查看: 7845|回复: 0
[LabVIEW] NI LabVIEW 2018 SP1 Win64ENG 64位LV2018SP1英语版下载
    半小时前
  • 签到天数: 3525 天
    连续签到: 13 天
    发表于 2018-12-5 10:16:55 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    2018年12月3日发布。64位LabVIEW,没有中文版等非英语版本。
    支持操作系统:
    Windows 10(1803版)/8.1 Update 1/7 SP1
    Windows Server 2012 R2
    Windows Server 2008 R2 SP1
    即要求最低WIN7SP1且要更新对SHA-256数字签名的支持,对于WIN7、WIN VISTA、WIN XP已经不再支持。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址(可能无效或无法下载完成)(EXE版和ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期更新重压制版):
    请购买附件下载查看
    LV2018SP1ENG64.txt (531 Bytes, 下载次数: 103, 售价: 10 元)
    LabVIEW 2018 Service Pack 1 Readme for Windows
    September 2018
    This file contains important information about LabVIEW 2018 Service Pack 1 (SP1) for Windows, including system requirements, installation instructions, known issues, and a partial list of bugs fixed for LabVIEW 2018 SP1.
    LabVIEW 2018 SP1 (64-bit)
    LabVIEW 2018 SP1 has the following requirements:
    WindowsRun-Time EngineDevelopment Environment
    Operating SystemWindows 10 (version 1803)/8.1 Update 12/7 SP13
    2
    3
    2
    3
    1 LabVIEW and LabVIEW Run-Time Engine require processors of the Pentium 4M/G1 generation or later, which are capable of executing SSE2 instructions.
    2 NI software installs VC2015 Runtime and .NET 4.6.2. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
    3 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
    Note
    • You cannot access LabVIEW using a Guest account on Windows.
    • In 2016 LabVIEW dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. LabVIEW 2018 SP1 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use LabVIEW 2018 SP1 to an unsupported OS. Additionally, after installing LabVIEW 2018 SP1, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. For more information about the changes to our OS support for 2016, refer to KB 79UC78LS, Why Does My NI ADE Installer Fail on Windows XP/Vista and Windows Server 2003?.
    Complete the following steps to install and activate LabVIEW for Windows.
    Are you installing LabVIEW for the first time? Insert the LabVIEW Platform media and follow the onscreen instructions to install LabVIEW, modules, toolkits, and drivers. When prompted, enter the serial number for each product you want to activate. Your serial number can be found at ni.com/myproducts. If you are managing your license with a volume license server, you should receive your volume license file by email.
    Are you upgrading from a previous version of LabVIEW? Refer to the LabVIEW Upgrade Notes for information about protecting existing VIs and projects before installing a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2018.
    Use the LabVIEW Platform media to install modules and toolkits supported by LabVIEW 2018 SP1 (32-bit) and LabVIEW 2018 SP1 (64-bit). When run on Windows (64-bit), LabVIEW (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW (64-bit) is available in English only.
    Refer to the NI website for information about drivers compatible with LabVIEW 2018 SP1 (64-bit). For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW (64-bit).
    LabVIEW 2018 SP1 (64-bit) supports a limited number of modules and toolkits. The following lists compares the modules and toolkits supported by LabVIEW (32-bit) and LabVIEW (64-bit).
    ProductLabVIEW 2018 SP1 (32-bit)LabVIEW 2018 SP1 (64-bit)
    OK
    OK
    OK
    OK1
    Database Connectivity Toolkit
    OK
    DataFinder Toolkit
    OK
    OK
    OK
    OK
    Digital Filter Design Toolkit
    OK
    OK
    FPGA Module
    OK
    OK
    MathScript RT Module
    OK
    OK2
    OK
    OK
    Real-Time Module
    OK
    Robotics Module
    OK
    SoftMotion Module
    OK
    Statechart Module
    OK
    Sound and Vibration Measurement Suite
    OK
    OK
    Unit Test Framework Toolkit
    OK
    OK
    VI Analyzer Toolkit
    OK
    OK
    Vision Development Module
    OK
    OK
    2 The MathScript RT Module (64-bit) does not support the libraries class of MathScript RT Module functions.
    (Windows) When you build an installer in LabVIEW, the default name of the executable is changed from setup.exe to install.exe. This behavior change may have potential impact to post-build processes that rely on the setup.exe name. To specify a different name for the executable, use the Installer name option on the Product Information page of the Installer Properties dialog box.
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2018 and LabVIEW 2018 SP1.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2018 SP1. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    708128Undefined data types do not resolve with Malleable VIs.
    705899LabVIEW crashes when using string control with the Python Node.
    705605Separately compiled code takes longer to load with mismatched bitness.
    701083Error Ring will not accept %$ String modifiers.
    691392Searching for text crashes LabVIEW.
    687308Class constants/controls appear grey on block diagram but VI's run arrow is unbroken.
    677536Mouse cursor does not scale properly with DPI settings.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2018 SP1.
    © 2004–2018 National Instruments. All rights reserved.
    374715K-01
    举报
    GMT+8, 2025-4-26 10:46
