查看: 3150|回复: 0
[LabVIEW] LabVIEW NXG2.0 下一代LabVIEW编程平台NXG2.0版在线/离线安装版
    12 小时前
  • 签到天数: 3528 天
    发表于 2019-12-16 09:50:19 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW NXG
    LabVIEW NXG使工程师能够快速自动化硬件、根据项目规格自定义测试,以及轻松查看测量结果。
    LabVIEW NXG是下一代LabVIEW开发软件。LabVIEW让您只需使用一种工具即可配置、自动化和可视化数据。该软件可自动管理NI和第三方仪器驱动,帮助您快速开始首次测量,从而专注于使用集成的拖放逻辑设计方法以
    及内含的数学、信号处理和分析IP来快速定制您的系统。LabVIEW NXG可以将使用其他软件和开源语言编写的代码与第三方软件互操作工具集成。您还可以直观地设计用户界面,以操作测试和测量系统并查看结果。
    NI官方下载地址、百度网盘下载地址提取码等,请购买附件下载:
    购买附件下载
    NXG2.0.txt (448 Bytes, 下载次数: 51, 售价: 10 元)
    LabVIEW NXG 2.0 Readme
    January 2018
    This file contains important information about LabVIEW NXG, including system requirements and known issues.
    Use LabVIEW NXG to automate benchtop measurements using NI data acquisition hardware and benchtop instruments. Start taking measurements quickly with interactive panels to acquire and visualize data sets. When you need more customization, you can create your own applications using the graphical programming environment.
    LabVIEW NXG has the following minimum system requirements:
    • 64-bit version of Windows 10/8.11/7 SP12
    • 4 GB disk space
    • 4 GB RAM
    • .NET Framework 4.6.2
    • 1024 x 768 resolution (1366 x 768 or higher recommended)
    1 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 requires Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    LabVIEW NXG 2.0 adds new functionality to the previous release. Refer to LabVIEW NXG 2.0 New Features and Changes for a list of new features and changes.
    You can access the software and documentation known issues list online. Refer to the Community on the NI website for an up-to-date list of known issues in LabVIEW NXG.
    Search for items using the search bar in the upper right corner of the LabVIEW window.
    View context help in LabVIEW NXG by pressing and hovering over an object. Refer to the LabVIEW NXG Help, accessible from Help»Online Help, for more information about LabVIEW NXG.
    To learn the theory behind the code, use interactive lessons in the Learning tab that contain example code within the environment.
    © 2017-2018 National Instruments. All rights reserved.
    copyright
    End-User License Agreements and Third-Party Legal notices
    • notices are located in the \_Legal Information and directories.
    IVI Foundation copyright notice
    For patents covering the NI products/technology, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your media, or the NI Patent notice at ni.com/patents.
    376808C-01
    GMT+8, 2025-4-29 20:43
