查看: 125617|回复: 169
[LV工具模块] NI Vision Development Module 2019 Win32/64Eng 视觉开发模块VDM2019 适用LabVIEW2019
  • 签到天数: 3829 天
    连续签到: 22 天
    发表于 2019-5-27 15:29:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    2019年5月发布。NI VISION视觉开发包,图像处理库,32位与64位英文版本。可选择离线安装版本下载。注意,VDM2019版及以后版本,视觉开发环境与运行环境将不再支持.NET,即在视觉助手中,不能生成.net代码。也不能用于.net环境中调用NI VISION函数。如需要.net环境调用NI VISION,请使用VDM2018SP1及以前版本,详情可查阅后面的自述文件。
    支持操作系统:
    Windows 7 (SP1) 32-bit
    Windows 7 (SP1) 64-bit
    Windows 8.1 32-bit
    Windows 8.1 64-bit
    Windows 10 32-bit
    Windows Server 2012 R2 64-bit
    即要求最低WIN7SP1,对于WIN7、WIN VISTA、WIN XP已经不再支持。
    支持的LabVIEW与LabVIEW NXG版本:
    NI Application Software
    Versions Supported by NI Vision Development Module
    NI LabVIEW
    2016, 2017, 2018, 2019
    NI LabVIEW Real-Time Module
    NI LabVIEW FPGA Module
    NI LabWindows™/CVI™
    2013, 2015, 2017, 2019
    NI LabVIEW NXG
    3.1
    LabVIEW2015SP1及以前版本不再支持
    NI在线安装文件地址(NI官方推荐方式):3.6M
    请购买附件下载查看
    离线ISO下载地址:2.69GB
    请购买附件下载查看
    VDM2019.txt (635 Bytes, 下载次数: 145, 售价: 10 圆)
    NI Vision Development Module 2019 Readme
    March 2019
    This file contains important information about National Instruments Vision Development Module, including installation instructions, new features, fixed issues, and known issues.
    LabVIEW NXG Support and Considerations
    Deprecated Features
    Updates and Improvements
    How to Activate the NI Vision License
    Deploying Vision Applications
    Documentation and Examples
    External Library Support
    The NI Vision Development Module (VDM) provides hundreds of image processing and machine vision functions. Along with programming libraries, the NI Vision Development Module also includes NI Vision Assistant. Installing this software may remove previous versions of the NI Vision Development Module that are currently installed.
    Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
    For information about licensing NI Vision software, visit ni.com/info and enter the Info Code LicenseVision. Refer to the NI Vision website at ni.com/labview/vision for the latest information about the NI Vision Development Module.
    The development computer must meet the following system requirements to run the NI Vision Development Module.
    MinimumRecommended
    Processor233 MHz Pentium or equivalentPentium 4/M or equivalent
    Memory256 MB RAM512 MB RAM
    Display (Vision Assistant)1,152 × 864 resolution video adapter with a 16-bit display1,152 × 864 resolution video adapter with a 24- or 32-bit display
    Display (other environments)1,024 × 768 resolution video adapter with a 16-bit display1,024 × 768 resolution video adapter with a 24- or 32-bit display
    Free Hard Disk Space
    3.2 GB
    NI Vision Development Module 2019 supports the following operating systems:
    • Windows 10 (32- and 64-bit)
    • Windows 10 IoT Enterprise LTSB 2016 (64-bit)3
    • Windows 8.1 (32- and 64-bit)1
    • Windows 7 SP1 (32- and 64-bit)2
    • Windows Embedded Standard 7 SP1(32- and 64-bit)2,3
    • Windows Server 2012 R2 (64-bit)1
    • Windows Server 2008 R2 SP1 (64-bit)2
    Note: In 2016 NI Vision Development Module dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI Vision Development Module 2019 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Vision Development Module 2019 to an unsupported OS. Additionally, after installing NI Vision Development Module 2019, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Note: Support for Windows 32-bit operating systems may require disabling physical address extension (PAE). To learn how this might affect your system and what actions you might need to take, visit ni.com/info and enter the Info Code PAESupport.
    3Only supported as pre-installed on NI hardware.
    The following table lists the NI application software versions, including service packs, supported by the NI Vision Development Module. The installer specifically allows side-by-side installations of Vision Development Module for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, or any other supported development environment, before installing the NI Vision Development Module.
    NI Application SoftwareVersions Supported by NI Vision Development Module
    NI LabVIEW
    NI LabWindows™/CVI™
    NI LabVIEW NXG
    3.1
    NI Vision Development Module .NET Support
    NI Vision Development Module 2013 SP1 was the last version to release updated support for the .NET Framework 1.1, .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported. Development and runtime support for .NET features are no longer included with NI Vision Development Module 2019 and later.
    NI Vision Development Module FPGA Support
    For more information and the complete list of Vision functions and hardware supported on FPGA, visit ni.com/info and enter the Info Code VisionFPGASupport.
    The following sections detail considerations for using NI Vision Development Module with LabVIEW NXG.
    LabVIEW NXG Operating Systems and Requirements
    • Operating system—Only 64-bit operating systems are supported.
    Note: Refer to the LabVIEW NXG Readme for additional system requirements.
    Changes in VDM Supported in LabVIEW NXG
    For information about VDM support in LabVIEW NXG, visit ni.com/info and enter the Info Code VisionNXGGuide.
    Installing Vision Development Module for LabVIEW NXG
    LabVIEW NXG is installed using NI Package Manager. Complete the following steps to install Vision Development Module for LabVIEW NXG.
    • Visit ni.com/info and enter the info code NXGDownload to access the LabVIEW NXG download page.
    • Click Download LabVIEW NXG.
    • NI Package Manager installs, then automatically opens an installation window.
    • Select LabVIEW NXG 3.1 and NI Vision Development Module 2019.
    • Complete the installer instructions to download LabVIEW NXG and Vision Development Module support for LabVIEW NXG.
    LabVIEW NXG Help
    View context help in LabVIEW by pressing Ctrl+H and hovering over an object.
    LabVIEW NXG Examples
    New Features in Vision Development Module 2019
    The 2019 release of the Vision Development Module includes the following new features:
    • Deep Learning OpenVINO™ Support
      • Added new Deep Learning API (Under Machine Learning > Deep Learning) to support loading of OpenVINO™ models, Intermediate Representation (IR) format. The new VI added is IMAQ DL Model Create (OpenVINO).
      • Added support for executing the OpenVINO™ IR models.
      • Added Model Optimizer Support using python. Python scripts for converting models from Deep Learning frameworks like Tensorflow and Caffe to IR are provided. (More details about Model Optimizer and it's usage are available here: %NI_MO_INSTALL_PATH%\Readme.md and %NI_MO_INSTALL_PATH%\Readme.html).
      • The OpenVINO™ Inference APIs are supported on Linux RT, Windows.
      • Minimum Hardware configuration supported:
        • 2 GB DRAM
      • Windows Embedded Standard 7 is not supported.
    • Vision FPGA
      • Added support for Xilinx® Kintex® UltraScale™ FPGA IPs capable of processing 8 pixels in parallel, using the following VIs:
        • IMAQ FPGA AutoBThreshold ICV ROI U8x8_DRAM256x2
        • IMAQ FPGA AutoBThreshold ICV U8x8_DRAM256x2
    • Video Support Improvements
      • AVI Updates: Support for writing AVI files larger than 2 GB.
      • New Codecs Installed: VP8, VP9.
    • Support for parallel Match Pattern instances with the same template image.
    • Vision Assistant
      • Template Editor improvements
        • The Template Editor window is now resizable.
        • Template masking improvements - Masks can be modified and not committed immediately, new magic wand tool to mask areas.
        • New Auto Mask feature, detecting the object and masking the background automatically.
    Deprecated Features
    The 2019 release of the Vision Development Module removes support for the following:
    • LabVIEW Real-Time targets running VxWorks OS. For a list of LabVIEW Real-Time targets running VxWorks, visit the National Instruments website.
    • NI CVS-1457RT, CompactRIO, and CompactDAQ targets running Phar Lap ETS. For a list of CompactRIO and CompactDAQ targets running Phar Lap ETS, visit the National Instruments website.
    After upgrading to a later release, Vision Development Module 2018 SP1 (or older) can still be installed on VxWorks and Phar Lap ETS based vision targets assuming it was previously installed on the host computer.
    Refer to the National Instruments Website for an up-to-date list of all bug fixes in this release.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the NI Vision Development Module.
    Installation InstructionsInstalling from the LabVIEW Platform Suite
    If you purchased LabVIEW, you can install all of your LabVIEW products—including the NI Vision Development Module—using the LabVIEW Platform Suite.
    To request additional LabVIEW Platform Suite, refer to the National Instruments Web site.
    Installing from the NI Vision Development Module Installation Media
    Complete the following steps to install the NI Vision Development Module from the NI Vision Development Module installation media.
    • Insert the NI Vision Development Module installation media.
    • If you do not have autorun enabled, double-click autorun.exe. If you have autorun enabled, autorun.exe runs automatically.
    • (Optional) Activate NI Vision Development Module when prompted by the installer, or activate at a later time using the NI License Manager.
    When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision license through an Internet connection.
    • Run the product you want to license.
    • Click Yes when prompted to interactively activate your product.
    • Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
    • Enter the product serial number, and click Next.
    • Enter your registration information, and click Next.
    Tip: Enter your email address to receive a copy of your activation code for your records.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
    • The ability to create NI Vision Runtime installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or custom applications.
    • One NI Vision Runtime License, which allows you to install a custom application on a single machine.
    The NI Vision Development Module installer provides the runtime installer for NI Vision that can be packaged for redistribution by LabVIEW, CVI, or the standalone NI Package Builder. Visit ni.com to download software upgrades for NI Vision and the NI Vision Runtime installers.
    Purchasing NI Vision Deployment Licenses
    You must purchase an NI Vision Runtime License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Runtime directly from the NI Vision Development Module installation media. The NI Vision Development Module ships with one runtime license. Contact a National Instruments sales representative or visit ni.com to purchase additional runtime licenses.
    Note: Additional NI Vision Runtime licenses do not include installation media. To install additional licenses, use the original NI Vision Development Module installation media and the serial number provided by National Instruments.
    Using the NI Vision Runtime
    You can install the NI Vision Runtime with your application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can directly include the NI Vision Runtime.
    Refer to the LabVIEW Help for more information about the LabVIEW Application Builder. Refer to the NI LabWindows/CVI Help for more information about building and distributing LabWindows/CVI applications.
    You can use NI Package Builder to package your custom application installer along with the NI Vision Runtime installer. This may be useful if you are creating an installer for applications created in other development environments.
    The NI Vision Runtime installer may require the system to be restarted after installation. Refer to the Automating the Installation of NI Products section for more information on how to change the level of interactivity of the installer or whether it automatically initiates a system restart.
    Distributing LabVIEW Applications
    The NI Vision Runtime installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Runtime as part of the installation.
    Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Runtime.
    Distributing LabWindows/CVI Applications
    In addition to including the NI Vision Runtime with the installer, you must include the appropriate LabWindows/CVI Runtime. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    For more information, refer to the following Knowledge Base articles:
    The NI Vision Development Module supports the external vision library OpenCV. Refer to the National Instruments Web site to download the NI Vision OpenCV support utilities.
    NI Vision OpenCV support utilities enable the use of OpenCV algorithms in LabVIEW and NI Embedded hardware. NI Vision OpenCV support utilities provide:
    • Pre-built OpenCV binaries for Windows and NI Linux RT
    • C++ development files to create an interface between NI Vision Image and OpenCV Mat.
    • Utilities to create LabVIEW APIs to call OpenCV entry points.
    • LabVIEW examples.
    Documentation and examples are installed onto your hard drive with the NI Vision Development Module. To view the documentation, select Start»All Programs»National Instruments»Vision»Documentation»Vision Documentation, or navigate to \Public\Public Documents\National Instruments\Vision\Documentation.
    Refer to the National Instruments Product Manuals Library at ni.com/manuals for the most recent versions of product documentation.
    The following sections describe the documents available for each application development environment and where to find examples.
    • NI Vision Concepts Help—Describes the basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
    NI Vision for LabVIEW
    • NI Vision for LabVIEW Help—This document contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. It describes how to create machine vision and image processing applications in LabVIEW. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module, and how to use the Vision FPGA VIs with an FPGA target and the LabVIEW FPGA Module. You can access this help in LabVIEW by selecting Help»NI Vision for LabVIEW Help.
    • NI Vision for LabVIEW Examples—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. NI Vision examples for LabVIEW are installed to \examples\Vision and \examples\Vision FPGA, where is the location LabVIEW is installed.
    NI Vision for LabWindows/CVI
    • NI Vision C Support Help—Contains reference information about NI Vision C functions.
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at National Instruments\Shared\CVI\Bin\NIVision.lfp.
    • NI Vision LabWindows/CVI example programs are installed at \Public\Public Documents\National Instruments\CVI\samples\Vision.
    NI Vision for Eclipse and other Text-based Development Environments
    • Getting Started with C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition with the NI Vision Development Module and NI-IMAQdx—Describes how to use the C/C++ Development Tools for NI Linux Real-Time, Eclipse Edition to develop an example C application using the NI Vision Development Module API and/or NI-IMAQdx, and deploy it on a Linux remote target. This tutorial outlines the basic steps required to build and deploy an example application.
    • To view text-based example programs, select Start»All Programs»National Instruments»Vision»Examples»Vision Examples, or navigate to \Public\Public Documents\National Instruments\Vision\Examples.
    NI Vision Assistant
    • To access Vision Assistant documentation from the Start menu, select Start»All Programs»National Instruments»Vision»Documentation»Vision Assistant Documentation, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Documentation.
    • To access Vision Assistant examples from the Start menu, select Start»All Programs»National Instruments»Vision»Examples»Vision Assistant Examples, or navigate to \Public\Public Documents\National Instruments\Vision Assistant\Examples.
    • NI Vision Assistant Tutorial—Describes the Vision Assistant software interface and guides you through creating example image processing and machine vision applications.
    • NI Vision Assistant Help—Contains descriptions of Vision Assistant features and functions and provides instructions for using them. In Vision Assistant, select Help»Online Help.
    • NI Classification Training Interface Help—Contains information about how to use the NI Classification Training Interface to classify binary samples. In the NI Classification Training Interface, select Help»Online Help.
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
    • NI OCR Training Interface Help—Contains information about how to use the NI OCR Training Interface to learn characters, save character sets, and verify characters by comparing them to a reference character. In the NI OCR Training Interface, select Help»Online Help.
    • NI Texture Training Help—Contains information about how to use the NI Texture Training Interface to train a texture classifier file for use in texture defect detection applications. In the NI Texture Training Interface, select Help»Online Help.
    • NI Calibration Training Help—Contains information about how to use the NI Calibration Training Interface to select and create a calibration for use in machine vision applications. In the NI Calibration Training Interface, select Help»Online Help.
    • NI Vision Template Editor Help—Contains information about how to use the NI Vision Template Editor to learn and edit template images that you can use with pattern matching, geometric matching, and golden template comparison functions. In the NI Vision Template Editor, select Help»Online Help.
    • NI Flat Field Creation Wizard Help—Contains information about how to use the NI Flat Field Creation Wizard to create a dark or bright field image and perform flat field correction in a machine vision application. In the NI Vision Flat Field Creation Wizard, select Help»Online Help.
    © 2003-2019 National Instruments. All rights reserved.
    375127K-01
  • 签到天数: 10 天
    发表于 2019-9-3 10:29:47 | 显示全部楼层 来自:江苏省苏州市吴中区 电信
    NI Vision Development Module 2019 for LabVIEW2019 Win32/64Eng VDM2019视觉开发包适用32位/64位LV2019版下载
    NI LabVIEW Vision Development Module 2019 X86/X64 WinEng VDM离线ISO下载地址:2.69GB" d: d! X" \6 x: R" l  w
  • 签到天数: 4 天
    发表于 2019-5-27 16:53:51 | 显示全部楼层 来自:广东省深圳市 电信
    谢谢分享NI LabVIEW 2019
  • 签到天数: 4 天
    发表于 2019-5-27 17:43:36 | 显示全部楼层 来自:广东省深圳市南山区 电信
    给力给力,一年一更新中
  • 签到天数: 62 天
    [LV.6]600FPS
    发表于 2019-5-27 23:04:51 | 显示全部楼层 来自:山东省潍坊市 电信
    dsa;lfaksd;lfasd;lfk;asdkf;lasdkf;sadads
  • 签到天数: 36 天
    发表于 2019-5-28 15:00:31 | 显示全部楼层 来自:广东省 移动数据上网公共出口
    的所有可以听到啥文案通过它瓦尔
  • 签到天数: 11 天
    发表于 2019-5-28 20:00:32 | 显示全部楼层 来自:陕西省西安市 移动
    haohaoahoaahi
  • 签到天数: 7 天
    发表于 2019-5-29 09:28:38 | 显示全部楼层 来自:山东省临沂市 联通
    正是需要了,谢谢了
  • 签到天数: 13 天
    发表于 2019-5-29 13:46:15 | 显示全部楼层 来自:安徽省芜湖市 联通
    感谢楼主分享,再次学习一下:D
  • 签到天数: 2 天
    发表于 2019-5-29 16:48:31 | 显示全部楼层 来自:重庆市 电信
    学习一下学习一下学习一下
  • 签到天数: 7 天
    发表于 2019-5-29 18:42:31 | 显示全部楼层 来自:浙江省杭州市 电信
    安装完怎么打不开啊,是缺什么组件吗
    GMT+8, 2026-3-18 09:30
