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    This release of LabVIEW NXG adds new functionality to the previous release. Refer to LabVIEW NXG 3.0 New Features and LabVIEW NXG 3.0 Behavior Changesfor lists of new features and changes.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW NXG.
    Search for items using the search bar in the upper right corner of the LabVIEW NXG window.
    View context help in LabVIEW NXG by pressing and hovering over an object. Refer to the LabVIEW NXG Manual, accessible from Help»Online Manual, for more information about LabVIEW NXG.
    To learn the theory behind the code, use interactive lessons in the Learning tab that contain example code within the environment.
    • For more information about silent installations of individual NI products, refer to KB 4CJDP38M, Customize and Automate the Installation of a Single Installer.
    • For more information about silent installations of NI products in a suite, such as NI Developer Suite, refer to KB 4GGGDQH0, Customize and Automate the Installation of a Suited Installer.
    • To determine what version of NI Installers your product contains, refer to KB 4CJDR18M, Determine Type and Version of My NI Installer.
    © 2017-2019 National Instruments. All rights reserved.
    copyright
    End-User License Agreements and Third-Party Legal notices
    • notices are located in the \_Legal Information and directories.
    IVI Foundation copyright notice
    For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent notice at ni.com/patents.
    376808E-01
    GMT+8, 2025-7-25 11:18
