查看: 4100|回复: 0
[LabVIEW] NI LabVIEW 2017 SP1 Win64ENG 64位LV2017SP1英语版下载
  • 签到天数: 3602 天
    连续签到: 10 天
    发表于 2018-12-31 16:45:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    2018年1月更新发布LabVIEW2017SP1版。LabVIEW2017SP1共发布了64位英文版、32位英文版、32位中文版、32位日文版、32位韩文版、32位法语版、32位德语版以及MAC系统版本等多个版本。请根据需要选择不同的版本安装。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    直接下载:
    请购买附件下载查看
    VIPM安装版:
    请购买附件下载查看
    LV2017SP1ENG64.txt (606 Bytes, 下载次数: 40, 售价: 10 元)
    LabVIEW 2017 Service Pack 1 Readme for Windows
    September 2017
    This file contains important information about LabVIEW 2017 Service Pack 1 (SP1) for Windows, including system requirements, installation instructions, known issues, and a partial list of bugs fixed for LabVIEW 2017 SP1.
    LabVIEW 2017 SP1 (64-bit)
    LabVIEW 2017 SP1 has the following requirements:
    WindowsRun-Time EngineDevelopment Environment
    Operating SystemWindows 10 (version 1703)/8.12/7 SP13
    Windows Server 2012 R22 (64-bit)
    Windows Server 2008 R2 SP13 (64-bit)
    1 LabVIEW and LabVIEW Run-Time Engine require processors of the Pentium 4M/G1 generation or later, which are capable of executing SSE2 instructions.
    2 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    3 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Note
    • You cannot access LabVIEW using a Guest account on Windows.
    • In 2016 LabVIEW dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. LabVIEW 2017 SP1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use LabVIEW 2017 SP1 to an unsupported OS. Additionally, after installing LabVIEW 2017 SP1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does my LabVIEW, LabWindows/CVI, Measurement Studio, or TestStand Built Installer Fail on Windows XP/Vista and Server 2003?.
    Complete the following steps to install and activate LabVIEW for Windows.
    Are you installing LabVIEW for the first time? Insert the LabVIEW Platform media and follow the onscreen instructions to install LabVIEW, modules, toolkits, and drivers. When prompted, enter the serial number for each product you want to activate. Your serial number can be found at ni.com/myproducts. If you are managing your license with a volume license server, you should receive your volume license file by email.
    Are you upgrading from a previous version of LabVIEW? Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2017.
    Note  Starting from 2017, LabVIEW supports backward compatibility for the LabVIEW Run-Time Engine. Versions of LabVIEW later than 2017 can load binaries and VIs built with LabVIEW 2017 without recompiling. This improvement applies to stand-alone applications (EXEs), shared libraries (DLLs), and packed project libraries.
    In LabVIEW 2017 SP1, malleable VIs can adapt to input classes. A malleable VI that calls a method of class A accepts data of unrelated classes as long as the class has a public method with the same name, connector pane pattern, and terminal direction as the method of class A that the malleable VI calls. The malleable VI adapts to the input class by replacing the call to the method of class A with a call to the public method in the input class, if such a method exists.
    You can think of this adaptability of a malleable VI as defining an interface of method calls with method name, connector pane pattern, and terminal direction. The malleable VI accepts data of any class that fulfills the interface of method calls, which allows you to use one malleable VI to perform operations on data of unrelated classes or implement multiple interfaces defined by different malleable VIs on one class.
    Refer to the labview\examples\Malleable VIs\Class Adaptation\Malleable VIs - Class Adaptation.lvproj for an example of using malleable VIs to define interfaces of method calls.
    Use the LabVIEW Platform media to install modules and toolkits supported by LabVIEW 2017 SP1 (32-bit) and LabVIEW 2017 SP1 (64-bit). When run on Windows (64-bit), LabVIEW (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW (64-bit) is available in English only.
    Refer to the NI website for information about drivers compatible with LabVIEW 2017 SP1 (64-bit). For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW (64-bit).
    LabVIEW 2017 SP1 (64-bit) supports a limited number of modules and toolkits. The following lists compares the modules and toolkits supported by LabVIEW (32-bit) and LabVIEW (64-bit).
    ProductLabVIEW 2017 SP1 (32-bit)LabVIEW 2017 SP1 (64-bit)
    OK
    OK
    OK1
    Database Connectivity Toolkit
    OK
    DataFinder Toolkit
    OK
    OK
    OK
    OK
    Digital Filter Design Toolkit
    OK
    FPGA Module
    OK
    MathScript RT Module
    OK
    OK2
    OK
    OK
    Real-Time Module
    OK
    Robotics Module
    OK
    SoftMotion Module
    OK
    Statechart Module
    OK
    Sound and Vibration Measurement Suite
    OK
    OK
    Unit Test Framework Toolkit
    OK
    OK
    VI Analyzer Toolkit
    OK
    OK
    Vision Development Module
    OK
    OK
    1 The Control Design and Simulation Module (64-bit) does not support the System Identification VIs, System Identification Assistant, Control Design Assistant, and real-time targets.
    2 The MathScript RT Module (64-bit) does not support the libraries class of MathScript RT Module functions.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2017 and LabVIEW 2017 SP1.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2017 SP1. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    604133LabVIEW can crash when executing a Value (Signaling) property on a generic subpanel reference.
    607006Changed click behavior with Windows 10, version 1607.
    607329Merged signals do not have correct names in output file of Write to Measurement File express VI.
    608412In some cases, attempting to plot multiple large datasets on an XY graph can result in LabVIEW hanging.
    618044In rare cases, updating a type definition file may cause instances of the typedef to revert to default data.
    620145Using a Formula Node with a large number of equations can cause LabVIEW to crash.
    622429On the first execution of LabVIEW, using the Edit Tree Items: Move Item method causes a crash.
    627910Large projects may have extended save times.
    637096LabVIEW-built applications can have DPI scaling issues.
    639416LabVIEW-built assemblies with array parameters cannot be called from Visual Studio.
    639842Occasional crashes on real-time targets, exception code 0x661.
    640139Updating a type definition that is used in dynamic event registration leads to incorrect behavior.
    640344A Stream channel writer can be wired to a Lossy Stream channel writer without breaking the wire.
    640873Callers of malleable VIs will sometimes show a document modification and prompt to save when the VI has not changed.
    649615Dragging a node with a channel wire connection into or out of a structure can rewire incorrectly.
    649837Crash using Actor Framework Message Maker after first message creation fails because of an already-existing file on disk.
    649952In very rare situations, LabVIEW can crash while unflattening data.
    650556Message Channel acks can unblock improperly.
    651326Double-clicking a reentrant subVI in LabVIEW 2017 always opens the master VI, never the clone.
    653033In certain cases, updating a numeric member of a cluster will not update the cluster.
    653897Make LabVIEW more robust when presented with corrupted resource files.
    654700Read-only DVR can occasionally return the wrong value.
    654714Scripted channel endpoint VIs show up on the Recent Files list in the Getting Started Window.
    656295In some cases, using the Alignment tool on wires can cause a LabVIEW crash.
    656516Some VIs that are runnable in LabVIEW 2015 and earlier will report broken in LabVIEW 2016 and later.
    657776Creating a VI for Data Member Access can crash LabVIEW.
    658033In the Rearrange Cases dialog for Event Structure frames, the "Sort" button doesn't sort alphabetically.
    658387Sometimes a terminal with a coercion dot will be displayed as the wrong data type in Context Help.
    658923Custom Probes for LabVIEW classes have erratic block diagram behavior when live drag is enabled.
    660055Comparison primitives with waveform as input in "Compare Aggregate" mode can cause a LabVIEW crash at runtime.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2017 SP1.
    © 2004–2017 National Instruments. All rights reserved.
    374715H-01
    GMT+8, 2025-7-23 10:31
