查看: 2880|回复: 1
[原创] 工具
  • 签到天数: 94 天
    [LV.6]600FPS
    发表于 2017-12-29 10:16:01 | 显示全部楼层 |阅读模式 来自:江苏省 移动数据上网公共出口
    NI VISION Assistant 2017版本增加一个工具(Processing Functions):个工具名字Flat Field Correction
    Creating a Bright Field Image Using Vision Assistant StepsTo create a bright field image in Vision Assistant, make a script with the following steps:
    Acquire an image.
    • Add an Image Buffer step to save the acquired image.
    • Add a Filters step. Select a Smoothing - Low Pass filter with a large Filter Size, or a Smoothing - Gaussian filter with a large Kernel Size. You can also use your own algorithm. This creates a bright field image.
    • Add an Image Buffer step to save the bright field image.
    • Add an Image Buffer step to retrieve the original acquired image stored in the first buffer step you created.
    • Add a Flat Field Correction step. Select the Correction with specified bright field image option and set the Image Buffer to retrieve the bright field image.
    The script should resemble the following image:
  • 签到天数: 94 天
    [LV.6]600FPS
     楼主| 发表于 2017-12-29 10:18:28 | 显示全部楼层 来自:江苏省 移动数据上网公共出口
    为什么帖子的字数有限制,同时贴的图片都不见了,上个图片使用流程
    GMT+8, 2026-1-9 10:22
