查看: 6993|回复: 3
[NI软件产品] NI Vision Builder for Automated Inspection 2012SP1f2 Win32Eng 自动检测视觉生成器VBAI2012SP1f2 LabVIEW2012SP1版适用
    昨天 08:12
  • 签到天数: 3787 天
    连续签到: 38 天
    发表于 2013-9-4 22:01:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    EXE版:
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    ZIP版:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址(可能无效或无法下载完成)
    请购买附件下载查看
    VBAI2012SP1.txt (557 Bytes, 下载次数: 56, 售价: 10 圆)
    NI Vision Builder for Automated Inspection 2012 SP1 f2 Readme
    May 2013
    This file contains important information about National Instruments Vision Builder for Automated Inspection (Vision Builder AI) software and is organized into the following sections:
    Activation Instructions
    Remote Target Support
    PC-Based Image Acquisition and I/O Support
    Additional Resources
    To configure inspections using Vision Builder AI, the host machine must meet the following requirements:
    MinimumRecommended
    ProcessorPentium 4/M or equivalentCore Duo or equivalent
    Memory512 MB RAM1 GB RAM
    Display1,024 x 768 resolution video adapter with a 24- or 32-bit display1,280 x 1,024 resolution video adapter with a 24- or 32-bit display
    Operating System
    Microsoft Windows 8/7/Vista/XP SP3/Server 2003 R2 (32-bit)/Server 2008 R2
    Browser
    Microsoft Internet Explorer 6.0 or later
    Hard Disk Space
    1 GB
    Complete the following steps to install Vision Builder AI:
    Note: You must be logged in with administrator privileges to install Vision Builder AI.
    • Insert the Vision Builder AI DVD into your DVD-ROM drive. If the DVD does not run automatically, open Windows Explorer, right-click the DVD drive icon, and select AutoPlay.
    • Select Install Vision Builder for Automated Inspection on the National Instruments Vision Builder for Automated Inspection screen.
    • Vision Builder AI prompts you to enter your user information. Select one of the following options:
      • Install this product using the following serial number
      • Install this product for evaluation
      If you choose to enter a serial number, enter the serial number found on your Certificate of Ownership card. Vision Builder AI automatically uses this serial number when you run the NI Activation Wizard.
    • Continue to follow the instructions on the screen.
    If you do not activate a valid license, Vision Builder AI runs in evaluation mode and continues to prompt you to activate a license on each launch. At the end of the evaluation period you must activate a Vision Builder AI license to continue using the product.
    Note: While Vision Builder AI is in Evaluation mode, all features are available except Migrate Inspection to LabVIEW.
    Complete the following steps to activate the Vision Builder AI license:
    • Launch Vision Builder AI.
    • Click Yes when prompted to activate Vision Builder AI.
    • Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
    • Enter your serial number, and click Next.
    • Enter your registration information, and click Next.
    • You can enter an email address to receive a copy of the activation code for your records.
    Deployment Policy for Vision Builder AI
    Pursuant to the National Instruments Software License Agreement, Vision Builder AI software is licensed to run on only one machine. Deployed applications that use Vision Builder AI require that Vision Builder AI be installed and licensed on each host machine. Therefore, you must purchase a separate Vision Builder AI license for each host machine. For more information, refer to the enclosed National Instruments Software License Agreement or visit ni.com/legal/license.
    Licensing Options
    Vision Builder AI offers the following licensing options:
    • Vision Builder AI Full-Featured (778649-01)—Allows full access to all Vision Builder AI features, which can be used to configure, benchmark, and deploy inspections. This license does not include the Vision Builder AI Development Toolkit.
    • Vision Builder AI Run-Time (779799-03)—Allows you to deploy existing inspections to a host machine and modify the control values for steps in an inspection. This license does not allow you to add steps to or remove steps from an inspection.
    • Vision Builder AI Development Toolkit (779343-03)—Licenses only the Vision Builder AI Development Toolkit, which allows you to create custom steps for use in any Vision Builder AI application.
    The following list describes the changes and enhancements in Vision Builder AI:
    • Support for the NI PCIe-8237R GigE Vision interface device
    • Support for the NI PCIe-8236 GigE Vision interface device
    • Support for NI 1712, 1732, 1752, and 1754 Smart Cameras
    • Support for AVI files in the Simulate Acquisition step for Windows, NI Embedded Vision Systems, and NI 177x Smart Cameras
    • Support for AVI files in simulation mode for the acquisition steps
    • Queued pulses capabilities in the Generate Pulse (Vision RIO) step with the NI PCIe-8237R
    • Reduced the Vision Builder AI application launch time, the launch time of the Vision Builder AI engine when using the API, and sped up opening inspections
    Updates
    The following list describes issues in previous versions of Vision Builder AI that are fixed in this release.
    398203The Boolean output in the Read/Write I/O (NI-DAQmx) Step does not drive High when using previous measurement results.
    398645When Learn Calibration at Each Iteration is enabled in the Calibrate Image Step, the angle calculated keeps increasing, which can lead to poor accuracy and bad behavior.
    393859The Find Circular Edge Step might return a memory overflow error when the image is calibrated.
    399143The Calculator Step tree can take a long time to update for large inspections.
    403652The Adv. Find Straight Edge Step configuration parameters are modified when editing the step.
    404621In the Vision Assistant Step, the Vision Assistant menu bar items are not grayed out properly for binary images.
    409404Steps can switch locations when loading an inspection.
    The following list describes issues fixed in Vision Builder AI 2012 SP1.
    361986The Generate Pulse (Vision RIO) Step does not use trigger edges properly.
    368689Vision RIO Device Names do not reset correctly when switching targets.
    386864VB.NET calls to engine.EnableInspectionMeasurements() cause an error.
    302360Vision Builder AI returns an error at launch: Missing NIINI32.dll.
    367792The Detect Objects step can return incorrect results until the inspection is reloaded.
    374523Vision Builder AI should use the same camera names as NI-IMAQdx in MAX.
    375634The Development Toolkit Template 1 does not clean up correctly when Cancel is pressed.
    376954JPEG2000 is not available in Vision Builder AI 2012.
    380343The Run LabVIEW step does not work with paths as controls.
    381421When zooming in the global settings of the Development Toolkit Process Template, an error occurs about an invalid ROI.
    381829The Advanced Straight Edge step does not display the previous value used when editing the step.
    381940The Run LabVIEW step should not run the VI until the Test button is pressed.
    384859Vision RIO input lines do not initialize to correct input filter time.
    386094Vision Builder AI examples cannot find images on a 64-bit operating system.
    388712The Run LabVIEW step generates a nonspecific error message that does not indicate the VI cannot run with separated compiled code.
    367431Disabled steps cannot be deselected in the Inspection Interface Editor.
    372135The Modbus Slave step does not correct values in data tables.
    372737When resizing the Vision Builder AI window during a continuous loop, the measurement updates disappear.
    375729In the Inspect Contour step, the curvature kernel size defaults to 3 regardless of user input.
    379123Setup step results are cleared after the first iteration.
    382738Xcontrols are not initialized correctly, causing missed measurements.
    384877The User Input step accepts "space" as a keyboard shortcut, but it should not.
    You can use Vision Builder AI to remotely configure and control a supported remote target. Vision Builder AI supports the following remote targets:
    • NI 17xx Smart Cameras
    • NI 177x Smart Cameras
    • NI EVS-1463RT Embedded Vision Systems
    • NI EVS-1464RT Embedded Vision Systems
    Note: Vision Builder AI no longer provides support for the NI 1762 Smart Camera, the NI 1764 Smart Camera, and NI CVS-1450 Series Compact Vision Systems.
    To use Vision Builder AI with a remote target, you must use Vision Builder AI to configure the remote target. For more information about using Vision Builder AI to configure the remote target, refer to the documentation included with the remote target.
    The following table illustrates when a remote target requires you to install driver software on the development computer.
    Remote Target or Camera
    Connected to a Remote Target
    Requires Driver Software Installed
    on Development Computer
    NI Smart Camera
    No
    IEEE 1394
    No
    GigE Vision
    No
    Camera Link
    Yes
    Note: To acquire images from a Camera Link camera attached to a NI EVS-1463RT device, you must use MAX to associate a camera file with the camera. For information about how to associate a camera file with a Camera Link camera connected to a remote target, visit ni.com/info and enter the info code rtcamerafile.
    Vision Builder AI supports the following types of image acquisition and I/O devices:
    • National Instruments image acquisition devices
    • IEEE 1394 industrial digital cameras
    • GigE Vision cameras
    • DirectShow-compatible USB cameras
    • IP cameras
    • Digital or analog I/O from NI data acquisition (DAQ) devices
    • Serial devices
    Note: You must install driver software to acquire images from an image acquisition device connected to the development computer.
    National Instruments Image Acquisition Devices
    This version of Vision Builder AI supports National Instruments image acquisition devices that require NI-IMAQ driver version 4.6.4 or later. Specific devices may require later versions.
    Note: If you are using an image acquisition device, you must install NI Vision Acquisition Software before you install the image acquisition device. NI Vision Acquisition Software gives you access to Measurement & Automation Explorer (MAX), which is software you can use to configure National Instruments devices.
    IEEE 1394 Cameras, GigE Vision Cameras, DirectShow-Compatible USB Cameras, and IP Cameras
    This version of Vision Builder AI supports IEEE 1394 cameras, GigE Vision cameras, DirectShow-compatible USB cameras, and IP cameras that require NI-IMAQdx driver version 3.3 or later. Specific devices may require later versions.
    To acquire an image from one of these camera types when the camera is connected to the host computer, use the Acquire Image (1394, GigE, or USB) step. The Acquire Image (1394, GigE, or USB) step requires NI-IMAQdx, which can be installed from the NI Vision Acquisition Software DVD included with Vision Builder AI.
    You must configure an IEEE 1394 camera to use the NI-IMAQdx driver. Complete the following steps to use MAX to configure an IEEE 1394 camera to use the NI-IMAQdx driver.
    • Launch MAX.
    • In the MAX configuration tree, expand Devices and Interfaces to obtain a list of installed devices.
    • Expand NI-IMAQdx Devices to obtain a list of available cameras.
    • Right-click the camera and select Driver»NI-IMAQdx IIDC Digital Camera.
    NI Analog and Digital I/O Devices
    This version of Vision Builder AI supports digital and analog I/O from any National Instruments data acquisition (DAQ) device using NI-DAQmx Global Virtual Channels. To support NI DAQ devices, Vision Builder AI requires NI-DAQmx 8.0 or later.
    Serial Communication
    To support serial communication, Vision Builder AI requires NI-VISA 2.6.0 or later, which is included with Vision Builder AI. You can use the serial ports built into the PC or one of the following NI serial interfaces: NI PCI-232/x, NI PXI-8420/x, or NI PXI-8422/x. You do not need to install NI-VISA to use the serial port on a remote target.
    National Instruments is aware of the following issues you may encounter while using Vision Builder AI.
    General
    • Using a TCP slave device with the Vision Builder AI API and the main Vision Builder AI application simultaneously can cause the device to stop communicating.
    • Vision Builder AI behaves unexpectedly or may not display an inspection image if the image is large and your computer is low on available memory.
    • If you configure a step to pass or fail based on pixel distances and subsequently calibrate the image, the step will compare calibrated values against pixel-based limits.
    • When connected to a remote target in the Configuration interface, the TCP Communication Terminal is not updated if you select an Operate»Run Inspection option.
    • When connected to a remote target in the Configuration interface, the Serial Communication Terminal is not updated if you select an Operate»Run Inspection option.
    • When connected to a remote target, the Configuration interface does not execute the Cleanup state.
    • After connecting to a remote target and starting an inspection in the Vision Builder AI Configuration interface, if you lose communication and reconnect to the target, the inspection opens in the Vision Builder AI Inspection interface.
    LabVIEW Project Integration
    (LabVIEW 2010) You can create a new VI in the context of a remote target added in Vision Builder AI Mode. A VI created in this context cannot run or support shared variables. If you try to add a shared variable to the VI, the VI generates an error message indicating that the target does not support shared variables. Always create a VI in the context of My Computer or a remote target added in LabVIEW Real-Time Mode.
    Windows Firewall
    If you are using the Windows Firewall, you may notice the following behavior:
    • Microsoft Windows 7, Windows Vista, Windows Server 2008, Windows Server 2003, or Windows XP with Service Pack 2 (SP2) or later installed
      When you launch Vision Builder AI, a dialog box may prompt you to allow Vision Builder AI to receive information over the network. Depending on your operating system, select Allow access or Unblock this program so that Vision Builder AI can communicate with your remote target.
    Additional ResourcesHow do I get started?
    Read the NI Vision Builder for Automated Inspection Tutorial, which provides exercises for learning how to perform basic machine vision techniques using Vision Builder AI.
    Where can I find reference information?
    Reference information for Vision Builder AI is available from within Vision Builder AI by clicking the Show Context Help button, or selecting Start»All Programs»National Instruments»Vision Builder AI»Documentation.
    The following documents are provided with Vision Builder AI as online help:
    • NI Vision Concepts Help—Contains basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
    • NI Vision Builder for Automated Inspection: Configuration Help—Contains information about the Vision Builder AI Configuration interface, managing inspections and images, and creating steps for an inspection.
    • NI Vision Builder for Automated Inspection: Inspection Help—Contains information about using the Vision Builder AI Inspection interface to run inspections.
    • NI Vision Builder for Automated Inspection: ActiveX Component Reference Help—Contains information about the ActiveX objects available to embed Vision Builder AI inspections into ActiveX applications.
    Use the Search tab in the help files to quickly locate specific information. For information about how to use the search functionality, refer to the Using Help»Searching Help topic in the help file.
    The following documents are provides with Vision Builder AI as Adobe PDF documents:
    • Vision Builder for Automated Inspection Tutorial—Describes Vision Builder for Automated Inspection and provides step-by-step instructions for solving common visual inspection tasks, such as inspection, gauging, part presence, guidance, and counting.
    • NI Vision Builder for Automated Inspection Development Toolkit Tutorial—Contains instructions for using LabVIEW to create custom steps for Vision Builder AI.
    Where can I find examples?
    Examples of common Vision Builder AI inspections are installed to the \Examples directory, where is the location to which you installed Vision Builder AI.
    Where else can I go for Vision Builder AI information?
    Visit ni.com/vision and the NI Developer Zone at ni.com/zone for the most up-to-date information about Vision Builder AI.
    © 2013 National Instruments Corporation. All rights reserved.
    National Instruments, NI, ni.com, NI TestStand, and LabVIEW are trademarks of National Instruments Corporation. Refer to the Terms of Use section on ni.com/legal for more information about National Instruments trademarks.
    发表于 2013-9-8 19:47:30 | 显示全部楼层 来自:广西桂林市 电信
    发表于 2013-11-19 12:13:11 | 显示全部楼层 来自:福建省福州市 电信
    昨天 08:12
  • 签到天数: 3787 天
    连续签到: 38 天
     楼主| 发表于 2013-11-19 13:21:29 | 显示全部楼层 来自:广东省东莞市 联通
    GMT+8, 2026-1-30 05:22
