查看: 13590|回复: 0
[LabVIEW] NI LabVIEW 2016 Win64ENG 64位LV2016英文版下载
    昨天 08:13
  • 签到天数: 3815 天
    连续签到: 8 天
    发表于 2016-8-15 09:50:33 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    什么是LabVIEW 2016?
    LabVIEW 2016是目前可靠性最高的版本,可以帮助您大胆地创新,高效地开发工程应用。 这些新的功能可以抽象底层细节,简化开发,助您专注于要解决的问题,而不是编程语法。 利用LabVIEW的开放性,您可集成任何硬件终端或编程语言。 LabVIEW 2016提供了对第三方设备的更多支持,并提高了与开源软件工具的集成度,使您可以针对应用需求使用正确的工具组合来构建最佳解决方案。
    该版本包含LabVIEW的新特性、各类LabVIEW模块,以及针对其余LabVIEW平台的更新和缺陷修复。本版本对核图标风格进行了间距扩大处理,以显示更多的字符信息。
    标准下载:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI下载器下载:
    提取码: 请购买附件下载查看
    NI官方下载地址(可能无效或无法下载完成)(EXE版和ZIP版内容一样,EXE版为NI当年发行版,ZIP版为NI后期更新重压制版):
    标准下载:
    请购买附件下载查看
    NI下载器下载:
    请购买附件下载查看 LV2016ENG64.txt (832 Bytes, 下载次数: 94, 售价: 10 圆)
    LabVIEW 2016 Readme for Windows
    June 2016
    This file contains important information about LabVIEW 2016 for Windows, including system requirements, installation instructions, a partial list of bugs fixed for LabVIEW 2016 for Windows, and known issues.
    LabVIEW 2016 (64-bit)
    Additions to the LabVIEW Help
    LabVIEW 2016 has the following requirements:
    WindowsRun-Time EngineDevelopment Environment
    ProcessorPentium III/Celeron 866 MHz (or equivalent) or later (32-bit)
    Operating SystemWindows 10/8.11/7 SP12
    Windows Server 2012 R21
    Windows Server 2008 R2 SP12
    Disk Space620 MB5 GB (includes default drivers from the NI Device Drivers media)
    Note  You cannot access LabVIEW using a Guest account on Windows.
    Depending on whether you are installing LabVIEW for the first time or upgrading from a previous version, refer to one of the following documents for information about installing LabVIEW:
    • LabVIEW Installation Guide—Includes information about installing LabVIEW, modules and toolkits, drivers, and hardware.
    • LabVIEW Upgrade Notes—Includes information about protecting existing VIs and projects before you install a new version of LabVIEW, as well as upgrade and compatibility issues and a complete list of new features in LabVIEW 2016.
    You can access the LabVIEW Installation Guide and the LabVIEW Upgrade Notes at ni.com as well as on the installation media.
    Note
    • If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/info and enter the Info Code exjq43 for more information and steps to resolve this issue.
    LabVIEW 2016 Drops Support for Microsoft Windows 7 RTM, Windows Vista, Windows XP, and Windows Server 2003
    With this release, LabVIEW drops support for Microsoft Windows 7 RTM (with no service pack), Windows Vista, Windows XP, and Windows Server 2003. LabVIEW 2016 and later will not install or run on an unsupported OS. You cannot deploy or distribute applications that use LabVIEW 2016 to an unsupported OS. Additionally, after installing LabVIEW 2016, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    When run on Windows (64-bit), LabVIEW 2016 (64-bit) provides access to more memory than a 32-bit operating system or a 32-bit application can provide. LabVIEW 2016 (64-bit) is available in English only.
    Refer to the NI website for information about drivers compatible with LabVIEW 2016 (64-bit). For GPIB devices, you must use at least NI-488.2 2.6 for Windows. Refer to the specific hardware documentation for more information about compatibility with LabVIEW 2016 (64-bit).
    LabVIEW 2016 (64-bit) supports a limited number of modules and toolkits. The following list compares the modules and toolkits available on the LabVIEW Platform installation media.
    ProductLabVIEW 2016 (32-bit)LabVIEW 2016 (64-bit)
    ✓1
    Database Connectivity Toolkit
    DataFinder Toolkit
    Digital Filter Design Toolkit
    FPGA Module
    MathScript RT Module
    ✓2
    Real-Time Module
    Robotics Module
    SoftMotion Module
    Statechart Module
    Sound and Vibration Measurement Suite
    Unit Test Framework Toolkit
    VI Analyzer Toolkit
    Vision Development Module
    1 The Control Design and Simulation Module (64-bit) does not support the System Identification VIs, System Identification Assistant, and Control Design Assistant.
    2 The MathScript RT Module (64-bit) does not support the libraries class of MathScript RT Module functions.
    You can install modules and toolkits supported by LabVIEW 2016 (32-bit) using the LabVIEW Platform installation media. To install modules and toolkits supported by LabVIEW 2016 (64-bit), refer to the NI website for available web downloads or use the LabVIEW 2016 (64-bit) installation media. Refer to the NI website for information about obtaining a copy of LabVIEW 2016 (64-bit).
    You can access the software and documentation known issues list online. Refer to the NI website for an up-to-date list of known issues in LabVIEW 2016.
    The following items are the IDs and titles of a subset of issues fixed in LabVIEW 2016. This is not an exhaustive list of issues fixed in the current version of LabVIEW. If you have a CAR ID, you can search this list to validate that the issue has been fixed.
    333388Incorrect highlight execution order with LVOOP property node
    405304Menu Item VIs can cause LabVIEW to crash
    425622Edit Events menu for Event Structures can delete the new event you are trying to create
    434420Leading zeros are not allowed in Numeric Case Selector values
    463239Resizing the front panel in an EXE and running Quit LabVIEW.vi causes an access violation
    468139.NET Callback Event VI keeps the Callback VI reserved even after calling a Close Reference VI is called
    518954Unconstrained Downhill Simplex ignores some stopping conditions
    519216LabVIEW crash when closing subVI Icon Editor that was opened from VI Hierarchy
    526175Spreadsheet String to Array VI crashes when an empty string is wired to delimeter input
    530595Not a Refnum Primitive returns incorrect value when evaluating a specific type of "Invalid Refnum"
    533890lvinput.dll crashes on Surface Pro 3
    534553Quit LabVIEW function closes VI if you choose cancel
    539895File Dialog Express VI alters error chain
    5444351-D Array Probe Display Window has issues with high resolutions
    544526Fatal Internal Error 0x89B93EF0: "drawmgr2.cpp" when running Mac application for extended time
    544533Scripting dynamic events on an event structure returns Error 1
    544907Delaunay Triangulation hangs on certain input data
    546555Error 1025 when creating Override VI for an already open parent class
    547120Incorrect VI dataflow when using an Error Wire with a parallelized For Loop
    548355Running a VI using the 'DataSocket Select URL.VI', navigating to a remote machine on the network, and browsing to the DataSocket Server Item can cause LabVIEW to crash
    549429DAbort 0x34E86741 ConvertNum called with non-numeric
    554381Sort items in the Choose Implementation class dialog alphabetically
    555317In rare cases Waveform Charts can show different sets of data when pulling from the same source
    555758Using the 'Unflatten From String Function' to unflatten an "invalid" string within LabVIEW x64 can cause the computer to become unresponsive
    555788Using "Fast File Format" to build an executable could result in error 2208 in some cases
    555868Using the Tree Control 'Drag Starting? Event' allows you to Delete the reference to the item you are dragging and can result in a LabVIEW crash
    561615In specific cases, building a LabVIEW executable with shared variables causes Error 1003 during the build
    564219Sometimes if RFmx continuously modifies the loading state of the UI thread, a race condition can occur and potentially cause a crash
    564417Special characters in Control names can cause Unit Tests to not recognize cluster elements in some cases
    567369LabVIEW crashes when getting the properties of a class containing a member VI with certain connector pane configurations.
    569362In cases of extreme load on a TCP server, LabVIEW can miss new connection notifications, causing a timeout
    569793Rare persistent Error 56 at TCP Read
    570547Bluetooth Read, Write, and Close primitives have TCP icon
    571421In certain cases, dynamically calling a VI containing a SubVI can cause a memory leak. The size of the memory leak scales with the size of the SubVI and its dependencies
    571556Showing Visible Items on Waveform Chart probe does not resize chart in the probe window
    571713Scripting a Value Change event for an IVI Logical Name control crashes LabVIEW
    571935Closing a project library containing a class with unsaved changes does not prompt for save
    573160The German, Chinese, and Japanese LabVIEW registry files have the incorrect LabVIEW version
    573195If applications called from SystemExec.vi crash, it can affect LabVIEW TCP communication
    573539In some cases, DNS name resolution in LabVIEW can block other TCP calls
    574048Error 8 when trying to create an actor under an unsaved library
    575278Error 1019 when creating a message, if the actor contains a never-before-saved method
    578899LabVIEW 64-bit Development Environment has the potential to crash while running certain RFmx examples
    580210Remote debugging sessions that involve packed project libraries can stop unexpectedly
    580212Remote debugging VIs that were built without front panels can close the session unexpectedly
    581199Unflatten From String throws error 74, does not update indicators
    585229LabVIEW packed project library can cause calling executable to break when rebuilt
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about LabVIEW 2016.
    The following list contains additional changes to LabVIEW that are not included in the LabVIEW Help, the LabVIEW Upgrade Notes, or both:
    • Installers built on a computer that has LabVIEW 2016 installed can only run on the operating systems that LabVIEW 2016 supports, even if you used an earlier version of LabVIEW to build those installers. To build an installer that can run on an operating system supported by an earlier version of LabVIEW but not by LabVIEW 2016, you must first uninstall LabVIEW 2016 and reinstall the earlier version of LabVIEW.
    © 2004–2016 National Instruments. All rights reserved.
    374715F-01
    GMT+8, 2026-3-5 07:10
