查看: 3579|回复: 0
[LabVIEW] NI LabVIEW2011 Win64ENG 64位LV2011英文版下载
    昨天 09:25
  • 签到天数: 3629 天
    连续签到: 3 天
    发表于 2019-2-26 20:31:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    EXE版:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请注册视觉论坛会员登录后购买附件下载查看
    ZIP版:
    LV2011ENG64.txt (302 Bytes, 下载次数: 52, 售价: 10 圆)
    LabVIEW 2011 Readme for Windows
    Version 11.0.0
    June 2011
    This file contains important information about LabVIEW 2011 for Windows, including installation and upgrade issues, compatibility issues, a partial list of bugs fixed for LabVIEW 2011, changes from LabVIEW 2010 and related service packs, and a link to the Web page that contains known issues for LabVIEW.
    Refer to the LabVIEW Upgrade Notes for more information about upgrade and compatibility issues and a complete list of new features in LabVIEW 2011. Refer to the LabVIEW Release Notes for installation instructions and a complete list of system requirements. After you install LabVIEW, refer to the labview\manuals directory to access these documents. You also can access the LabVIEW Release Notes and LabVIEW Upgrade Notes at ni.com.
    Refer to the National Instruments Web site for the latest information about LabVIEW 2011.
    Installing LabVIEW 2011
    Installing Another Language Version
    Licensing
    LabVIEW 2011 (64-bit)
    Additions to the LabVIEW Help
    Notice Regarding Microsoft Silverlight Installation and Redistribution
    If you have a previous version of LabVIEW installed, you can install LabVIEW 2011 without uninstalling the other version. In this instance, LabVIEW 2011 does not replace the previous version of LabVIEW, which remains installed.
    Refer to the LabVIEW Release Notes for more information about installing LabVIEW on Windows.
    If you have installed another language version of LabVIEW 2011, uninstall that version before you install the new language version.
    Licensing
    LabVIEW relies on licensing activation. You must activate a valid LabVIEW license before you can run LabVIEW. To activate the license, use the serial number you received as part of your installation package.
    Refer to the LabVIEW Release Notes for more information about licensing in LabVIEW.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in LabVIEW 2011.
    When run on Windows (64-bit), LabVIEW 2011 (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW 2011 (64-bit) includes nearly all of the development environment features of LabVIEW 2011 (32-bit).
    Refer to the National Instruments Web site for information about obtaining a copy of LabVIEW 2011 (64-bit).
    LabVIEW 2011 (64-bit) supports many hardware devices. Drivers are available for DAQ devices, VISA devices, GPIB devices, and image acquisition devices. For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW 2011 (64-bit).
    Supported Modules
    LabVIEW 2011 (64-bit) supports only the NI Vision Development Module. Refer to the Vision Development Module documentation for more information. LabVIEW 2011 (64-bit) does not support any additional modules.
    The following list contains additional changes to LabVIEW that are not included in the LabVIEW Help, the LabVIEW Upgrade Notes, or both:
    • In previous versions of LabVIEW, the NewRange event data field for the Scale Range Change event ignores custom offset and multiplier values you set for a graph or chart. In LabVIEW 2011, the NewRange event data field factors in custom offset and multiplier values in the results it returns. In previous versions of LabVIEW, if you use code to work around this issue, you need to update the code in LabVIEW 2011.
    The following table contains the IDs and titles of a subset of issues fixed in LabVIEW 2011. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    IDLegacy IDFixed Issue
    3491846L911BHPrint quality degradation
    3509347KA4N6SIncorrect behavior of multiple axis autoscaling on XY Graph: inadvertent activation of autoscaling on second axis.
    354023I89TJXLFrivolous 'Highs' in Digital Waveform Graph
    354323MSAIG00Charts draw strange lines after being minimized and restored.
    35895447GDT2AWFChart property LegPlots crashes LabVIEW if VI is reentrant and multiple copies are run
    405064BMF48ZLWrite Data Express VI incorrectly interprets and writes time for a waveform
    415774DO8EDE8Defer Panel Updates can cause Waveform Chart to redraw improperly
    431094FRF0826Cannot customize plot legend with background image in LabVIEW
    433554G5A3L00Incorrect scaling for "Scale range change" event
    436714GID11F2Opening VI Properties Window takes a long time
    441884H9BHC00Maximized is no longer maximized after the Leopard (Mac OS X 10.5.1) upgrade
    447844HMB2RF2Value Property of DAQmx Channel empty if control saved off screen
    458024IDA53I0Using VI Server Get/Set [Variant] Control Values on Clusters with Fixed Size Arrays creates error 2
    466032W2BLNNREditing an array of clusters with fixed size strings has incorrect behavior and results in internal errors.
    476573LBBNK8VMoving array in and out of cluster increases memory usage
    486033UEFJ2V2Insane object when saving a VI after executing a Value Change event for a specific control
    5004642BFUN8QSVE stops updating variables when third computer connects to the engine
    5035544A7PAR0Intermittent crash using Delete From Array - Fatal Internal Error: "memory.cpp", line 638
    5067746108800XControl remains locked after leaving memory
    521794ADJODJCTimestamp control does not accept values between 1970/1/1 0:00:00 and 1970/1/1 8:59:59 when in the Tokyo time zone
    640924B0KD2M5Read From Measurement File Express VI changes file extension
    101680Scrollbars of subPanel VI crash LabVIEW if you are trying to type text at the same time
    108531XY Graph shows incomplete graph when using specific point-style and having NaN data
    117209Bundle by Name does not break VI when fields from the input cluster's typedef are deleted
    118106Variant To Flattened String and Flattened String To Variant do not support Fixed Point data type
    118949Tab control local variables generate value change events when you use a multicolumn listbox
    123313Unnecessary IAK file checked into source code control
    124866FPDCO.cpp line 54: Variant to Flattened String crashes LabVIEW with clusters of 54 typedefs
    125593Front Panel updates are processed one at a time in a Property Node - XY Graphs
    125834Unexpected coercion with feedback node
    125907In the new 3D Graph, a transparent cursor plane hides the 3D surface graph
    128512Autoscaling a graph on a tab control does not work unless visible
    128871Disable color ramp interpolation in XControl 3D Graph in LabVIEW 8.6 not working.
    129830String outputs from flattening can differ between LabVIEW 8.5 and LabVIEW 8.6
    130365Upgraded digital waveform graph causes Exception
    130376Digital waveform graph does not show up in Context Help in the block diagram
    132771LabVIEW 8.6 graphobj.cpp on line 66 error when attempting to scroll on a front panel
    135150Unexpected behavior on MixedGraph Cursor and Watch All Plots Property Nodes
    144663RT OSes allow for only 1 remote front panel connection even if additional licenses are installed
    144813LabVIEW hangs when window mode is set to "Floating" and timestamp control browse button is pressed
    147187Crash using XScale Info or YScale Info graph properties
    148149Event Structure Cases can incorrectly remap to other dynamic events
    148398Key Focus is lost when programmatically changing the tip strip
    148616IMAQ Image Control options not available in executable
    151166Scale.cpp, line 2769 when opening XY Graph (Word).vi
    154260Context Help does not update for controls or indicators placed in a tab control on front panel
    156873Chart does not update properly, shows gaps in data
    156938Read From Measurement File Express VI (LVM, Absolute Time) shows wrong timestamp on secondary waveforms
    157042App.Kind Property in Web Service Reports Development Environment
    158083Numeric support.cpp line 88 error when editing ring control
    161519Connector pane of Create SubVI From Selection should be 4x2x2x4 or whatever is set in config
    162800Wait on Notification from Multiple returns inconsistent results when multiple refnums refer to same named notifier
    163754Issue on X cursor position depending on the zoom of the waveform graph.
    164268Tab control incorrectly displays ComponentWorks 3D Graph when other tabs are selected "Page Labels Display"
    164604Calling LabVIEW built .NET Interop Assembly from same version of LabVIEW causes a hang
    165690Corrupt typedef or a typedef that is not updated is not detected by LabVIEW and causes crash
    169208Compiler error. Bad type A
    169600VI produces error -2570 when flushing TDMS file
    170713LabVIEW 8.6 error log file: drawmgr.cpp line 2921
    176856VI Snippet of a VI with dynamic inputs results in a LabVIEW crash
    178185LabVIEW crashes in multicolumn listbox when right-clicking a cell
    178273"Must Override" doesn't break descendant classes if ancestor implementation is renamed
    178567Hiding and showing captions deletes caption text
    178757The variable dialog does not allow users to enter a logging deadband with precision less than 10^-5
    179603Dynamic dispatch input to Call Parent Method can cause broken run arrow
    182002Event structures with XControl facade VI-specific events cause compile errors in normal VIs
    182466LabVIEW 8.6.1 error log file: lvmain.cpp line 447
    182952Cannot delete files in Files View of LVLIB when outside of a project
    183011LabVIEW crashes with ThEvent.cpp line 233
    183414Show Buffer Allocation tool does not identify feedback nodes in LabVIEW 2009
    185059Member VIs of a class that is a member of a project library have a red X on them in the palettes
    185191Value change events for bound shared variables
    185958Plot chart delay when using Delay Panel Update property node
    186104LabVIEW 2009 error log file: xstuffprivate.cpp line 2711
    186615Write to Measurement File Express VI slows when given larger amounts of data
    186972Compiler Error copy cvt str/pict/tag, csrc = 0x32
    187247ActiveX functions return error 1 if using a 64-bit integer
    187332LabVIEW 2009 32-bit error log file: setstate.cpp line 4046
    187690LabVIEW 2009 error log file: undo.cpp line 985
    187859Mixed Signal Graph cursor style is not applied to entire graph
    188530Changing data type in numeric control/constant/indicator property pages does not update other panes
    189327Writing blank array of data to 3D Graph does not clear graph unless you force a redraw.
    189418Open and close empty TDMS file will delete file
    191423LabVIEW does not execute properly when scrollbars on the .NET RichTextBox control are set
    192280Open UFF58 VI will cause a hang if built into an application
    193027Crash on undo when undoing a deletion of a wire with a breakpoint
    194339AM/PM section of timestamp control is always reset to 'AM' when any value in timestamp control is changed on Korean user locale
    194845Diagram Disable Over Call Library Function with missing DLL function causes broken run arrow
    195376Performance improvement in loops
    198232Hexadecimal option grayed out for dial control but advanced allows Hex
    202356.NET Constructor Node with Controls and Indicators does not get added using VI Snippet
    202702RT Remote Panel license is not released when tab or browser window is closed
    202959VIs in vi.lib with path inputs should show the Browse button
    204964Y Scale Range Start is glitchy with incorrect behavior on a waveform chart
    205020TDMS read.vi returns an error -2532 if executed twice with TDMS files that have different group names
    206275Delete From Array sometimes does not create memory copy correctly
    207352Moving a .NET Assembly while LabVIEW is open will cause an error the next time it is called from LabVIEW.
    207438Issues with .NET property node linkage
    208365Active subVI from exe loses "active" status when different program is maximized
    211323Auto Error Handling setting in App Builder does not appear to do anything for EXEs
    211544The Show Buffer Allocation tool does not indicate allocation in a disabled structure
    211565Calling Library.Save a Copy crashes LabVIEW
    212777Multi-plot cursor needs changes to work on non-MSG Graphs
    213565VI with MathScript inside Diagram Disable opens as broken if unlicensed
    213702Strip Chart drawing gets messed up with Defer Panel Updates
    214860Build path too long when building application
    215290When RT-FIFO network variable hits corner-case warnings that are positive error codes, they are returned as undefined negative error codes
    215683Statistics Express VI: Kurtosis output inconsistent with TSA Skewness and Kurtosis VI output
    216011VI Analyzer Toolkit 2010 does not load VI Analyzer Toolkit 1.1 .cfg files correctly
    216715LabVIEW 64-bit hangs when clicking on front panel with locked decoration covered by cluster with indicator or control
    2186273D Pie and 3D Bar Plot Size change between VI loads
    2190452D Error Bar Plot Line Marker and Point/Fill Color Options unable to be changed from plot legend
    221992LabVIEW Constructor node cannot load DLLs written in .NET 4.0
    222274Wait for Rendezvous.vi causes deadlock due to improper error handling
    222275Improper error handling inside Release Waiting Procs.vi
    222276Queue reference can go invalid when using Wait at Rendezvous
    222395Zero Phase Filter VI - init/cont input does not change filter output
    223244"File is not a resource file." popup on a built app
    225112Installer Builder preferences take a long time to open
    226856Sound input VIs - cannot start sound again after stopping sound
    227177Creating second VI with Scilab Node hangs LabVIEW
    230644LabVIEW 2009 crashes when loading .NET assembly with Turkish Regional Settings
    230671Save for Previous with Call Library Function Node causes LabVIEW crash
    230799Crash on exit in process which calls a LabVIEW-built shared library on Linux
    231024Network Streams do not support Fixed Point range and delta
    231320XY Graph does not have label for the two elements in its cluster
    231877Polymorphic VIs with "Adapt to Type" set can choose wrong instance VI
    231900LabVIEW.exe crashes on Aplex TPC-3511T Computer
    232466Replace with Programmatic Access is misleading for RT FIFO Enabled Shared Variables
    232512Web service output of timestamp is formatted incorrectly on French
    233205Network Streams do not support enums, data types with units, substrings, subarrays, and fixed-size arrays
    233209An array of Stream refnums can incorrectly display access type
    233588Writing an empty 2D array to disk with the TDMS-API causes LabVIEW to crash
    233778LabVIEW Shared Libraries built on Mac mess up the app that loads them
    233986LabVIEW crashes when using the Save As option for a class
    234411RT Web Service Build error 1502
    235257Edit Palette Set window gets stuck behind Getting Started window
    235357GetAllDescendents ActiveX Method returns an empty array when wiring nothing to the Types input
    235446LabVIEW Installer does not install .NET support if only .NET 4.0 is installed.
    235737Cannot select and drag anything within Icon Editor anymore
    235775LabVIEW crashes in assembly deployment if lkads.exe is not running on Vista/Windows 7
    236257LabVIEW crashes when replacing a CXT numeric control with another numeric control
    237173Adding library with missing owner to a project aborts LabVIEW
    237213Event registration refnum of typedef does not update when typedef updates
    238284.NET and ActiveX Controls remain on subsequent tabs when using the Page Labels Display
    238868Unescape HTTP URL.vi adds an extra \00 at the end of the string
    239017Synchronizing Icon Library in LabVIEW 2009 SP1 gives Error 42
    239302LabVIEW 2009 32-bit error log file: image.cpp line 5144 when reverting polymorphic VI
    239362New Data Member Access Wizard puts new terminal in the wrong place
    239710LabVIEW 2009 64-bit error log file: drawmgr.cpp line 2548
    240938Typedef links aren't maintained when using the Replace with Programmatic Access right-click option on Variable Nodes
    242033Strictly typed VI References created in LabVIEW 2010 do not match references created in LabVIEW 2009
    242227LabVIEW-built .NET assembly function hangs if it opens a modal dialog
    242600A search dialog can appear when building a source distribution where the main destination is a library
    242612Problem of overwriting of output folders of installers built with LabVIEW 2009/2010 Japanese
    242702Arrays of clusters do not work correctly with LabVIEW-built .NET Interop Assemblies
    243036LabVIEW 2009 32-bit error log file: wiretbl.cpp line 3530
    243334Ctrl-A does not select wire labels
    243927Property cannot be used until after project is restarted
    244005Remote front panels exceeds maximum number of licenses for LabVIEW 2009 SP1 and RT target (cRIO-9022)
    244201XY Graph plot legend causes panelsup.cpp line 551 error
    244357Adding numeric ranges in case structure selector results in fpsane.cpp(442) error
    244492Add XML File IO VIs to File IO Palette when on a Real-Time Target
    245132LabVIEW 3D picture control renders textures incorrectly
    245285Run-Time Engine Web Server must be selected as an additional installer for NILVWSPostInstallerScript.exe to be included in installer
    245293LabVIEW 2010 32-bit error log file: compiler.cpp line 447
    245508A VI with a build array in a certain configuration crashes LabVIEW 2010
    246179TCP Listen does not work reliably when using dynamic port assignment
    246637Quick drop shortcuts do not work in localized (German) LabVIEW
    247479Inplace structure does not update after changing in a Class Typedef cluster
    248113Crash with Base LabVIEW OOP object variants and flatten string
    248965Deploying an executable that uses SSL with the HTTP Client API will error out
    248978Unflatten from String crashes LabVIEW 8.2.1 and LabVIEW 8.5, using a flattened string saved in LabVIEW 2010
    249370In LabVIEW 2010 on a Mac, you cannot save VIs with the .vit and .ctt file extensions
    249939Error 1562 when building an app that uses a locked, unreferenced class.
    250348LabVIEW 2010 32-bit error log file: compiler.cpp line 447
    250355VISA Read's 'Byte Count' input of high value can crash LabVIEW
    250745Incorrect behavior of Interpolate 2D function in LabVIEW 2010
    251094HTTP post reports error 42 when executing a FSWS download with a 1MB file
    251371Crash when moving a section of code with arrow key
    251607LabVIEW crashes when removing a shared variable then a library
    251728Unexpected error dialog when using path to a new file with Read From XML File.vi
    251754LabVIEW 8.5.1 error log file:StdGraph.cpp line 8807
    252630For Loop with parallelism enabled causes dataflow to not be enforced
    253283Problems showing the Visible Items»Display Style menu option on many front panel strings
    253348Mark Project VIs in big project (<1000 VIs) closes directly after opening.
    253700LabVIEW 2010.0f2 32-bit error log file: PatchLVRTRefs.cpp, line 80
    253708LVClassControl:ReplaceWithControlOfOtherClass crashes when outgoing control ref is unwired
    254158Certain settings on a Cursor List Graph property node crash LabVIEW without notice.
    255014Probes are listed as Not Executed intermittently on Real-Time target
    255059VI crashes LabVIEW when opened
    255066LabVIEW 2010 crash replacing system combo box with Modern, Values Match Items checkbox
    255155Compiler error when wiring a string array to subVI that expects variant data
    256559Including .vi in web method name and using "?" as a query separator causes app web server to crash
    256981Strange behavior with zero phase filter with certain frequency and order values
    257063Exec.cpp line 509 when calling class VI.
    257244File Dialog Pattern Match does not work on Mac OS X 10.6.4
    257405Source dists have bad links to class methods inside of packed libraries when lvlibp is targeted to another directory
    257593Crash after switching to the block diagram
    257713Child Class Property Node does not output until deleting and rewiring any part of the VI
    257729LabVIEW 2009 project causes hard LabVIEW crash when opened in LabVIEW 2010
    257888Repeatable diagram cleanup crash with specific VI
    257922Child override VI can be given a different scope from its parent when folders are used in the class
    258033Selecting a locked cluster in LabVIEW 2010 (64 bit) causes LabVIEW to crash
    258135LabVIEW 2010 32-bit error log file: fpsane.cpp line 442
    258485FTP VIs do not close session if there is an error
    258691LabVIEW 2010 Visual C++ Runtime crash with Network Streams API and custom control
    258694GPS Toolkit 1.5 installed with DAQmx causes Application Builder not to include dependencies in Windows XP
    258721LabVIEW crashes when VI with a class reference is called with suspend flag via Active X and LabVIEW is closed
    258839Right-click on property nodes and re-link them doesn't work
    275825LabVIEW aborts when changing representation of a typedef - datamgr.cpp line 2720
    276334On VxWorks targets, the TDMS Defragment VI shows Error 6 and deletes the file it is operating on in the U:\ drive
    276811Icon Editor templates grayed out
    277004Block diagram constants from enum change value after adding element to the end. Clearing Object Cache reverts value.
    277049Changing a missing type definition control to a constant crashes LabVIEW
    277392Typecast of object with different binary size may crash LabVIEW
    277631LabVIEW 2010 32-bit error log file: objprop.cpp line 6145
    277725LabVIEW 2010 Application Builder TARGETDIR not specified when building installer with absolute path
    277728Changing missing typedef constant to control crashes LabVIEW
    277796Network Streams do not handle cluster data types appropriately at edit time
    277979Merge Error node Terminal Names property returns incorrect names
    278029Changing a case selector from I64 to U32 can cause a corruption
    278100Parallel For Loop produces incorrect results on some runs
    278143Different .NET invoke node errors in different LabVIEW versions when output is not wired
    278559Nested classes in a packed project library breaks a VxWorks VI.
    278592LabVIEW crashes when creating control/indicator/constant from a Property Node with LabVIEW Class type when accessor VI is missing front panel
    278697Aborting a VI call made from TestStand does not work when highlight execution is enabled.
    278878LabVIEW 2010 32-bit error log file: drawmgr.cpp line 2955
    278922Saving particular VI causes LabVIEW to hang
    279050Create indicator on auto-indexed Detect Parallel Loops method.
    279526LabVIEW crashes when no indicator on ReplaceWithControlOfOtherClass scripting method
    279670Child cannot use Property Node for an inherited parent property
    279691Files in Source Files view disappear after deleting a folder when configuring an installer
    280940Converting a VT_DATE to a LabVIEW timestamps corrupts the date
    280980Overriding properties in a localized class may break class
    281124Nested diagram disable structures can cause LabVIEW to not compile.
    281278LabVIEW crashes when placing a class within a class
    281324LabVIEW 2010 32-bit error log file: OMUDClass.cpp line 3367
    281409Load STL Geometry.vi opens a file dialog whenever loading a read-only file.
    281445LabVIEW 2010 error log file: HeapObjMapImpl.cpp line 227
    282048SubVI closes if main VI is open and the Project execution target will be changed via context menu
    282278Creating Event Registration Refnum indicators using VI server appear with different user event refnum type
    282333In Range primitive does not work correctly for cluster inputs
    282567LabVIEW 2010 32-bit error log file: LinkObj.cpp line 669
    282849Diffing VI which uses a missing class crashes LabVIEW
    283001VISA and GPIB read/write primitives not respecting async flag
    283248Multivariable Editor crashes when editing variable properties
    283265Inlining a VI with a Register for Events node causes calling VIs to crash LabVIEW
    283381LabVIEW 2010 Installer Build Spec: exe files cannot be added
    283671Graph does not update after a multi-plot cursor is removed programmatically using the Cursor List property
    283754Logos XT can hang if the Connection::message_queue_ becomes full
    283773Multi-property property nodes on a VI which needs typeprop can crash LabVIEW
    283895Shared Variable API never connects to variables in a process with an IO server
    284156HTTP Client creates a new session cookie for each call of a HTTP method
    284204Remove passwords from Open or Close VI.vi and _LaunchHelp.vi in Call DLL.vi shipping example
    284534Source distributions link incorrectly against classes inside of packed libraries
    284688Japanese LabVIEW 2010 SP1 fails to launch when a third-party toolkit is installed.
    284737Add array item to waveform graph displays error message
    285371Logos XT can hang when ACE internal message socket queue becomes full
    285763Default Installation directory is removed after deleting a folder in an Installer Destination tree
    285876Export to DIAdem menu inserts random zeros in the temporary TDMS file
    285887Crash when running parallel instances of General Histogram.vi
    286063LabVIEW 2010 SP1 can crash when trying to print preview
    286309VI exits when done running, when opened through TestStand, and Show VI front panel when called is checked
    286361Get Properties.vi has incorrect generated code
    286392VI and EXE crash with Internal Error 566, MemoryManager.cpp
    286480LabVIEW crash with Feedback Node U32-Initialized Setup
    286975App Builder incorrectly claims a 255 character path limitation for Windows
    287942Libraries containing .mnu files saved in LLBs fail to find the .mnu
    288018Export Data to Excel does not properly export Absolute Time from waveform chart
    288290MemoryManager.cpp, line 566 when ctrl + drag and drop items in a multi column list box in LabVIEW 2010
    288454LabVIEW 2010 32-bit error log file: image.cpp line 5173
    288773Running Complex Formula Node in Parallel with Two "A x B.vi" Crashes LabVIEW
    288967Error 0xFFFEF84D when deploying a Web Service build containing a CD Convert Continuous to Discrete VI
    288971Error 0xFFFEF84D when deploying a Web Service build containing a specific MathScript node
    289559Dynamically launching reentrant VIs is slower and requires more memory.
    289749Cannot deploy web services after upgrading to LabVIEW 2010 SP1
    289765Icon layers are not persistent
    289826Custom item symbols for tree control get corrupt after saving, closing, and reopening
    290464Resetting or clearing an XY Graph cursor list programmatically does not work correctly
    290976LabVIEW crashes when auto-indexing tunnel is connected to case selector
    290985ActiveX container has broken dependency on VC runtime
    291046LabVIEW does not detect spaces in the TDMS channel name
    291422Installer Builder should prevent user from using illegal file name
    292464The function GaussHG returns NaN for X values less than 0.
    292591Indicator in LabVIEW 2010 subVI does not update from local variable in a sequence except in highlight execution.
    292603In Place Element Structure with Add In Place In/Out inside any loop structure causes a crash
    292642Reading Bus and BusOpen properties on digital waveform graph crashes LabVIEW
    292700Projection palette has an odd square when set to a different color
    2928303D plot axis range does not support arbitrary input when log scale
    292948LabVIEW Properties menu starts search for ni_security_salapi.dll
    293013MathScript command "kalman" does not work properly for a discrete-time system
    293077Front Panel is decoupled from block diagram. Data not shared between them
    293177Add SCC Exclusion Folder Check to VI Analyzer
    294466Waveform chart does not work when placed in a cluster of clusters
    294891Reading a variable with a 0 timeout is significantly slower than reading with timeouts disabled
    295601Variable causes type prop repeatedly when VI is loaded
    295719Case structure selects wrong case if input is large I64 number
    296308Copy and paste bundle of classes across context crashes LabVIEW
    2965042D Compass Plot control does not save the size
    299134DAQmx hang when clearing tasks in certain situations
    299330Add primitive with timestamp and fxp numeric crashes LabVIEW
    299532LabVIEW crashes upon save when VI has labeled wire inside structure
    302986Cannot view or move source files in installer specification
    Using Microsoft Silverlight
    © 2004–2011 National Instruments Corporation. All rights reserved.
    For copyright notices, conditions, and disclaimers, including information regarding certain third-party components used in LabVIEW, refer to the Copyright topic of the LabVIEW Help.
    LabVIEW, National Instruments, NI, ni.com, LabVIEW, the National Instruments corporate logo, and the Eagle logo are trademarks of National Instruments Corporation. Refer to the Trademark Information at ni.com/trademarks for other National Instruments trademarks.
    GMT+8, 2025-8-21 02:21
