查看: 13922|回复: 2
[NI驱动程序] NI Vision Acquisition Software 2013.09 LabVIEW2013 Win32/64Eng 视觉采集软件VASSeptember2013
    昨天 08:12
  • 签到天数: 3787 天
    连续签到: 38 天
    发表于 2013-12-19 21:56:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    VAS2013.09 相较于VAS2013.08增加了一些新硬件的支持。其它差别不大,如果不是刚好遇到这类硬件,两个版本都可以适用于LabVIEW2013。如果担心遇到问题,那就装VAS2013.09,升级的理论上会更好一些。
    文件大小: 2109392340 字节 (1.96 GB)
    修改日期: 2013-12-24 21:20
    MD5: 507e75574ed7554c419a79f4a5a523a9(官方正确)
    SHA1: a008745a6e72817efffef38658b12e28a0abf69d
    SHA256: 33153510ee50a3b003d7ae2621506e0e069e70fdfc67cf83fbea5dd0617b9e60
    CRC32: 191c9f23
    百度网盘下载和NI官方下载地址:
    请购买附件下载查看
    VAS2013.09.txt (391 Bytes, 下载次数: 76, 售价: 10 圆)
    NI Vision Acquisition Software Release Notes
    September 2013
    This file contains important information about National Instruments Vision Acquisition Software, and is organized into the following sections:
    Upgrade Considerations for Legacy NI-IMAQ for IEEE 1394 Cameras
    Minimum System Requirements
    Updates and Improvements
    Software Support
    Installation
    Configuring NI-IMAQ
    Configuring NI-IMAQdx
    NI Vision Acquisition Software allows you to acquire, display, and save images; control digital I/O on National Instruments image acquisition devices; and configure your driver software and hardware.
    This release of Vision Acquisition Software includes the following new features:
    NI-IMAQdx 4.3
    NI-IMAQdx is driver software that supports NI 177x smart cameras, as well as IEEE 1394, GigE Vision, DirectShow-compatible USB, USB3 Vision cameras, and IP cameras.
    • Support for the NI CVS-1457RT
    • Support for USB3 Vision cameras on VxWorks CompactRIO and Single-BoardRIO Real-Time targets
    NI-IMAQ I/O 2.8
    NI-IMAQ I/O provides support for reconfigurable input/output (RIO) using National Instruments EVS-1460 Series Embedded Vision Systems, compact vision systems, and other GigE Vision and IEEE 1394 reconfigurable image acquisition devices.
    • NI-IMAQ I/O can be added as an additional installer in LabVIEW Application Builder
    NI-IMAQdx no longer supports Legacy NI-IMAQ for IEEE 1394 Cameras. This version of NI-IMAQdx uninstalls the Legacy NI-IMAQ for IEEE 1394 Cameras feature of NI-IMAQdx 3.3 or earlier. If you require Legacy NI-IMAQ for IEEE 1394 Cameras, you must download and install it separately. Visit ni.com/infoand enter the info code legacy1394 for information about how to install Legacy NI-IMAQ for IEEE 1394 Cameras. This version of NI-IMAQdx does not affect separate installations of Legacy NI-IMAQ for IEEE 1394 Cameras.
    Porting Existing Legacy NI-IMAQ for IEEE 1394 Cameras Applications to NI-IMAQdx
    In most cases, there is a one-to-one correlation between an NI-IMAQdx VI or function and Legacy NI-IMAQ for IEEE 1394 Cameras VI or function. For example, the IMAQ 1394 Snap VI has been replaced with the IMAQdx Snap VI and takes similar parameters.
    You set and get camera attributes differently for each driver. For example, with Legacy NI-IMAQ for IEEE 1394 Cameras, you passed in an enumerated type that contained the attribute name and a value. With NI-IMAQdx, you pass a string with the attribute name and value.
    Another major difference between the two drivers is that NI-IMAQdx now supports the Event Structure in LabVIEW. Rather than using occurrences, as you did with Legacy NI-IMAQ for IEEE 1394 Cameras, you can now register the Frame Done event to fire in LabVIEW for more readable code.
    Maintenance and Support Policy
    National Instruments recommends that all new applications be developed with NI-IMAQdx. All new features, bug fixes, or other enhancements in the future will be made to the NI-IMAQdx driver and API. NI-IMAQ for IEEE 1394 Cameras is "frozen" to ensure that the behavior of existing applications does not change. NI-IMAQdx no longer includes Legacy NI-IMAQ for IEEE 1394 Cameras. This version of NI-IMAQdx uninstalls Legacy NI-IMAQ for IEEE 1394 Cameras. If you requires Legacy NI-IMAQ for IEEE 1394 Cameras, you must download and install it separately. Visit ni.com/info and enter the info code legacy1394 for information about how to install Legacy NI-IMAQ for IEEE 1394 Cameras. National Instruments Applications Engineers no longer support the Legacy NI-IMAQ for IEEE 1394 Cameras API.
    The development computer must meet the following requirements to run NI Vision Acquisition Software:
    Processor
    Pentium 4 1 GHz or equivalent
    Memory
    512 MB RAM
    Display
    1,024 × 768 resolution video adapter with a 16-bit display
    Minimum Recommended
    Free Hard Disk Space
    2 GB
    NI-IMAQ
    1 GB
    NI-IMAQdx
    1 GB
    NI-IMAQ I/O
    1.5 GB
    Operating System
    Windows 8/7/Vista/XP SP3 (32-bit)/Server 2008 R2/Server 2003 R2 (32-bit)
    Browser
    Microsoft Internet Explorer 6.0 or later
    The following list describes issues in previous versions of the NI Vision Development Module that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the NI Vision Development Module.
    427191When Multiple Vision Acquisition Express VIs are in use, they cannot save to different image logging paths.
    425502Unplugging a USB3 Vision camera when a NI-IMAQdx session is open on the camera can cause a potential hang.
    425436Some attributes do not properly refresh when using a Basler Ace USB3 Vision camera.
    425042niimaqdx.lib installs into the wrong directory for LabWindows/CVI.
    424480Setting an attribute with an empty string causes a crash.
    424407Saving a camera file on a Basler Ace USB3 Vision camera can result in an error in getting the attribute.
    422281USB R Series DAQ devices cannot be detected in LabVIEW 2013 when NI-IMAQ I/O 2.7 is also installed.
    420546Measurement and Automation Explorer crashes when using a DirectShow camera without any video modes.
    418479The NI PCIe-1473R is not detected on desktop PCs used as Real-Time targets.
    383188NI-IMAQdx generates a large amount of network traffic on NI Linux Real-Time targets when Measurement and Automation Explorer is open.
    325222NI PCIe-1473R RioClk40 is unconstrained.
    Software Support
    This section describes the operating systems and application development environments (ADEs) supported by NI Vision Acquisition Software.
    Operating Systems
    • LabVIEW Real-Time Module 2010 or later
    • Windows 8/7/Vista/XP SP3 (32-bit) SP2/Server 2008 R2/Server 2003 R2 (32-bit). Refer to the following table for more information.
    Note  NI Vision Acquisition Software does not support Windows Server non-R2 editions.
    DeviceWindows 8/7/Vista/XP SP3/Server 2003 R2 32-bit versionsWindows 8/7/Vista/Server 2008 R2 64-bit versions
    NI 1405
    Yes
    Yes*
    NI 1407
    Yes
    Yes*
    NI 1408
    No
    No
    NI 1409
    Yes
    Yes*
    NI 1410
    Yes
    Yes*
    NI 1411
    Yes
    Yes*
    NI 1422
    Yes
    Yes*
    NI 1424
    Yes
    Yes*
    NI 1426
    Yes
    Yes*
    NI 1427
    Yes
    Yes*†
    NI 1428
    Yes
    Yes*
    NI 1429
    Yes
    Yes*†
    NI 1430
    Yes
    Yes*†
    NI 1433
    Yes
    Yes*†
    NI 1435
    Yes
    Yes*†
    NI 1473R
    Yes
    Yes*†
    NI 1483
    Yes
    Yes*
    NI 8231
    Yes
    Yes
    NI 8234
    Yes
    Yes
    NI 8235
    Yes
    Yes
    NI 8236
    Yes
    Yes
    NI 8237R
    Yes
    Yes
    NI 8252
    Yes
    Yes
    NI 8254R
    Yes
    Yes
    NI 8255R
    Yes
    Yes
    *  Applications developed using LabVIEW 8.2.1 or later will run on systems with more than 3 GB of physical memory. Applications developed using other development environments, such as Microsoft Visual C, Visual Basic, and .Net, are limited to systems with 3 GB or less of physical memory. All 32-bit applications, including those developed using LabVIEW, may not allocate more than 2 GB of memory total.
    †  A firmware update is available for this device to allow non-LabVIEW applications to run on systems with more than 3 GB of physical memory. To update the device firmware, launch MAX and select Tools»NI Vision»Update NI-IMAQ Device Firmware.
    Remote Target Support
    NI Vision Acquisition Software September 2011 was the last version of NI Vision Acquisition Software to provide support for the NI 1762 Smart Camera and the NI 1764 Smart Camera. New software features of NI Vision Acquisition Software will not work on these devices. Backward compatibility for existing applications is maintained.
    NI Vision Acquisition Software February 2013 was the last version of NI Vision Acquisition Software to provide support for the NI 1454, 1455, and 1456 Compact Vision Systems. New software features of NI Vision Acquisition Software will not work on these devices. Backward compatibility for existing applications is maintained.
    Development Environments
    • LabVIEW 2010 or later
    • LabWindows/CVI 8.1 or later
    • Microsoft Visual C/C++ 6.0 or later
    • Microsoft Visual Basic 6.0 or later
    • Microsoft Visual Studio .NET 2005 and 2008 (except NI-IMAQ I/O)
    Additional Software
    You can also use NI-IMAQ, and NI-IMAQdx with the following National Instruments software packages to prototype, benchmark, and deploy your applications.
    • NI Vision Development Module 7.1 or later
    • NI Vision Builder for Automated Inspection (Vision Builder AI) 2.5 or later
    Complete the following steps to install NI Vision Acquisition Software:
    Note: You must have administrator access to install the NI Vision Acquisition Software.
    • Insert the NI Vision Acquisition Software installation media.
    • If you do not have autorun enabled, double-click autorun.exe. If you have autorun enabled, autorun.exe runs automatically.
    NI-IMAQ and NI-IMAQdx integrate with MAX, the National Instruments utility for configuring and testing your measurement and automation system. The MAX icon appears on your desktop after you install NI Vision Acquisition Software.
    Configuring NI-IMAQ
    Complete the following steps to install an image acquisition device and configure NI-IMAQ:
    Note: You must install NI-IMAQ before installing your image acquisition device.
    Caution: Power off and unplug the computer before installing your hardware. Wait for any motherboard LEDs to power off before proceeding, since some computers remain powered for some time after being unplugged.
    • Install your image acquisition device, and connect the camera. Refer to the device documentation for specific hardware installation instructions.
    • Run MAX.
      • Double-click the MAX icon on the desktop. You can use MAX to modify camera properties. Once you have saved these properties, they become the default settings for all NI-IMAQ applications.
      • Expand Devices and Interfaces and NI-IMAQ Devices to display a list of the image acquisition devices installed on your computer.
    • Select a camera file, and acquire an image.
      • Click the plus sign next to the image acquisition device to expand the menu tree and list the available channels or ports. Right-click the channel or port to display a list of available cameras.
      • Select the appropriate camera type from the list. Camera type selection varies according to the image acquisition device installed.
      • To change the camera settings, modify the parameters at the bottom of the image viewer panel.
      • You can acquire an image in the following ways:
        • Use the Snap button to acquire and display a single image with the image acquisition device.
        • Use the Grab button to acquire images continuously. A grab allows you to focus the camera.
    Tip: For a complete list of supported cameras, right-click the channel or port, select Camera, and click Search ni.com.
    Note: Refer to the right side of the MAX user interface, which displays context-sensitive help, for information about configuring image acquisition devices with MAX.
    Configuring a Remote PXI/Compact PCIe Image Acquisition Device
    Use MAX to install NI-IMAQ for LabVIEW Real-Time from the host machine onto the target system. The NI-IMAQ for LabVIEW Real-Time components enable the remote device to acquire and analyze images as directed by the host machine.
    Note: Install NI-IMAQ and the LabVIEW Real-Time Module on the remote system before you install and configure the image acquisition device. Follow the steps in the MAX help window to install software.
    Tip: Configuring remote image acquisition devices is similar to configuring local image acquisition devices, except that the procedure for working with camera files is different. Refer to the Measurement & Automation Explorer Help for NI-IMAQ for information about working with camera files on remote image acquisition devices.
    • Launch MAX.
    • In the Configuration tree, expand Remote Systems.
    • Expand the appropriate system.
    • Expand Devices and Interfaces.
    • Expand NI-IMAQ Devices.
    • Expand the device you want to configure.
    Refer to the Measurement & Automation Explorer Help for NI-IMAQ for information about configuring specific NI image acquisition devices. You can access this help file from the MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQ.
    Complete the following steps to install and configure NI-IMAQdx.
    If you are using a USB camera, ensure that the camera is compatible with DirectShow, and that the camera driver is installed and functioning. For specific information about drivers and camera compatibility, consult your camera manufacturer documentation.
    Instructions for configuring an IEEE 1394 or GigE Vision camera are included in the Measurement & Automation Explorer Help for NI-IMAQdx. You can access this help file from the MAX Help menu by selecting Help»Help Topics»NI Vision»NI-IMAQdx.
    Installing IEEE 1394 Hardware
    Install your IEEE 1394 interface card. Follow the installation instructions provided by the manufacturer.
    Installing the High Performance GigE Vision Driver
    If you have an Intel Pro/1000 Series gigabit Ethernet Network Interface Card (NIC), it is recommended that you install the High Performance GigE Vision Driver. This will ensure optimized performance and minimal configuration. To associate your hardware with the high performance driver, complete the following steps.
    • Install your NIC.
      • If Windows does not prompt you to choose a driver, proceed to step 2.
      • If Windows prompts you to choose a driver, proceed to step 3.
    • Right-click the NIC in the Device Manager, and select Update Driver.
    • Choose not to connect to the Windows Update Web site, and click Next.
    • Choose to Install from a list or a specific location, and click Next.
    • Choose Don't Search. I will choose the driver to install.
    • Click Next.
    • Select National Instruments GigE Vision driver from the list, and click Next.
    • Click Finish.
      Note: Windows may return a warning stating that the driver is unsigned. It is safe to ignore the warning.
    Installing the Universal GigE Vision Driver
    NI-IMAQdx will work with any standard gigabit Ethernet NIC. To use NI-IMAQdx with a standard gigabit Ethernet NIC, complete the following steps:
    • Install the NIC and any related drivers. Refer to the NIC device documentation for installation instructions.
    • Enable jumbo frames (frame packet size is greater than 1,500 bytes) on your NIC.
      • Right-click the NIC in the Device Manager, and select Properties.
      • Click the Advanced tab, and Jumbo Frames will appear in the Property list if supported by your NIC.
      • Select the largest frame size available and click OK.
      Note: The procedure for enabling jumbo frames on your NIC may vary by manufacturer. Refer to the NIC device documentation for more information about enabling jumbo frames.
    • Disable the Windows Firewall or any additional third party firewalls on the port. Windows Firewall can be disabled on individual ports from the Advanced tab of the Windows Firewall applet.
    Configuring Multiple Ports
    If you plan to use multiple ports with NI-IMAQdx, complete the following steps:
    • Open the Network Connections window in Windows, and select all of the ports that cameras will be connected to by holding while clicking each port.
    • Right-click one of the selected ports, and choose Bridge Connections.
      Note: If you are not using the High Performance Driver, you will be unable to use jumbo frames on bridged devices.
    Configuring NI-IMAQdx for Windows
    Complete the following steps to configure NI-IMAQdx for Windows:
    • Connect the camera.
    • Run MAX.
      • Double-click the MAX icon on your desktop. You can use MAX to modify camera attributes. After you have saved these attributes, they become the default settings for all NI-IMAQdx or NI Vision applications.
      • Expand Devices and Interfaces»NI-IMAQdx in the configuration tree to display a list of the cameras installed on your computer.
      • For IEEE 1394 cameras, NI-IMAQdx may not be associated with the camera. If this is the case, change the associated driver by right-clicking the camera and selecting Driver»NI-IMAQdx.
      • Select the camera from the list. You then can view or modify the camera attributes on the Camera Attributes tab located below the image viewer.
    Tip: Click the Show Help button to display the help window on the right side of the image viewer. Move your mouse over the properties to view context-sensitive help in the bottom half of the help window.
    Configuring NI-IMAQdx for the LabVIEW Real-Time Module
    If you are using a Windows development machine, the LabVIEW Real-Time Module, and an RT target, complete the following steps to install and configure NI-IMAQdx:
    Note: NI-IMAQdx does not support USB cameras on the LabVIEW Real-Time Module.
    • Install NI-IMAQdx software on your Windows development machine.
    • Ensure that your RT target is connected to the same subnet as the Windows development machine.
    • Run MAX.
      • Expand the Remote Systems list in the configuration tree.
      • Select your RT target in the list.
      • Configure your network settings. Refer to the Remote Systems Help in MAX (Help»Help Topics»Remote Systems) for instructions about configuring network settings.
    • Install NI-IMAQdx on the RT target.
      • Click the Software item below the RT target in the configuration tree.
      • Click Install Software on the MAX toolbar to launch the LabVIEW Real-Time Install Software Wizard.
      • Select NI-IMAQdx RT, as well as any additional software you would like to install on the target machine.
      • Click Next. Review the list of software you selected to install.
      • Click Next to begin downloading the software to the target machine. When MAX has finished downloading the software, it restarts the remote device.
      • Click Finish.
    • Connect your camera to your remote system.
    • Press to refresh the MAX configuration tree. Your camera should be listed in the Remote Systems list.
      Tip: Press to refresh the configuration tree whenever you connect a new device to an RT target.
    • Select the camera from the list. You then can view or modify the camera attributes from the Camera Attributes panel located below the image viewer.
    Configuring USB3 Vision hardware on Windows XP
    Windows will not automatically assosciate the correct driver with USB3 Vision cameras. Complete the following steps to configure your USB3 Vision camera:
    • Locate the camera in Device Manager.
    • Right-click the camera and select Update Driver.
    • Click Have Disk....
    • Click Browse and navigate to Program Files\National Instruments\NI-IMAQdx\Staging\NI USB3 Vision.
    • Click OK. In the next window, select your device, then click Next.
    • A warning will appear. Click Continue Anyway.
    • Click Finish.
    Known IssuesNI-IMAQ
    • In LabVIEW 2012 and earlier, error codes returned during a property node read or write are not being reported correctly. The status flag is set correctly, to notify you that an error occurred, but the code is set to an invalid value.
    NI-IMAQdx
    • Volume License Manager will attempt to check out available Vision Development Module licenses before trying Vision Acquisition Software licenses.
    • Attempts to extend the evaluation period for Vision Acquisition Software licenses from within LabVIEW or the LabVIEW Run-Time Engine are unsuccessful in connecting to the internet.
    • Unplugging a USB3 Vision camera on NI Linux or VxWorks Real-Time targets can cause a crash.
    • Bayer VNG decoding can overflow when decoding 16-bit Bayer pixel formats.
    • The Bayer bilinear algorithm does not properly decode pixels on the right side of the image for certain image widths.
    NI-IMAQ I/O
    • On NI CVS-1457RT targets, serial configuration is not available in MAX. Programmatic configuration is still available in Vision Builder AI and LabVIEW.
    • In LabVIEW 2013, Project Explorer displays the NI 1454, 1455, and 1456 Compact Vision Systems. However, LabVIEW 2013 does not support the NI 1454, 1455, and 1456 Compact Vision Systems.
    Documentation is installed onto your hard drive with NI Vision Acquisition Software. The documentation ships as Adobe Acrobat portable document format (PDF) files and HTML Help files. To view the NI Vision Acquisition Software documentation, select Start»All Programs»National Instruments»Vision»Documentation.
    Note: You must have Adobe Acrobat Reader installed to view the PDFs. Refer to the Adobe Systems Incorporated Web site at www.adobe.com to download the latest version of Adobe Reader.
    NI LabVIEW Documentation
    You can access the NI-IMAQ VI Reference Help, NI-IMAQdx VI Reference Help, and NI Vision-RIO VI Reference Help from the LabVIEW Help menu. In LabVIEW, select Help»NI Vision for LabVIEW Help.
    .NET Documentation
    The NI Vision Acquisition Software .NET documentation merges into the NI Measurement Studio Help. The NI Measurement Studio Help integrates into the Visual Studio Combined Help Collection under the Measurement Studio node in the Table of Contents. In order for links from Measurement Studio help topics to .NET Framework help topics to work, you must install the product documentation for Visual Studio, which installs the MSDN Library. This requires a secondary installation during the Visual Studio installation process.
    The NI Measurement Studio Help is in the Microsoft Help 2.0 format and requires a Microsoft Help 2.0 viewer to be displayed. A Microsoft Help 2.0 viewer is installed with both Microsoft Visual Studio and the Microsoft .NET Framework SDK. The SDK is freely available from MSDN at http://www.microsoft.com/downloads. If you do not have either of these products, you will need a standalone Microsoft Help 2.0 viewer to display the documentation. Some Help 2.0 viewers are available for download, such as Helpware's H2Viewer.
    • NI Measurement Studio Help—Contains reference information about NI Vision for .NET objects. Describes how to create machine vision and image processing applications in Visual Basic .NET and C# using the NI Vision Development Module. You can launch the NI Measurement Studio Help in the following ways:
      If you have Measurement Studio installed:
      • From the Windows Start menu, select Start»All Programs»National Instruments»»Measurement Studio Documentation, where is the location to which Measurement Studio is installed. The help launches in a stand-alone help viewer.
      • From Visual Studio, select Measurement Studio»NI Measurement Studio Help.
      If you do not have Measurement Studio installed:
      • From Visual Studio, select Help»Contents to view the Visual Studio table of contents. The NI Measurement Studio Help is listed in the table of contents.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI Vision Acquisition Software Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments Vision Acquisition Software will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of Vision Acquisition Software that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    ProductInfo Code
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2013 National Instruments Corporation. All rights reserved.
    The registered trademark Linux® is used pursuant to a sublicense from LMI, the exclusive licensee of Linus Torvalds, owner of the mark on a world-wide basis.
  • 签到天数: 16 天
    发表于 2013-12-24 09:19:26 | 显示全部楼层 来自:上海市 电信
    5 天前
  • 签到天数: 387 天
    [LV.9]900FPS
    发表于 2014-6-4 17:12:26 | 显示全部楼层 来自:美国
    GMT+8, 2026-1-30 06:59
