查看: 9108|回复: 0
[NI软件产品] NI Vision Builder for Automated Inspection 2015F2 Win32/64Eng 自动检测视觉生成器VBAI2015F2 LabVIEW2016版适用
    昨天 08:13
  • 签到天数: 3815 天
    连续签到: 8 天
    发表于 2017-5-16 16:46:16 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Vision Builder for AI 2015F2版 2017年5月更新版本
    2017春季软件包
    视觉生成器,VBAI2015F2版,期待以久的VBAI2016,看来是要夭折了。看网上都有LabVIEW2017版本了。VBAI还只是更新到2015F2,看来这个软件也是后妈生的了。估计后期难有大的更新与性能提升,大家且下且珍惜。VBAI2015F2版,理论上应该是支持LV2016SP1版的,但是LV2016SP1版也没有发布,所以仍然只适用于LabVIEW2016(即在LV2016中可以调用VBAI API),运行VI则需要使用LV2015。
    标准下载:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI下载器下载:
    提取码: 请购买附件下载查看
    标准下载:
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看
    VBAI2015F2.txt (509 Bytes, 下载次数: 24, 售价: 10 圆)
    NI Vision Builder for Automated Inspection 2015 f2 Readme
    January 2017
    This file contains important information about National Instruments Vision Builder for Automated Inspection (Vision Builder AI) and is organized into the following sections:
    Activation Instructions
    Updates and Improvements
    Remote Target Support
    Software Requirements for Migrating an Inspection to LabVIEW
    PC-Based Image Acquisition and I/O Support
    Additional Resources
    NI Vision Builder AI gives you an easy way to configure, benchmark, and deploy a system that addresses vision applications from pattern matching to code reading and presence detection to precision alignment and classification.
    For information about licensing NI Vision software, visit ni.com/info and enter the Info Code LicenseVision. Refer to the NI Vision website at ni.com/vision for the latest information about NI Vision Builder for Automated Inspection.
    To configure inspections using Vision Builder AI, the host machine must meet the following requirements:
    MinimumRecommended
    ProcessorPentium 4/M or equivalentCore Duo or equivalent
    Memory512 MB RAM1 GB RAM
    Display1,024 × 768 resolution video adapter with a 24- or 32-bit display1,280 × 1,024 resolution video adapter with a 24- or 32-bit display
    Operating System
    • Windows 10 (32- and 64-bit)
    • Windows 8.1 (32- and 64-bit)1
    • Windows 7 SP1 (32- and 64-bit)2
    • Windows Server 2012 R2 (64-bit)1
    • Windows Server 2008 R2 SP1 (64-bit)2
    Browser
    Microsoft Internet Explorer 6.0 or later
    Hard Disk Space
    1 GB
    Note  NI Vision Builder AI 2015 f2 dropped support for Windows Vista, Windows XP, Windows Server 2003, and installations of Windows 7 without any service packs. NI Vision Builder AI 2015 f2 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use NI Vision Builder AI 2015 f2 or later to an unsupported OS. Additionally, after installing NI Vision Builder AI 2015 f2 or later, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Complete the following steps to install Vision Builder AI:
    Note: You must be logged in with administrator privileges to install Vision Builder AI.
    • Insert the Vision Builder AI DVD into your DVD-ROM drive. If the DVD does not run automatically, open Windows Explorer, right-click the DVD drive icon, and select AutoPlay.
    • Select Install Vision Builder for Automated Inspection on the National Instruments Vision Builder for Automated Inspection screen.
    • Vision Builder AI prompts you to enter your user information. Select one of the following options:
      • Install this product using the following serial number
      • Install this product for evaluation
      If you choose to enter a serial number, enter the serial number found on your Certificate of Ownership card. Vision Builder AI automatically uses this serial number when you run the NI Activation Wizard.
    • Continue to follow the instructions on the screen.
    If the NI product you are installing uses Microsoft .NET 4.6.1, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.1 separately before you install NI software.
    If you do not activate a valid license, Vision Builder AI runs in evaluation mode and continues to prompt you to activate a license on each launch. At the end of the evaluation period you must activate a Vision Builder AI license to continue using the product.
    Note: While Vision Builder AI is in Evaluation mode, all features are available except Migrate Inspection to LabVIEW.
    Complete the following steps to activate the Vision Builder AI license:
    • Launch Vision Builder AI.
    • Click Yes when prompted to activate Vision Builder AI.
    • Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
    • Enter your serial number, and click Next.
    • Enter your registration information, and click Next.
    • You can enter an email address to receive a copy of the activation code for your records.
    The following list describes the new features in Vision Builder AI 2015 f2:
    • Industrial Smart Camera Support
      • Vision Builder AI now supports the ISC-1780, ISC-1781, ISC-1782, and ISC-1783 smart cameras running NI Linux Real-Time.
    The following list describes the new features in Vision Builder AI 2015 f1:
    • Industrial Controller Support
      • Vision Builder AI now supports the IC-3171 and IC-3172 industrial controllers.
    • Hardware-based Precision Time Protocol (PTP) / IEEE 1588-2008 Support
      • Hardware-based Precision Time Protocol (PTP), also known as IEEE 1588-2008, is supported on IC-3171, IC-3172 and IC-3173 real-time targets.
    The following list describes the new features in Vision Builder AI 2015:
    • Flat Field Correction Step
      • This step corrects for intensity variations due to lighting and lens non-uniformity.
    • Color Palette Support
      • This step allows you to select predefined or user-defined color palettes within inspection steps to display 8- and 16-bit images.
      • Vision Builder AI now supports the IC-3120, IC-3121, and IC-3173 industrial controllers.
    • Software-based Precision Time Protocol (PTP) / IEEE 1588-2008 Support
      • Software-based Precision Time Protocol (PTP), also known as IEEE 1588-2008, is supported on CVS-1458RT, CVS-1459RT, IC-3120, and IC-3121 targets.
    • Embedded UI Support
      • The Inspection Interface can be displayed using the Embedded UI on Linux RT targets. This allows you to use an HMI to load, run, and interact with your inspections.
    The following list describes the changes and enhancements to existing features in Vision Builder AI 2015 f2:
    • Overlay Step Improvements
      • Overlay color can be based on a previous numeric result. The Calculator step also has a color box constant added to simplify getting the numeric value for colors.
      • Added a new ROI Tool to support overlaying a previous Regions of Interest.
    • LabVIEW 2016 Support
      • The API for Vision Builder AI is now available for LabVIEW 2016 32- and 64-bit.
      • The Migrate Inspection to LabVIEW is now available for LabVIEW 2016 32- and 64-bit.
    • Support for accessing previous measurements from other states
      • The following steps now support accessing previous measurements from other states: Simulate Acquisition, Read/Write Camera Attributes, Find Edges, Find Circular Edge, Find Straight Edge, Max Caliper, Create Region of Interest, Inspect Contours, Segment Color Image, Image Logging, Read/Write Variables to INI File, and the Delay Step.
    • Vision Builder AI Recommended Software Set
      • NI-DAQmx 16.1 is now a supported add-on for the Vision Builder AI Recommended Software Set when it is present on the host system. It is not available for use with NI 17xx smart cameras or IC-317x industrial controllers.
    • Improved Performance
      • The inspection performance on a target when a host Vision Builder AI is connected to the target is now improved.
    The following list describes the changes and enhancements to existing features in Vision Builder AI 2015:
    • Network Drive Mounting
      • Mounting network drives is supported from Linux RT targets for faster and more convenient data logging and image logging than FTP.
    • Vision Assistant Step Improvements
      • Support added for setting bit-depth of 16-bit images.
      • The Geometry step's Rotation operation provides access to previous measurements for the Angle.
      • The Geometry step's Rotation operation allows you to maintain the image size after rotation.
      • The Operator and Color Operator steps provide access to previous measurements for the Constant.
      • The Image Buffer step provides access to the Variable Manager to create new image variables.
    • Network Trigger Support
      • Network triggering is added for GigE Vision cameras that support action commands and are attached to a PCIe-8237R, CVS-1457RT, CVS-1458, CVS-1458RT, IC-3120, or IC-3173.
    • Ethernet/IP Improvements
      • Custom tags are now global and can be configured in the Communication Device Manager.
      • Support added for SLC-500 and CIP messaging types.
      • Support added for arrays of previous measurements.
      • Support added for access to previous measurements from other states.
    • Ethernet/IP Server Improvements
      • Support added for adding custom descriptions to register settings.
      • Support added for customizing available registers.
    • Simulate Acquisition Step Improvements
      • Support added for reading extra information embedded in PNG files.
      • Support added for setting bit-depth for read files.
    • Using Contour ROI Measurements from the Measure Intensity Step in the Results Manager
      • The Measure Intensity step supports saving an array of intensity values from an open contour ROI (e.g. line, broken line, freehand line).
    • 16-bit Auto-Threshold Support
      • The Threshold Image, Detect Object, and Count Pixels steps support the use of 16-bit auto-threshold methods.
    • Calculator Step Improvements
      • Support added for numeric conversion functions and data manipulation.
    • Run LabVIEW VI Step Improvements
      • ROIs can be passed as input into the Run LabVIEW VI step.
      • The UI window for the Run LabVIEW VI Step supports resizing.
      • Support added for updating inspection variables from the Run LabVIEW VI step.
      • Overlays can be added or removed conditionally.
      • The width of overlays can be adjusted in the Custom Overlay step.
      • Measurement results from other inspection states can be used for overlays in the current state.
    Fixed Issues
    Refer to the National Instruments Website for an up-to-date list of all bug fixes in this release.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in NI Vision Acquisition Software.
    National Instruments Device SupportWindows-Based Device Support
    You can use Vision Builder AI to configure and control the following Windows-based National Instruments devices:
    • NI CVS-1458 and 1459 Compact Vision Systems
    • NI EVS-1463 and 1464 Embedded Vision Systems
    • NI IC-3120, 3121, 3171, 3172, and 3173 Industrial Controllers
    You can use Vision Builder AI to remotely configure and control a supported remote target. Vision Builder AI supports the following remote targets:
    • NI 1712, 1732, 1752, 1754, 177x, and 178x Smart Cameras
    • NI CVS-1457RT, 1458RT, and 1459RT Compact Vision Systems
    • NI EVS-1463RT and 1464RT Embedded Vision Systems
    To use Vision Builder AI with a remote target, you must use Vision Builder AI to configure the remote target. For more information about using Vision Builder AI to configure the remote target, refer to the documentation included with the remote target.
    Note: National Instruments recommends using WebDAV to transfer files to and from a real-time target. For more information on using WebDAV to transfer files to and from a remote target, go to ni.com/info and enter the Info Code WebDAVTransfer.
    The following table illustrates when a remote target requires you to install driver software on the development computer.
    Remote Target or Camera
    Connected to a Remote Target
    Requires Driver Software Installed
    on Development Computer
    NI Smart Camera
    No
    IEEE 1394
    No
    GigE Vision
    No
    Camera Link
    Yes
    Note: To acquire images from a Camera Link camera attached to a NI EVS-1463RT device, you must use MAX to associate a camera file with the camera. For information about how to associate a camera file with a Camera Link camera connected to a remote target, visit ni.com/info and enter the info code rtcamerafile.
    Deprecated Devices
    Vision Builder AI no longer provides support for the following devices:
    DeviceLast Version of
    Vision Builder AI Supported
    NI 1762, and 1764 Smart Cameras
    2011 SP1
    NI CVS-1454, 1455, and 1456 Compact Vision Systems
    2011 SP1
    NI 1722, 1742, 1744 Smart Cameras
    2013 SP1
    Note: Vision Builder AI 2015 is the last version which will support both Windows-based and real-time Embedded Vision Systems.
    To migrate an inspection to LabVIEW, Vision Builder AI 2015 requires LabVIEW 2015 or later and NI Vision Development Module 2015 or later.
    Some Vision Builder AI steps require additional software to successfully migrate an inspection to LabVIEW.
    • OPC UA requires the Datalogging and Supervisory Control Module for LabVIEW.
    • Ethernet/IP or Ethernet/IP adapter require NI-Industrial Communications for Ethernet/IP.
    Refer to the following table for software requirements to migrate specific steps. Driver versions must support the target version of LabVIEW for migration.
    Step NameRequirement
    Acquire ImageNI-IMAQ
    Acquire Image (IEEE 1394, GigE, or USB)NI-IMAQdx
    Acquire Image (Smart Camera)NI-IMAQ (excluding NI 177x Smart Cameras)
    NI-IMAQdx (NI 177x Smart Cameras only)
    Generate PulseNI-IMAQ
    Generate Pulse (Vision RIO)NI-IMAQ I/O for PCIe-8237R and PCIe-825xR boards, Embedded Vision Systems, and Compact Vision Systems
    NI Industrial Controller Device Drivers for industrial controllers
    Read/Write I/ONI-IMAQ
    Read/Write I/O (NI-DAQmx)NI-DAQmx
    Read/Write I/O (Vision RIO)NI-IMAQ I/O for PCIe-8237R and PCIe-825xR boards, Embedded Vision Systems, and Compact Vision Systems
    Note:  NI-IMAQ, NI-IMAQdx, and NI-IMAQ I/O are available on the NI Vision Acquisition Software DVD included with Vision Builder AI. The NI Industrial Controller Device Drivers DVD is provided separately with industrial controller devices.
    Software Requirements for the Run LabVIEW VI Step
    The Run LabVIEW VI step in Vision Builder AI 2015 supports VIs saved in LabVIEW 2015 or later.
    Vision Builder AI supports the following types of image acquisition and I/O devices:
    • National Instruments image acquisition devices
    • IEEE 1394 industrial digital cameras
    • GigE Vision cameras
    • DirectShow-compatible USB cameras
    • IP cameras
    • Digital or analog I/O from NI data acquisition (DAQ) devices
    • Serial devices
    Note: You must install driver software to acquire images from an image acquisition device connected to the development computer.
    National Instruments Image Acquisition Devices
    This version of Vision Builder AI supports National Instruments image acquisition devices that require NI-IMAQ driver version 4.6.4 or later. Specific devices may require later versions.
    Note: If you are using an image acquisition device, you must install NI Vision Acquisition Software before you install the image acquisition device. NI Vision Acquisition Software gives you access to Measurement & Automation Explorer (MAX), which is software you can use to configure National Instruments devices.
    IEEE 1394 Cameras, GigE Vision Cameras, DirectShow-Compatible USB Cameras, and IP Cameras
    This version of Vision Builder AI supports IEEE 1394 cameras, GigE Vision cameras, USB 3 Vision, DirectShow-compatible USB cameras, IP cameras, and requires NI-IMAQdx driver version 3.3 or later. Specific devices may require later versions.
    To acquire an image from one of these camera types when the camera is connected to the host computer, use the Acquire Image (1394, GigE, or USB) step. The Acquire Image (1394, GigE, or USB) step requires NI-IMAQdx, which can be installed from the NI Vision Acquisition Software DVD included with Vision Builder AI.
    You must configure an IEEE 1394 camera to use the NI-IMAQdx driver. Complete the following steps to use MAX to configure an IEEE 1394 camera to use the NI-IMAQdx driver.
    • Launch MAX.
    • In the MAX configuration tree, expand Devices and Interfaces to obtain a list of installed devices.
    • Expand NI-IMAQdx Devices to obtain a list of available cameras.
    • Right-click the camera and select Driver»NI-IMAQdx IIDC Digital Camera.
    NI Analog and Digital I/O Devices
    This version of Vision Builder AI supports digital and analog I/O from any National Instruments data acquisition (DAQ) device using NI-DAQmx Global Virtual Channels. To support NI DAQ devices, Vision Builder AI requires NI-DAQmx 8.0 or later.
    Serial Communication
    To support serial communication, Vision Builder AI requires NI-VISA 2.6.0 or later, which is included with Vision Builder AI. You can use the serial ports built into the PC or one of the following NI serial interfaces: NI PCI-232/x, NI PXI-8420/x, or NI PXI-8422/x. You do not need to install NI-VISA to use the serial port on a remote target.
    Deployment Policy for Vision Builder AI
    Pursuant to the National Instruments Software License Agreement, Vision Builder AI software is licensed to run on only one machine. Deployed applications that use Vision Builder AI require that Vision Builder AI be installed and licensed on each host machine. Therefore, you must purchase a separate Vision Builder AI license for each host machine. For more information, refer to the enclosed National Instruments Software License Agreement or visit ni.com/legal/license.
    Licensing Options
    For information about licensing NI Vision software, visit ni.com/info and enter the Info Code LicenseVision. Vision Builder AI offers the following licensing options:
    • Vision Builder AI Full-Featured (778649-01)—Allows full access to all Vision Builder AI features, which can be used to configure, benchmark, and deploy inspections. This license does not include the Vision Builder AI Development Toolkit.
    • Vision Builder AI Runtime (779799-03)—Allows you to deploy existing inspections to a host machine and modify the control values for steps in an inspection. This license does not allow you to add steps to or remove steps from an inspection.
    • Vision Builder AI Development Toolkit (779343-03)—Licenses only the Vision Builder AI Development Toolkit, which allows you to create custom steps for use in any Vision Builder AI application.
    Windows Firewall
    If you are using the Windows Firewall and launch Vision Builder AI, a dialog box may prompt you to allow Vision Builder AI to receive information over the network. Select Allow access so that Vision Builder AI can communicate with your remote target.
    Additional ResourcesHow do I get started?
    Read the NI Vision Builder for Automated Inspection Tutorial, which provides exercises for learning how to perform basic machine vision techniques using Vision Builder AI.
    Where can I find reference information?
    Reference information for Vision Builder AI is available from within Vision Builder AI by clicking the Show Context Help button, or selecting Start»All Programs»National Instruments»Vision Builder AI»Documentation.
    The following documents are provided with Vision Builder AI as online help:
    • NI Vision Concepts Help—Contains basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
    • NI Vision Builder for Automated Inspection: Configuration Help—Contains information about the Vision Builder AI Configuration interface, managing inspections and images, and creating steps for an inspection.
    • NI Vision Builder for Automated Inspection: Inspection Help—Contains information about using the Vision Builder AI Inspection interface to run inspections.
    • NI Vision Builder for Automated Inspection: ActiveX Component Reference Help—Contains information about the ActiveX objects available to embed Vision Builder AI inspections into ActiveX applications.
    Use the Search tab in the help files to quickly locate specific information. For information about how to use the search functionality, refer to the Using Help»Searching Help topic in the help file.
    The following documents are provides with Vision Builder AI as Adobe PDF documents:
    • Vision Builder for Automated Inspection Tutorial—Describes Vision Builder for Automated Inspection and provides step-by-step instructions for solving common visual inspection tasks, such as inspection, gauging, part presence, guidance, and counting.
    • NI Vision Builder for Automated Inspection Development Toolkit Tutorial—Contains instructions for using LabVIEW to create custom steps for Vision Builder AI.
    Where can I find examples?
    Examples of common Vision Builder AI inspections are installed to the \Examples directory, where is the location to which you installed Vision Builder AI.
    Where else can I go for Vision Builder AI information?
    Visit ni.com/vision and the NI Developer Zone at ni.com/zone for the most up-to-date information about Vision Builder AI.
    Legal InformationCopyright
    © 2017 National Instruments Corporation. All rights reserved.
    The registered trademark Linux® is used pursuant to a sublicense from LMI, the exclusive licensee of Linus Torvalds, owner of the mark on a world-wide basis.
    375131C-01
    GMT+8, 2026-3-5 03:58
