查看: 17888|回复: 3
[原创] NI Vision Development Module 2013 Readme /NI VDM2013说明
    昨天 08:12
  • 签到天数: 3787 天
    连续签到: 38 天
    发表于 2013-8-7 16:38:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI VDM2013视觉开发包说明
    June 2013
    This file contains important information about National Instruments Vision Development Module and is organized into the following sections:
    General Information
    Updates and Improvements
    How to Activate the NI Vision License
    Deploying Vision Applications
    Documentation and Examples
    Refer to the Machine Vision Web site at ni.com/vision for the latest information about the NI Vision Development Module.
    General Information
    Installing this program may remove previous versions of the NI Vision Development Module that are currently installed.
    The NI Vision Development Module 2013 supports LabVIEW 2010, 2011, 2012, and 2013; Visual Studio 2005 and 2008; and LabWindows/CVI 8.1 or later. The installer specifically allows side-by-side installations of NI Vision for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, or any other supported development environment, before installing the NI Vision Development Module.
    Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
    This release of the NI Vision Development Module includes the following new features:
    • Support for LabVIEW 2013 (32- and 64-bit)
    • Traditional Mean Shift and Shape Adapted Mean Shift algorithms for tracking objects across a sequence of images
    • New Grayscale Value and Gradient Pyramid pattern matching algorithms. These algorithms enable matching on low-contrast images, robust rotated ROI support, and learning smaller templates.
    • Improvements to OCR: support for reading multiple lines of text, small rotations of text with the region of interest, more robust segmentation, local threshold, color threshold, and space identification
    • Support for Japanese and Simplified Chinese for text overlays on Real-Time targets
    • New examples for LabVIEW 2011, 2012, and 2013
    • Support for the NI cRIO-9068, NI myRIO-1900, and NI myRIO-1950
    NI Vision Assistant includes the following additions:
    • Object Tracking step for tracking objects across a sequence of images using Traditional Mean Shift and Shape Adapted Mean Shift algorithms
    • New Grayscale Value and Gradient Pyramid pattern matching algorithms in the Pattern Matching step. These algorithms enable matching on low-contrast images, robust rotated ROI support, and learning smaller templates.
    • The Windows Start menu shortcut for NI Vision Assistant is now Start>All Programs>National Instruments>Vision>Vision Assistant
    The following list describes issues in previous versions of the NI Vision Development Module that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of the NI Vision Development Module.
    381752AVI: Quality is not implemented for the FFmpeg (Vision built-in) codecs.
    404868Cannot select Create Control from Vision property nodes.
    412022IMAQ Set Calibration Axis Info - Point does not set the axis properly when selected X-axis pixel is at an angle of 90 or -90 degree.
    381293No prompt provided to extend Vision products evaluation periods.
    401407Vision: error 0xC0000005 when using IMAQ Load Image Dialog VI.
    401363Reading AVI frames takes longer and longer when trying to access frames that are further away in the file.
    411876In some cases, the Calibration Training Interface does not properly set the calibration axis, resulting in converted pixel to real-world returning wrong coordinates.
    391306IMAQ Find Circles VI will cause LabVIEW to crash if too many circles are present.
    386275AVI Open/Close has a memory leak on Pharlap.
    386892Vision .NET policy redirects not installed for VDM 2011 SP1, 2012, 2012 SP1.
    366342IMAQ Count Objects 2 does not work properly as a reentrant VI.
    407934IMAQ Overlay Text does not use the User-Specified font on Windows.
    407378IMAQ Overlay Text does not support multibyte characters with user-specified font on Windows.
    411378The Calibration Training Interface Calibration Axis Angle does not set properly when the user chooses to specify angles in the vicinity of 90 or -90 degrees.
    412895NI Template Editor does not error when trying to open an invalid template.
    332875Vision Development Module license cannot be activated from the evaluation dialog when launching LabVIEW.
    The development computer must meet the following system requirements to run the NI Vision Development Module:
    MinimumRecommended
    Processor233 MHz Pentium or equivalentPentium 4/M or equivalent
    Memory256 MB RAM512 MB RAM
    Display1,024 × 768 resolution video adapter with a 16-bit display1,024 × 768 resolution video adapter with a 24- or 32-bit display
    Free Hard Disk Space
    1.4 GB
    Operating System
    Windows 8/Windows 7/Vista/XP (32-bit)/Server 2008 R2/Server 2003 R2 (32-bit)
    Browser
    Microsoft Internet Explorer 6.0 or later
    Remote Target Support
    NI Vision Development Module 2011 SP1 was the last version of NI Vision Development Module to provide support for the NI 1762 Smart Camera and the NI 1764 Smart Camera. New software features of NI Vision Development Module will not work on these devices. Backward compatibility for existing applications will be maintained.
    Installation InstructionsInstalling from the LabVIEW Platform DVDs
    If you purchased LabVIEW, you can install all of your LabVIEW products—including the NI Vision Development Module—using the LabVIEW Platform DVDs.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments Web site.
    Installing from the NI Vision Development Module Installation Media
    Complete the following steps to install the NI Vision Development Module from the NI Vision Development Module installation media.
    • Insert the NI Vision Development Module installation media.
    • If you do not have autorun enabled, double-click autorun.exe. If you have autorun enabled, autorun.exe runs automatically.
    • (Optional) Activate NI Vision Development Module when prompted by the installer, or activate at a later time using the NI License Manager.
    When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision license through an Internet connection.
    • Run the product you want to license.
    • Click Yes when prompted to interactively activate your product.
    • Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
    • Enter the product serial number, and click Next.
    • Enter your registration information, and click Next.
    Tip: Enter your email address to receive a copy of your activation code for your records.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
    • The ability to create NI Vision Run-Time Engine installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or a custom installer.
    • The ability to install the NI Vision Run-Time Engine directly from the Vision Development Module CD.
    • One NI Vision Run-Time License, which allows you to install a custom application on a single machine.
    The NI Vision Development Module installer contains the run-time engine installer for NI Vision. The run-time engine installer is installed at \Run-Time Engine, where is the location to which the NI Vision Development Module is installed. Visit the Drivers and Updates section of ni.com to download software upgrades for NI Vision and the NI Vision Run-Time installers.
    Purchasing NI Vision Deployment Licenses
    You must purchase an NI Vision Run-Time License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Run-Time Engine directly from the NI Vision Development Module CD. The NI Vision Development Module CD ships with one run-time license. Contact a National Instruments sales representative or visit ni.com to purchase additional run-time licenses.
    Note: Additional NI Vision Run-Time Licenses do not include a CD. To install additional licenses, use the original NI Vision Development Module CD and the serial number provided by National Instruments.
    Using the NI Vision Run-Time Engine
    You can call the NI Vision Run-Time Engine installer from the application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can direct the installer to call the NI Vision Run-Time Engine installer.
    Refer to the LabVIEW Help for more information about the LabVIEW Application Builder. Refer to the NI LabWindows/CVI Help for more information about building and distributing LabWindows/CVI applications.
    You can also direct a custom application installer to call the NI Vision Run-Time Engine installer. Refer to the documentation that came with the installer software to learn how to call executables from the custom installer. If you are using a custom installer, call the NI Vision Run-Time Engine installer at the end of the installation procedure because the installer may require the system to be restarted.
    To use the NI Vision Run-Time Engine installer, you must add /qn as a command line argument to the run-time engine installer. For example, enter \Run-Time Engine\vision2012rte.exe /qn to run the NI Vision Run-Time Engine installer, where is the location to which NI Vision is installed.
    Distributing LabVIEW Applications
    The NI Vision Run-Time Engine installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Run-Time Engine as part of the installation.
    Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Run-Time Engine.
    Distributing LabWindows/CVI Applications
    In addition to including the NI Vision Run-Time Engine with the installer, you must include the appropriate LabWindows/CVI Run-Time Engine. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the NI Vision Development Module.
    • The IMAQ Edge Tool 3 VI can cause a fatal error in LabVIEW when using a large ROI.
    • Specifying a negative angle in the IMAQ Learn Pattern 4 VI causes error -1074395249.
    • The AVI2 VIs do not support writing extra data to AVIs.
    • Japanese and Simplified Chinese for text overlays are not supported on NI Linux Real-Time targets.
    • The IMAQ Read QR Code VI may hang when the QR Code Cell Size has a minimum size of 2 or less. Setting the minimum size to 3 or higher will prevent this issue.
    • The IMAQ Read Data Matrix Barcode 3 VI may hang on some I16 images.
    • Zooming out on a large, 32-bit image in the Image Display in LabVIEW will cause the image to black out. Only the displayed image is affected. The image itself is not modified.
    • To store error statistics on corrected images, you must run the IMAQ Get Calibration Info2 VI before correcting the calibration template image. The Return Error Information input must be set to TRUE.
    • Vision Assistant cannot generate C code if a double-byte character exists in the path to Vision Assistant or in the destination path for the generated code.
    • Some Vision Development Module .NET examples only work if Measurement Studio 8.6 or later is installed.
    • The Visual Basic .NET Label example does not compile.
    • There is no 64-bit Vision API for C or .NET.
    • Installing the Vision Development Module on a Windows Vista 64-bit computer where Visual Studio 2005 has been recently installed causes compatibility warnings.
    • On some systems, the Vision Development Module cannot open two of the installed AVI files, SideCrash1.avi and SideCrash2.avi, when running as a 64-bit application.
    • Using NI Vision with LabWindows/CVI on a machine that does not support the MMX instruction set may cause an Illegal Operation exception to occur within the LabWindows/CVI environment. This error occurs when DirectX checks for the availability of the MMX instruction set on the machine.
    The NI Vision Development Module documentation set consists of the following manuals and help files:
    • NI Vision Concepts Help—Describes the basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
    The following sections describe the documents available for each application development environment and where to find example programs.
    NI Vision for LabVIEW Documentation
    • NI Vision for LabVIEW Help—Describes how to create machine vision and image processing applications in LabVIEW using the NI Vision Development Module. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module.
      This document also contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. In LabVIEW, select Help》NI Vision for LabVIEW Help.
      Note: The NI Vision for LabVIEW Help combines the NI Vision for LabVIEW User Manual and NI Vision for LabVIEW VI Reference Help from previous releases into one document.
    • NI Example Finder—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help》Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help.
    NI Vision for LabWindows/CVI Documentation
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
    • NI Vision for LabWindows/CVI Function Reference Help—Contains reference information about NI Vision for LabWindows/CVI functions.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at\bin\NIVision.lfp, where is the location to which LabWindows/CVI is installed.
    • Example programs for specific applications are installed at \Samples\Vision.
    NI Vision for .NET Documentation
    The NI Vision .NET documentation merges into the NI Measurement Studio Help. The NI Measurement Studio Help integrates into the Visual Studio Combined Help Collection under the Measurement Studio node in the Table of Contents. In order for links from Measurement Studio help topics to .NET Framework help topics to work, you must install the product documentation for Visual Studio, which installs the MSDN Library. This requires a secondary installation during the Visual Studio installation process.
    The NI Measurement Studio Help is in the Microsoft Help 2.0 format and requires a Microsoft Help 2.0 viewer to be displayed. A Microsoft Help 2.0 viewer is installed with both Microsoft Visual Studio and the Microsoft .NET Framework SDK. The SDK is freely available from MSDN at http://www.microsoft.com/downloads. If you do not have either of these products, you will need a standalone Microsoft Help 2.0 viewer to display the documentation. Some Help 2.0 viewers are available for download, such as Helpware's H2Viewer.
    • NI Measurement Studio Help—Contains reference information about NI Vision for .NET objects. Describes how to create machine vision and image processing applications in Visual Basic .NET and C# using the NI Vision Development Module. You can launch the NI Measurement Studio Help in the following ways:
      If you have Measurement Studio installed:
      • From the Windows Start menu, select Start》All Programs》National Instruments》》Measurement Studio Documentation, where is the location to which Measurement Studio is installed. The help launches in a stand-alone help viewer.
      • From Visual Studio, select Measurement Studio一I Measurement Studio Help.
      If you do not have Measurement Studio installed:
      • From Visual Studio, select HelpContents to view the Visual Studio table of contents. The NI Measurement Studio Help is listed in the table of contents.
    • Example programs for specific applications are installed at \Examples\dotNET, where is the location to which NI Vision is installed.
    NI Vision Assistant Documentation
    • NI Vision Assistant Tutorial—Describes the Vision Assistant software interface and guides you through creating example image processing and machine vision applications.
    • NI Vision Assistant Help—Contains descriptions of Vision Assistant features and functions and provides instructions for using them. In Vision Assistant, select Help》Online Help.
    • NI Classification Training Interface Help—Contains information about how to use the NI Classification Training Interface to classify binary samples. In the NI Classification Training Interface, select Help》Online Help.
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help》Online Help.
    • NI OCR Training Interface Help—Contains information about how to use the NI OCR Training Interface to learn characters, save character sets, and verify characters by comparing them to a reference character. In the NI OCR Training Interface, select Help》Online Help.
    • NI Texture Training Help—Contains information about how to use the NI Texture Training Interface to train a texture classifier file for use in texture defect detection applications. In the NI Texture Training Interface, select Help》Online Help.
    • NI Calibration Training Help—Contains information about how to use the NI Calibration Training Interface to select and create a calibration for use in machine vision applications. In the NI Calibration Training Interface, select Help》Online Help.
    • NI Vision Template Editor Help—Contains information about how to use the NI Vision Template Editor to learn and edit template images that you can use with pattern matching, geometric matching, and golden template comparison functions. In the NI Vision Template Editor, select Help》Online Help.
  • 签到天数: 2 天
    发表于 2013-8-9 10:06:06 | 显示全部楼层 来自:广东省深圳市 电信
    发表于 2013-8-12 08:39:38 | 显示全部楼层 来自:广西桂林市 电信
  • 签到天数: 15 天
    发表于 2015-8-18 09:11:11 | 显示全部楼层 来自:广东省东莞市 电信
    GMT+8, 2026-1-30 04:02
